86BB2-001
86BB2-001
    GRAYHILLINC.
    SWITCH KEYPAD 16 KEY 0.01A 24V
86BB2-001 数据手册
Standard Keypads Series 86 Unsealed, .500" Centers, Flange Mounted FEATURES • 1/2" Button Centers • Flange Mounted • Top Surface or Sub Surface Mounting • Snap-Dome Contact Provides Positive Feedback 3x4 Keyboard .500 – .010 (12,7 – 0,25) TOL. .600 – .010 (15,24 – 0,25) .150 – .005 (3,81 – 0,13) R. .128 – .010 (3,25 – 0,25) .072 – .010 (1,83 – 0,25) SWITCH KEY IDENTIFICATION FOR REF. ONLY 2.200 – .015 (55,88 – 0,38) 1 .500 – .010 (12,7 – 0,25) 3 EQ. SPS. NON-ACCUM. 2 3 ROW 1 4 5 6 ROW 2 7 8 9 ROW 3 .105 – .010 (2,67 – 0,25) Termination 2.800 – .010 (71,12 – 0,25) .050 (1,27) .055 – .010 (1,40 – 0,25) .200 – .010 (5,08 – 0,25) .360 – .010 (9,14 – 0,25) 1.990 + .000 .010 (50,55 + 0,00 0,25) COL = COLUMN CL OF 2.200 (55,88) Code and Truth Table in inches (and millimeters) 2.200 – .015 (55,88 – 0,38) 3x4 .280 – .010 (7,11 – 0,25) BUTTON NO. 1 .100 (2,54) TYP. .220 – .010 (5,59 – 0,25) A B C F G H L M N Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. RETAINING STUDS CL OF 2.200 (55,88) 1.200 CODES 3x4 BUTTON LOCATION .025 – .002 (0,64 – 0,05) SQUARE TERMINAL 3.000 – .015 (76,2 – 0,38) RETAINING STUDS ROW 4 COL 3 .366 – .010 (9,30 – 0,25) SQUARE BUTTON COL 2 10 11 12 .096 (2,44) 2.690 + .000 .010 (68,33 + 0,00 0,25) BUTTON NO. 1 .100 – .010 (2,54 – 0,25) 2.000 – .010 (50,8 – 0,25) .093 – .005 (2,36 – 0,13) DIA. 4 PLACES .750 – .010 (19,05 – 0,25) COL 1 Keyboards and Keypads Dimensions in inches (and millimeters) 1 2 3 4 5 6 7 8 9 10 11 12 Matrix Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • F E D K J H G J E A K F B L G C MH D N TERMINAL LOCATION .600 .100 TYP. A B C D E F GH J K L MN TERMINAL PIN-OUT SINGLE POLE/COMMON BUS .100 TYP. D E F GH J K Matrix TERMINAL PIN-OUT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads Series 86 Unsealed, .500" Centers, Flange Mounted FEATURES • 1/2" Button Centers • Flange Mounted • Top Surface or Sub Surface Mounting • Snap-Dome Contact Provides Positive Feedback 4x4 Keyboard .500 – .010 (12,7 – 0,25) TOL. 3 EQ. SPS. NON-ACCUM. .600 – .010 (15,24 – 0,25) .150 – .005 (3,81 – 0,13) R. .128 – .010 (3,25 – 0,25) .072 – .010 .093 – .005 (1,83 – 0,25) (2,36 – 0,13) DIA. 4 PLACES SWITCH KEY IDENTIFICATION FOR REF. ONLY 2.700 – .015 (68,58 – 0,38) 2.500 – .010 (63,5 – 0,25) BUTTON NO. 1 .100 – .010 (2,54 – 0,25) .750 – .010 (19,05 – 0,25) 1 9 10 11 12 ROW 3 13 14 15 16 ROW 4 8 ROW 2 COL 4 COL 3 7 .096 (2,44) .050 (1,27) ROW 1 2.690 + .000 .010 (68,33 + 0,00 0,25) 2.800 – .010 (71,12 – 0,25) .055 – .010 (1,40 – 0,25) .200 – .010 (5,08 – 0,25) .360 – .010 (9,14 – 0,25) CL OF 2.700 (68,58) Code and Truth Table in inches (and millimeters) 4x4 Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 2.700 – .015 (68,58 – 0,38) .280 – .010 (7,11 – 0,25) BUTTON NO. 1 .100 (2,54) TYP. 4x4 A B E F G K L M R S T .220 – .010 (5,59 – 0,25) BUTTON LOCATION .025 – .002 (0,64 – 0,05) SQUARE TERMINAL RETAINING STUDS CL OF 2.700 (68,58) .700 1.600 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 • • • • Matrix • • • • • • • • • • • • • • • • • • • • • • • • • • • • • H G F E M L KJ CODES Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• P J E A R L F B S M H C T N GD K TERMINAL LOCATION .100 .100 TYP. TYP. A B CDE F GHJ K L MNP RS T SINGLE POLE COMMON BUS TERMINAL 3.000 – .015 (76,2 – 0,38) RETAINING STUDS 2.490 + .000 .010 (63,25 + 0,00 0,25) COL = COLUMN .105 – .010 (2,67 – 0,25) Termination 4 6 COL 1 .366 – .010 (9,30 – 0,25) SQUARE BUTTON 3 5 COL 2 .500 – .010 (12,7 – 0,25) 3 EQ. SPS. NON-ACCUM. 2 E F G H J K L M MATRIX TERMINAL PIN-OUT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keyboards and Keypads Dimensions in inches (and millimeters) Standard Keypads Series 86 Unsealed, .500" Centers, Flange Mounted FEATURES • 1/2" Button Centers • Flange Mounted • Top Surface or Sub Surface Mounting • Snap-Dome Contact Provides Positive Feedback 5x4 Keyboard .500 ± .010 (12,7 ± 0,25) TOL. 4 EQ. SPS. NON-ACCUM. .600 ± .010 (15,24 ± 0,25) .150 ± .005 (3,81 ± 0,13) R. .128 ± .010 (3,25 ± 0,25) .072 ± .010 (1,83 ± 0,25) .280 ± .010 (7,11 ± 0,25) SWITCH KEY IDENTIFICATION FOR REF. ONLY 3.200 ± .015 (81,28 ± 0,38) BUTTON NO. 1 .100 ± .010 (2,54 ± 0,25) 3.000 ± .010 (76,2 ± 0,25) .750 ± .010 (19,05 ± 0,25) 1 4 5 ROW 1 11 12 13 14 15 ROW 3 16 17 18 19 20 ROW 4 2.800 ± .010 (71,12 ± 0,25) .055 ± .010 (1,40 ± 0,25) .360 ± .010 (9,14 ± 0,25) .093 ± .005 (2,36 ± 0,13) DIA. 4 PLACES 5x4 Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 3.200 – .015 (81,28 – 0,38) BUTTON NO. 1 .100 (2,54) TYP. 5x4 A D E F J K L P Q R U V W BUTTON LOCATION .220 – .010 (5,59 – 0,25) .025 – .002 (0,64 – 0,05) SQUARE TERMINAL RETAINING STUDS CL OF 3.200 (81,28) 2.000 .100 TYP. CL OF 3.200 (81,28) Code and Truth Table in inches (and millimeters) .280 – .010 (7,11 – 0,25) 3.000 ± .015 (76,2 ± 0,38) RETAINING STUDS COL 5 9 COL 4 COL 3 8 .096 .025 ± .002 (2,44) (0,64 ± 0,05) SQUARE TERMINAL .050 (1,27) 2.690 + .000 – .010 (68,33 + 0,00 – 0,25) 2.990 + .000 – .010 (75,95 + 0,00 – 0,25) COL = COLUMN .105 ± .010 (2,67 ± 0,25) Termination 3 ROW 2 7 COL 2 .366 ± .010 (9,30 ± 0,25) SQUARE BUTTON 2 10 6 .500 ± .010 (12,7 ± 0,25) 3 EQ. SPS. NON-ACCUM. COL 1 Keyboards and Keypads Dimensions in inches (and millimeters) .800 • • • • • • • • • • • • • • •• • • • • • • • • • • • • • • • • • • • • • • • • • P N K G F J LM H CODES Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • T P MH DU Q L G C V R K F BW S J EA N TERMINAL LOCATION .100 TYP. A B C D E F G H J K L MN P R S T U VW F GH J K L MN P SINGLE POLE COMMON BUS TERMINAL PIN-OUT MATRIX TERMINAL PIN-OUT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Matrix 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads Specifications Rating Criteria Rating at 24 Vdc: 10 milliamps, resistive Contact Resistance: Compatible with MOS, TTL and DTL (10 ohms maximum) Voltage Breakdown: 250 Vac between mutually insulated parts Life Expectancy: 3,000,000 operations per button Contact Bounce: Less than 4 milliseconds at make, 10 milliseconds at break Operating Temperature: -40°C to +80°C Contact Dome: Stainless steel, selectively gold- plated Terminals: Phosphor bronze Materials and Finishes Operating Features Housing: ABS polycarbonate, black Buttons: ABS plastic, white. Legends are black. Snap-On-Cap: Clear polycarbonate Button Travel: 0.015" nominal total travel Typical Operating Force: 350 grams Standard Legends insert. This surface can also be ink stamped by Grayhill in higher volume quantities. When the cap is replaced, the assembly extends approximately .015" (0,38 mm) above the surface. The legend sheet information follows 5x4: Shown below -201 (Insertable) the legend presentation. All other legends incorporate molded-in (two shot) legends with the exception of legend numbers -202 and -203. The blank legends or spaces in legends -202 and -203 are insertable legends, others are molded-in. -202 -203 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 Molded-in 8 9 a B 8 9 a B C D e F C D e F Insertable Molded-in Insertable Insertable Legends For use with -101, -001, -201, -202 and -203 legend options. Legends are die cut to fit button surface when cap is removed. Dry transfer legends offer some flexibility to customize the blank inserts included on the sheet of popular legend letters, words and symbols provided or on the insertable legends sheet. Description Part No. Sheet of Legend Inserts Dry Transfer Lettering, Small Dry Transfer Lettering, Medium Dry Transfer Lettering, Large 87AC2046 87-DT-2096-088 87-DT-2096-125 87-DT-2096-187 Ordering Information Grayhill Series Number Size Option A = 3x4 B = 4x4 J = 5x4 Circuitry Option B2 = Matrix code C2 = Single pole/common bus 86AB2–103 Standard Legend Choices 3x4 Size: -101, -102 or -103 4x4 Size: -001, -002, -003, -004, -005 or -006 5x4 Size: -201, -202, or -203 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keyboards and Keypads Insertable legend version (legend numbers -101, -001, -201 and row or column indicated in -202 and -203) has a removable cap. The revealed button surface can be legended by an insert or a dry transfer of a blank legend
86BB2-001
PDF文档中包含以下信息: 1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压DC/DC转换器,适用于需要高效率和低噪声的应用。
3. 引脚分配:LM5111有8个引脚,包括输入电压、输出电压、地、使能、反馈、开关节点等。
4. 参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
5. 功能详解:详细介绍了器件的工作原理、功能和应用场景。
6. 应用信息:适用于需要高效率和低噪声的电源转换场合。
7. 封装信息:器件采用SOIC封装。
86BB2-001 价格&库存
很抱歉,暂时无法提供与“86BB2-001”相匹配的价格&库存,您可以联系我们找货
