96AB2-102-FS
96AB2-102-FS
    GRAYHILLINC.
    KEYPAD 12 BTN FRONT PANEL MNT
96AB2-102-FS 数据手册
Standard Keypads SERIES 96 Conductive Rubber Keyboards and Keypads FEATURES • Quality, Economical Keyboards • Easily Customized Legends • Matrix Circuitry • Backlit and Shielded Options Available • Termination Mates With Standard Connectors • Tactile Feedback to Operator • 1,000,000 Operations per Button • Compatible With High Resistance Logic Inputs The Series 96 is Grayhill's most economical 3x4 and 4x4 keypad family. The contact system utilizes conductive rubber to mate the appropriate PC board traces. Offered in matrix circuitry, with shielded and backlit options. Built with quality component parts, the Series 96 is subjected to our rigid statistical process control to insure that it meets our reliability standards. DIMENSIONS In inches (and millimeters) 3x4 Front Mount Keyboard 3 4 5 6 7 8 9 10 11 12 2.400 (60,96) .350 (8,89) 1.100 (27,94) 10 9 8765432 1 .150 (3,81) 2.400 (60,96) 2.400 (60,96) GRAYHILL INC GRAYHILL INC 1.000 (25,4) .308 (7,82) SQ. BUTTON 12 PLS. 1.700 (43,18) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .150 (3,81) 2.700 1.500 ± .015 (68,58 (38,1) ± 0,38) SWITCH POSITION IDENTIFICATION FRONT PANEL MOUNT CUTOUT .550 (13,97) .600 (15,24) .600 (15,24) .500 (12,7) .030 (0,76) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .150 (3,81) R. 4 CORNERS .500 (12,7) 2 Shielded/Backlit Versions .030 (0,76) 2.000 ± .015 (50,8 ± 0,38) .500 (12,7) 1.000 (25,4) 1 Standard Versions .125 (3,18) .062 (1,57) R. 2 PLS. .125 (3,18) MAXIMUM PANEL THICKNESS RECOMMENDED .125 (3,18) DIA. 2 PLS. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD .250 (6,35) 4 PLS. .200 (5,08) LABEL LABEL .100 (2,54) DIA. 4 PLS. .100 (2,54) DIA. 4 PLS. 1.700 (43,18) .150 (3,81) 1.700 (43,18) .100 (2,54) REF. TERMINAL PIN HEADER .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION TERMINAL PIN IDENTIFICATION 7 6 5 4 3 2 1 10 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .150 (3,81) .098 (2,49) REF. TERMINAL PIN HEADER 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keypads 3 Standard Keypads DIMENSIONS In inches (and millimeters) 3x4 Rear Mount Keyboard Standard Versions .030 (0,76) 2.200 ± .015 (55,88 ± 0,38) 2.000 (50,8) .600 (15,24) 1.000 (25,4) .500 (12,7) .500 (12,7) Shielded/Backlit Versions .340 ± .015 (8,64 ± 0,38) .030 (0,76) .150 (3,81) R. 4 PLS. .025 ± .002 (0,64 ± 0,05) SQ. PIN .750 (19,05) .650 (16,51) .600 (15,24) .025 ± .002 (0,64 ± 0,05) SQ. PIN .700 (17,78) 1.100 (27,94) .500 (12,7) 10 9 8 7 6 5 4 3 2 Keyboards and Keypads 2.690 + .000 .595 –.005 (15,11) (68,33 + 0,00 –0,13 1 2 3 4 5 6 7 8 9 10 11 12 .495 (12,57) .308 (7,82) SQ. BUTTON 12 PLS. GRAYHILL INC GRAYHILL INC 1.000 (25,4) .050 (1,27) 2.000 (50,8) 2.800 (71,12) .200 (5,08) 1.500 (38,1) SW. POS. ID .150 + .000 –.005 R. (3,81 + 0,00 –0,13) 4 PLS. 1 .200 (5,08) .500 (12,7) 2.800 (71,12) 3.000 ± .015 (76,2 ± 0,38) 1.990 + .000 –.005 (50,55 + 0,00 –0,13) REAR PANEL MOUNT CUTOUT .340 ± .015 (8,64 ± 0,38) LABEL .062 (1,57) .200 (5,08) .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD LABEL .100 (2,54) R. 4 PLS. .093 (2,36) DIA. 4 PLS. .100 (2,54) REF. TERMINAL PIN HEADER .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION TERMINAL PIN IDENTIFICATION 7 6 5 4 3 2 1 2.700 (68,58) 10 9 .100 (2,54) TYP. .062 (1,57) MAXIMUM PANEL THICKNESS RECOMMENDED .100 (2,54) R. 4 PLS. .093 (2,36) DIA. 4 PLS. 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .098 (2,49) REF. TERMINAL PIN HEADER .093 (2,36) DIA., 4 PLS. OR 2-56 X .250 (6,35) LONG STUD 4x4 Front Mount Keyboard 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 GRAYHILL INC .125 (3,18) .062 (1,57) R. 2 PLS. LABEL .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD 2.200 (55,88) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .100 (2,54) DIA. 4 PLS. .150 (3,81) TERMINAL PIN IDENTIFICATION 8 7 6 5 4 3 2 1 .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION 1110 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .150 (3,81) 2.200 (55,88) .100 (2,54) REF. TERMINAL PIN HEADER .250 (6,35) 4 PLS. .200 (5,08) .125 (3,18) DIA. 2 PLS. LABEL .100 (2,54) DIA. 4 PLS. .125 (3,18) MAXIMUM PANEL THICKNESS RECOMMENDED Keypads 4 .150 (3,81) 2.400 (60,96) 2.400 (60,96) GRAYHILL INC .308 (7,82) SQ. BUTTON 12 PLS. 2.400 (60,96) 1 1.000 (25,4) SWITCH POSITION IDENTIFICATION 2.200 (55,88) 1110 9 8 7 6 5 4 3 2 .150 (3,81) 2.700 1.500 ± .015 (68,58 (38,1) ± 0,38) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN 1.200 .700 (30,48) (17,78) .750 (19,05) .700 (17,78) .600 (15,24) .500 (12,7) .030 (0,76) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .150 (3,81) R. 4 CORNERS .500 (12,7) FRONT PANEL MOUNT CUTOUT Shielded/Backlit Versions .030 (0,76) 2.500 ± .015 (63,5 ± 0,38) 1.500 (38,1) 1.000 (25,4) .500 (12,7) Standard Versions .098 (2,49) REF. TERMINAL PIN HEADER 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Standard Keypads DIMENSIONS In inches (and millimeters) 4x4 Rear Mount Keyboard Standard Versions .500 (12,7) .340 ± .015 (8,64 ± 0,38) .030 (0,76) 2.700 ± .015 (68,58 ± 0,38) 2.500 (63,5) 1.500 (38,1) 1.000 (25,4) .600 (15,24) Shielded/Backlit Versions .150 (3,81) R. 4 PLS. .025 ± .002 (0,64 ± 0,05) SQ. PIN .750 (19,05) .700 (17,78) .650 (16,51) .500 (12,7) .025 ± .002 (0,64 ± 0,05) SQ. PIN 1.200 .700 (17,78) (30,48) .900 (22,86) 1110 9 8 7 6 5 4 3 2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 GRAYHILL INC GRAYHILL INC 1.000 (25,4) SW. POS. ID .308 (7,82) SQ. BUTTON 12 PLS. LABEL .100 (2,54) R. 4 PLS. .093 (2,36) DIA. 4 PLS. .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD .050 (1,27) .150 + .000 –.005 R. (3,81 + 0,00 –0,13) 4 PLS. LABEL .062 (1,57) .200 (5,08) 2.800 (71,12) 3.000 ± .015 (76,2 ± 0,38) 2.490+ .000 –.005 (63,25 + 0,00 –0,13) 2.500 (63,5) 2.800 (71,12) .200 (5,08) 1.500 (38,1) .495 (12,57) REAR PANEL MOUNT CUTOUT 1 .200 (5,08) .500 (12,7) .093 (2,36) DIA. 4 PLS. .100 (2,54) REF. TERMINAL PIN HEADER .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION TERMINAL PIN IDENTIFICATION 8 7 6 5 4 3 2 1 2.700 (68,58) 11 10 .100 (2,54) TYP. .062 (1,57) MAXIMUM PANEL THICKNESS RECOMMENDED .098 (2,49) REF. TERMINAL PIN HEADER .100 (2,54) R. 4 PLS. 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .093 (2,36) DIA., 4 PLS. OR 2-56 X .250 (6,35) LONG STUD CODE AND TRUTH TABLES Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 12 Button Keypads MATRIX CODES Standard Shielded/Backlit • • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• • • • • • • • • • • • 4x4 Shielded keypad = Shielded Backlit keypad = NC Shielded and backlit keypad = Shielded • • • Shielded keypad = NC Backlit keypad = EL Panel 1 Shielded and backlit keypad = EL Panel 1 • • • 5 6 7 1 2 3 4 6 7 8 2 3 4 5 1 9 10 Shielded keypad = NC Backlit keypad = EL Panel 2 Shielded and backlit keypad = EL Panel 2 TERMINAL LOCATION BUTTON LOCATION BUTTON LOCATION 3x4 1 2 3 4 5 6 7 8 9 10 11 12 16 Button Keypads 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Standard • • • • • • • • • • • • • • • • • • • • MATRIX CODES Shielded/Backlit • • • • • • • • • • • • • • • • • • •• • • • Shielded keypad = Shielded Backlit keypad = NC Shielded and backlit keypad = Shielded • • • • • • • • • • • • • 5 6 7 8 1 2 3 4 • • • • Shielded keypad = NC Backlit keypad = EL Panel 1 Shielded and backlit keypad = EL Panel 1 • • • • Shielded keypad = NC Backlit keypad = EL Panel 2 Shielded and backlit keypad = EL Panel 2 6 7 8 9 2 3 4 5 1 10 11 TERMINAL LOCATION Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Keypads 5 Keyboards and Keypads 2.690 + .000 .595 –.005 (15,11) (68,33 + 0,00 –0,13 .340 ± .015 (8,64 ± 0,38) .030 (0,76) Standard Keypads SPECIFICATIONS Shielding Effectiveness Rating Criteria Results shown are typical for a standard Grayhill Series 84S keyboard. A conductive gasket will generally increase the shielding, depending on the size and shape of the gasket and its material. Data derived for E-Field Radiation. Rating at 12 Vdc: 5 milliamps for .5 seconds Contact Bounce: < 12 milliseconds Contact Resistance: < 300 milliohms max. Voltage Breakdown: 250 Vac between components Mechanical Operation Life: 1,000,000 operations per key Insulation Resistance: > 1012 ohms @ 500 Vdc Push Out Force Per Pin: 5 lbs. Operating Features Keyboards and Keypads Travel: .040 minimum Operating Force: 175 ± 40 grams Operating Temperature: -30°C to +80°C Material and Finishes Terminal Pin: Phosphor bronze PC Board: FR-4 glass cloth epoxy Keypad: Silicone rubber, durometer 50 ± 5 Housing: ABS, cycolac FR15 Housing Color: Black SHIELDING EFFECTIVENESS OF SERIES 96 E.L. KEYPADS dB 100 80 60 40 Test Method: Measurements were made with the keyboard mounted to a brass plate, which in turn was mounted to a shielded enclosure containing the receiving equipment. A signal generator provided the frequency source that was radiated from the transmitting antenna to the enclosed receiving antenna. The spacing between antennas was maintained constant throughout the frequency range. The effectiveness rating is determined by establishing a reference reading without obstruction between the two antennas and determining the difference between that reading and the test setup reading. Note: When measured in actual equipment, shielding effectiveness is determined by many factors. This method accurately represents the shielding effectiveness of the Grayhill Series 84S under Ideal test conditions. 20 0 0.1 10 100 400 800 2000 6000 10000 18000 MHz Represents shielding effectiveness greater than or equal to line. Frequency M Hz 0.1 10 100 400 800 2,000 6,000 10,000 18,000 Rating in dB t 66.2 t 94.8 90.5 64.2 42.3 40.5 33.1 34.4 37.0 STANDARD LEGENDS Available through Grayhill Distributors To order one of the configurations below, use the dash number shown here; select the keypad size and code, and order the part number with the appropriate legend dash number. 1 2 3 1 ABC DEF 2 3 4 5 6 GHI JKL 4 5 7 8 9 PRS 7 A 1 2 3 1 ABC DEF 2 3 MNO B 4 5 6 GHI JKL 4 5 MNO B TUV WXY 7 8 9 PRS WXY 9 C TUV 8 8 9 C 6 OPER 0 0 -102 D 0 -006 -152 7 6 OPER 0 A D -056 ORDERING INFORMATION Grayhill Series Number Keyboard Size: A = 3x4, B = 4x4 Circuitry: B2 = Matrix (terminal pin header) Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 96AB2-102-FS-EL E.L. Panel Backlighting Option EL = Backlit, Blank = Non-backlit EMI/RFI Shielding Option S = Shielded, Blank = Non-shielded Mounting Option: F = Front panel mount, R = Rear panel mount Standard Legend Choices 12 Position legends 102 = Black legends on a white button 152 = White legends on a black button 16 Position legends 006 = Black legends on a white button 056 = White legends on a black button Keypads 6 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
96AB2-102-FS 价格&库存
很抱歉,暂时无法提供与“96AB2-102-FS”相匹配的价格&库存,您可以联系我们找货
