| | www.crouzet-switches.com
|| 1
| | microswitches
| | 07/2016
Miniature microswitches - SEALED
V3S - 83169
› High precision flexible leaf snap-action mechanism
› Operation without balance-point, even at extremely slow actuating speed
› Excellent resistance to harsh environments - IP67/IP69 protection
› High resistance to shock and vibration - Very long life
› Operating temperature -40 °C up to 130 °C
› Wire lead or cable output
› Tight switching hysteresis versions: 0.07 mm max differential travel
› Ratings from 1 mA 4 Vc to 8 A 250 Va and 1/4 HP 125-250 Va
› Wide choice of actuators on 4 possible fixing positions (pre-assembled
or retrofittable)
Main specifications
Standard
831690
Function
Connections
I (changeover)
D0.5
I (changeover)
G0.5
I (changeover)
C0.5
I (changeover)
Y0.5
I (changeover)
D - G - C -Y *
R (normally closed)
D - G - C -Y *
C (normally open)
D - G - C -Y *
* wire length or cable length on demand
Electrical characteristics
Rating nominal / 250 V AC (A)
Rating thermal / 250 V AC (A)
Mechanical characteristics
Maximum operating force (N)
Min. Release force (N)
Maximum total travel force (N)
Max. Allowable overtravel force (N)
Rest position max. (mm)
Operating position (mm)
Maximum differential travel (mm)
Min. overtravel (mm)
Ambient operating temperature-wires (°C)
Ambient operating temperature-cable (°C)
Mechanical life (operations)
Contact gap (mm)
Weight (g)
Reduced differential
travel
831694
Dual-current
831698
Dual-current
travel
831699
83169002
83169001
83169015
83169046
83169405
83169404
83169406
83169442
83169802
83169801
83169803
83169820
83169905
83169904
83169906
83169913
8
10
5
6
5**
6
5**
6
4.5
1
8
14.7±0.5
0.35
1
-40 ➞ +105 °C
-40 ➞ +90°C
5 x 106
0.4
30
4.5
1
8
14.7±0.5
0.07
0.4
-40 ➞ +105 °C
-40 ➞ +90 °C
5 x 106
0.4
30
4.5
1
8
14.7±0.5
0.35
1
-40 ➞ +105 °C
-40 ➞ +90 °C
5 x 106
0.4
30
4.5
1
8
14.7±0.5
0.07
0.4
-40 ➞ +105 °C
-40 ➞ +90 °C
5 x 106
0.4
30
Additional specifications
- Case: PBT GF (UL 94-V0 / GWFI 960 °C)
- Button: stainless steel
- Membrane: fluorosilicone rubber
- Moving blade: silver-plated beryllium copper
- Contacts: silver alloy, micro-profile
gold alloy on silver alloy, crossbar (dual-current)
- Wire leads, cable: copper, PVC insulated
- Levers: stainless steel, polyamide roller
- Degree of protection: IP67/IP69
-P
rotection against electric shock : models with cable output on left are
suitable for Class II equipment up to 250 V without additional protection
- Recommended min actuating speed: 0.001 mm/s
Product adaptations
› Special levers: special shapes and lengths, flexible levers, adjustable, pinned, ….
› Special leads and cables, EN 50306 halogen free versions, full wiring with custom connector
› High operating temperature: +130 °C
› Long overtravel variant (min 3.5 mm) with metal or plastic plunger, also suitable for lateral approach up
to 30° (SP4978, SP4988)
› Adjustable fixing by threaded barrel: see 83581
› Reinforced housing with metal insert and cable output for very severe conditions
› Variant with plastic button for double insulation (SP4965)
› Integrated varistor for extended service life on DC inductive load
› cURus approved versions
Standard product
Product made to order
Contact us
|| 2
| | microswitches
| | 07/2016
Principles
Single break snap-action switch
Changeover - SPDT (form C)
Normally closed - SPST-NC (form B)
2
1
Normally open - SPST-NO (form A)
2
1
1
4
4
Curves
Operating curve for type 831690
1
2
3
107
Operating curve for type 831694
1
L = 5 ms
R
cos ϕ = 0,8
10
7
4
5
2
250V~
250V~
2
3
L = 5 ms
R
cos ϕ = 0,8
1
107
4
5
12Vc
106
5
2
Operating curve for types 831698/831699
2
250V~
250V~
2
105
5
5
2
104
0.1 0.2 0.5 1 2
4
12Vc
250V~
2
5
5
L = 5 ms
R
cos ϕ = 0,8
106
5
105
5 8
2
105
2
104
0.1 0.2 0.5 1 2
3
5
12Vc
106
5
2
5
2
104
0.1 0.2 0.5 1 2
5
5
5
B
C
D
E
F
Number of cycles
Resistive circuit
Inductive circuit
Mechanical life limit
Current in Amps
** Models 831698 and 831699 are designed to operate equally well on low-current (1 mA 4 V minimum recommended) or medium-current (5 A maximum)
circuits. However, a given product should only be used to switch one type of circuit during its working life.
Dimensions
Product
10,3 ±0,1
83169
B Total travel position
Connections
Y cable output on right
Ø5
C cable output on left
Ø5
Ø2
G wire output on left
Ø2
D wire output on right
max. 5***
***Outer jacket stripping
Wire characteristics:
1: black (common)
2: brown (NC)
4: blue (NO)
Cross section: 1 mm2
Standard length: 0.5 m (other lengths on request)
Cable characteristics:
1: black (common)
2: brown (NC)
4: grey (NO)
Cross section: 3 x 0.75 or 2 x 0.75 mm2
|| 3
| | microswitches
| | 07/2016
Actuator mounting positions
161-type levers (clipped-on)
0,6
139-type levers (pinned)
Actuators
139AX flat
139EX roller
161A flat
4,6
0,5
0,5 x 3,8
161F dummy roller
2
5,7
7
161G dummy roller
161E roller
R 2,5
22
21
5,5
,2
,8
x7
0,5
3
0,
Other shapes and dimensions: consult us
|| 4
| | microswitches
| | 07/2016
Actuators and mounting accessories
Part numbers for standard
actuators
79215740
Flat 139 AX
R29.7*
Actuators
Fixing position
Operating force - max.
Release force - min.
Operating position
Differential travel - max.
(831690/8)
N
N
mm
D
2.5
0.4
14.3±1.2
D
2.5
0.4
19.4±1.3
mm
1.2
1.2
actuators
Actuators
Fixing position
Operating position
Differential travel max.
(831690/8)
Roller 139 EX
R28.7*
70507524
79215742
Flat 161A
R14.2
A
2.5
0.5
15.1±1.2
0.8
Roller 161E
R13.6
R24.1
R25.4
B
4.5
1
15.2±0.6
0.4
A
1.4
0.25
14.5±2.4
B
2.5
0.5
15±1.2
1.6
0.8
70507528
79218651
Dummy roller 161F R22.2
Dummy roller 161G R21.8
N
N
mm
A
1.5
0.25
19.8±2.2
B
2.6
0.5
20.2±1.1
A
B
1.5 2.6
0.25 0.5
20.8±2.2 21.2±1.1
mm
1.6
0.8
1.6
70507529
C
3.5
0.6
15.2±0.9
0.6
A
2.5
0.5
20.4±1.2
B
4.5
1
20.5±0.6
A
1.4
0.25
19.7±2.4
B
2.5
0.5
20.1±1.2
C
3.5
0.6
20.3±0.9
0.8
0.4
1.6
0.8
0.6
0.8
Unless mentioned specifically, 161-type levers are supplied unassembled.
For factory mounting, specify mounting position A, B or C.
* 139-type levers are factory mounted.
Note: We recommend greasing the switch button lightly when fitting actuators.
V3S-83169 microswitches with referenced actuators
Actuators
831690 I D0.5
831698 I D0.5
161A R14.2
79215740
Pos A
Pos B
83169003 83169004
161A R25.4
Pos A
83169005
70507524
Pos B
83169006
161E R13.6
Pos C
83169007
79215742
Pos A
Pos B
83169008 83169009
83169819
139EX
R28.7
161E R24.1
Pos A
83169010
70507529
Pos B
83169011
Pos C
83169012
Installation recommendations
See “Basic technical concepts”
How to order
Use the 8 digit part numbers when they are defined
Other cases, precise: Type of microswitch - Function - Connection - UL approval* - Actuator* - Fixing position* - Adaptation*
* if needed
Example: 831690 R D1.50 UL 161E R24.1 B
Standard product
Contact us
Pos D
83169017
83169818
|| 5
| | microswitches
| | 07/2016
Examples of special adaptations
Long overtravel variant with
plastic plunger and reinforced
housing (SP4988)
Full wiring with custom connector
metal plunger (SP4978)
barrel and telescopic plunger:
see 83581
Double insulation model with
plastic plunger (SP4965)
很抱歉,暂时无法提供与“831699CR1.0”相匹配的价格&库存,您可以联系我们找货
