83201003
83201003
    CROUZET(高诺斯)
    SNAP ACTION SWITCH SPDT X1C 50MA
83201003 数据手册
| | www.crouzet-switches.com || 1 | | microswitches | | 04/2016 Sub-subminiature microswitches - Sealed V5S - 8320 › High precision flexible leaf snap-action mechanism › Operation without balance-point, even at extremely slow actuating speed › Very small size › Extra-long plunger stroke: 2 mm overtravel to absorb dispersions in application › Suitable for lateral approach from any direction with angle up to 45° › Excellent resistance to harsh environments - IP67/IP69 protection › Ratings from 1 mA 4 Vc to 4 A 250 Va › Long mechanical life › Various terminal types and pre-wired models - Choice of flexible actuators Main specifications Standard 83200 Function Connections / Locating pins I (changeover) X1 / none I (changeover) X1 / CAV, CAR, LAV, LAR, 4C, 4L I (changeover) X1L / none I (changeover) X1L / CAV, CAR, LAV, LAR, 4C, 4L I (changeover) X2 / CAR I (changeover) X2 / LAR I (changeover) X2 / none, CAV, LAV, 4C, 4L I (changeover) X3 / CAV I (changeover) X3 / LAV I (changeover) X3 / none, CAR, LAR, 4C, 4L I (changeover) W2 / LAV I (changeover) W2 / 4C I (changeover) W2 / none, CAV, CAR, LAR, 4L I (changeover) W2ST / none, CAV, CAR, LAV, LAR, 4C, 4L I (changeover) FB0 / CAR I (changeover) FG0 / 4L I (changeover) FD0 / none I (changeover) FB0, FG0, FD0 / none, CAV, CAR, LAV, LAR, 4C, 4L R (Normally closed) FB0, FG0, FD0 / none, CAV, CAR, LAV, LAR, 4C, 4L C (Normally open) FB0, FG0, FD0 / none, CAV, CAR, LAV, LAR, 4C, 4L Electrical characteristics Rating nominal / 250 V AC (A) Operating range / 4 ➞ 14 V AC/DC (A) Rating thermal / 250 V AC (A) Mechanical characteristics Max. operating force (N) Min. Release force (N) Max. total travel force (N) Max. Allowable overtravel force (N) Max. rest position (mm) Operating position (mm) Max. differential travel (mm) Min. overtravel (mm) Ambient operating temperature (°C) Mechanical life (operations) Contact gap (mm) Weight (g) (terminal versions) * Please contact us Low current 83201 83200003 83201003 ● ● 83200004 83201004 ● ● 83200005 83200023 83201005 83201023 ● ● 83200006 83200024 83201006 83201024 ● ● 83200034 83200035 83201034 83201035 ● ● ● ● 83200051 83200063 83200071 83201051 83201063 83201071 ● ● 83202* 83204* 83203* 83205* 4 5 0.001 ➞ 0.05 0.1 1.5 0.2 2.5 10 11.1 10.5±0,2 0.15 2 -40 ➞ +90 106 0.3 0.75 1.5 0.15 2.5 10 11.1 10.5±0,2 0.2 2 -40 ➞ +90 106 0.6 0.75 Additional characteristics - Degree of protection: IP67/IP69 (mechanism and wire output) - Protection against electric shock: button and actuators have reinforced insulation for Ui 250V / Uimp 2,5kV / pollution 2 - Recommended min actuating speed: 0.001 mm/s - Cover: PARA GF - Base: PA66 GF (UL 94-V0 / GWFI 960 °C) - Button: POM - Membrane: silicone rubber - Moving blade: silver-plated beryllium copper - Contacts: silver alloy - Terminals: silver-plated brass - Wire leads: copper, PVC insulated - Levers: stainless steel Standard product Product made to order Contact us | | www.crouzet-switches.com || 2 | | microswitches | | 04/2016 Product adaptations › Special connections: SMD terminals, special leads, cables, full wiring with custom connector › Special levers: special shapes and lengths › Fully customized switching modules with integrated connector › Integration of resistors for specific electrical diagrams or self-diagnosis function › Low switching hysteresis variant: 0.06 mm max differential travel › Dual-current version with gold plated contacts for use from 1mA to 4A › High operating temperature: +125 °C › cURus approved versions - ENEC approval Principles Single break snap-action switch Changeover - SPDT (form C) 2 4 Normally closed - SPST-NC (form B) 2 1 Normally open - SPST-NO (form A) 1 4 1 Curves Electrical life Low-current 83201 - 5 Vc 1 mA resistive 1.000.000 cycles Standard 83200 - 250 Va 4 A resistive > 6.000 cycles - 14 Vc 2 A resistive 200.000 cycles - 14 Vc 10 W lamps 100.000 cycles - 14 Vc 0.5 A L/R = 4 ms 50.000 cycles Dimensions (mm) Product 8320 Version without locating pins 8320 Version with locating pins 2 2,27 ±0,2 5,08 4 3,75 ±0,1 7,5 ±0,2 1±0,1 12,2 ±0,15 1,8 ±0,1 1 1 0,6 5,08 4 1 1 ±0,05 ±0,2 2 1 Ø 2.6 ±0.1 on ribs ±0,2 5,4 -0,15 +0,10 R 0,5 ±0,2 5,3 ±0,2 +0,1 14,7 -0,2 1 Total travel position: max 8.5 Locating pins 1 2 1 2 short pins at rear (CAR) 3 ±0,1 Ø2,2±0,08 2 4 short pins (4C) 3 2 short pins at front (CAV) 12,13 4 2 long pins at rear (LAR) 9,53±0,15 6 2 long pins at front (LAV) Ø2,2 ±0,08 ±0,1 4 5 ±0,1 4,9 6 9,53 ±0,15 12,13 ±0,1 1,5 5 4 long pins (4L) | | www.crouzet-switches.com || 3 | | microswitches | | 04/2016 Recommendations for lateral approach 45° In order to reduce friction and wear, the actuating ramp shall preferably be of PA, POM, PBT or steel, and also be as smooth as possible. As a general rule, the use of any lubricant substance is not needed nor recommended. For particular cases, please consult us. . max 35° 35° 35° 45° 45° 35° 35° 35° Connections 0,5±0,05 2,85±0,2 0,5±0,05 ±0,2 2,85 0,6 0,6 ±0,05 ±0,05 3,6 ±0,2 5,85±0,2 2,05±0,2 0,5±0,05 1 X3 for printed circuit board, front output 2,05±0,2 X2 for printed circuit board, rear output 5,85±0,2 1±0,2 X1-X1L for printed circuit board, straight output 1 X1 = 3.5 ± 0.2 X1L = 7 ± 0.2 W2 - W2ST solder CMS2 for surface mounting, rear output CMS3 for surface mounting, front output 0,1±0,08 ±0,05 ±0,2 0,5 1 With holes: W2 Ø 1.8 ± 0.1 5,85±0,2 2,05±0,2 2,05±0,2 5,85±0,2 ±0,2 2 2,8 3,5 ±0,2 1 0,1±0,08 Please contact us Please contact us Without holes: W2ST 4 2 1 1 4 2 18 Wire characteristics 1: Black 2: Grey 4: Blue Cross-section: 0.35 mm2 Standard length: 500 mm (other lengths on request) 6,5 2 1 FG0 wire output on left 16 4 16 2 FD0 wire output on right 6,5 12,5 15,5 FB0 wire output on bottom 4 1 4 2 18 1 | | www.crouzet-switches.com || 4 | | microswitches | | 04/2016 Drilling Installation on printed circuit board with locating pins 5,85±0,05 2,5 ±0,05 Installation on printed circuit board X1-X1L-X2-X3 5,08±0,05 3xØ1,3+0,1 0 2,6 +0,1 0 9,53±0,05 Ø2,5±0,05 3xØ1,3 5,08±0,05 5,08±0,05 +0,1 0 5,08±0,05 9,86±0,05 Actuators 200AF flexible flat lever 200FF flexible dummy roller lever F R R 3±0,1 R F R0,7±0,1 Other shapes and dimensions: consult us R0,7±0,1 Mounting accessories Stainless steel mounting flange 6,25 ±0.1 5.5 ±0.2 Ø 3,1 0,3 22 ±0.1 15,8 ±0.2 2 4 1,25±0,1 1 3,6±0,1 3,6±0,1 1 Operating position 8±0,2 8±0,2 ±0,03 0,3 1,25±0,1 1 1 | | www.crouzet-switches.com || 5 | | microswitches | | 04/2016 Actuators and mounting accessories Actuators Flexibles actuators Max. operating force Min. release force Operating position (N) (N) (mm) Flat 200AF R15 Flat 200AF R20 1.5 0.1 11.4 ±0.4 1.3 0.05 12.2 ±0.4 Dummy roller 200FF R17 1.5 0.1 14.75 ±0.5 Actuators are factory mounted Mounting accessories 79257491 Stainless steel mounting flange Installation recommendations See “Basic technical concepts” How to order Use the 8 digit part numbers when they are defined Other cases, precise: Type of microswitch - Connection - Locating pins - Actuator* - Mounting accessories* - Adaptation* * if needed Example: 83200 W2 CAV 200AF R15 79257491 Examples of special adaptations IP67 module with 45° rotary operation, maintained action, integrated connector and quick fastening IP67 module with integrated connector and quick fastening “V4 size” conversion housing and wire lead or cable output Customized wiring Printed circuit board assembly with connector Special levers
83201003 价格&库存
很抱歉,暂时无法提供与“83201003”相匹配的价格&库存,您可以联系我们找货
