Series 34E: Sealed Surface Mount Toggle Switches
Series 34E
Models
in inches (and millimeters)
M6
.240
(6.10)
SPDT
.148
(3.78)
MODEL NO.
WMSP1
WMSP2
WMSP3
WMSP4
WMSP5
TERM. COMM.
SWITCH POSITION
NONE
ON
ON
NONE (ON)
ON
OFF
ON
ON
OFF
(ON)
(ON)
OFF
ON
(ON)
OPEN
2-3
2-1
EPOXY
SEAL
.020
(0.51)
.162
(4.11)
.320
(8.13)
.030
(0.76)
.100
(2.52)
.300
(7.62)
.410
(10.40)
.140
(3.56)
()=MOMENTARY
02COMM.
SCHEMATIC
.200
(5.08)
3
1
.100
(2.54)
.020
(0.62)
.150
(3.81)
.080
(2.03)
.290
(7.37)
.040
(1.02)
S6
.240
(6.10)
.315
(8.00)
SPDT
Ø.179
(Ø4.55)
SWITCH POSITION
NONE
ON
ON
NONE (ON)
ON
OFF
ON
ON
OFF
(ON)
(ON)
OFF
ON
(ON)
OPEN
2-3
2-1
MODEL NO.
WMSP1
WMSP2
WMSP3
WMSP4
WMSP5
TERM. COMM.
()=MOMENTARY
02COMM.
1
SCHEMATIC
EPOXY
SEAL
.162
(4.11)
.100
(2.52)
.323
(8.20)
.276
(7.00)
.100
(2.54)
.071
(1.80)
.280
(7.10)
.059
(1.50)
.366
(9.30)
.100
(2.54)
05COMM.
3 4
.080
(2.03)
6
.079
(2.00)
.032
(0.80)
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
DIP Switches
Toggle Switches
FEATURES
• Save Space and Weight
• SPDT Circuitry
• Choice of Actuators and Terminations
• Sealed per IP67
M7
Ø.100
(Ø2.54)
.640
(16.26)
.240
(6.10)
Ø.099
(Ø2.52)
.175
(4.46)
Ø.180
(Ø4.60)
.105
(2.70)
Toggle Switches
.080
(1.98)
SPDT
.030
(0.76)
.215
(5.50)
MODEL NO.
WMSP1
WMSP2
WMSP3
WMSP4
WMSP5
TERM. COMM.
SWITCH POSITION
ON
NONE
ON
NONE
ON
OFF
OFF
(ON)
OFF
ON
2-3
OPEN
()=MOMENTARY
1
.030
(0.76)
.561
(14.25)
.125
(3.18)
.221
(5.60)
ON
(ON)
ON
(ON)
(ON)
2-1
.120
(3.00)
.063
.079
(1.60)
(2.00)
.125
(3.18)
.100
(2.54)
.325
(8.27)
3
1
ACTUATOr OPTIONS
.020
(0.50)
.173
(4.39)
02COMM.
SCHEMATIC
.335
(8.51)
For S6, M7 Termination
Options Only
2
3
Ø.100
(Ø2.52)
ESD Resistant
Plastic Toggle
4
ESD Resistant
Plastic Toggle
Ø.100
(Ø2.52)
Ø.100
(Ø2.52)
Ø.100
(Ø2.52)
.425
(10.80)
.240
(6.10)
.264
(6.70)
.425
(10.80)
Termination OPTIONS
M6
S6
M7
TAPE AND REEL PACKAGING
For M6 Termination
Option Only
.260
(6.60)
.339
(8.60)
.472
(12.00)
.197
(5.00)
Ø.059
(Ø1.50)
.079
(2.00)
.157
(4.00)
.882
(22.40)
.039
(1.00)
1.118
(28.40)
Ø.059
(Ø1.50)
.016
(0.40)
DIP Switches
Toggle Switches
.618
(15.70)
.421
(10.7)
.071
(1.80)
1.260
(32.00)
.559
(14.20)
.630
(16.00)
30˚
.244
(6.20)
.291
(7.40)
For S6 Termination
Option Only
.819
(20.80)
.415
(10.55)
.331
(8.40)
.071
(1.80)
1.260
(32.00)
.157
(4.00)
.079
(2.00)
Ø.059
(Ø1.50)
.228
(5.80)
.014
(0.35)
.559
(12.40)
.453
(11.5)
.098
(2.50)
1.118
(28.40)
.248
(6.30)
.630
(16.00)
5˚
For M7 Termination
Option Only
.272
(6.90)
.071
(1.80)
.305
(7.75)
1.732
(44.00)
.157
(4.00)
Ø.063
(Ø1.60)
1.598
(40.)
.354
(9.00)
.394
(10.00)
.610
(15.50)
1.114
(28.30)
.386
(9.80)
.591
(15.00)
.504
(12.80)
.197
(5.00)
.014
(0.35)
.866
(22.00)
.634
(16.10)
.098
(2.50)
.252
(6.40)
.315
(8.00)
.236
(6.00)
Specifications
Ratings
Contact Rating: 0.4 VA max. @ 20V max.
(AC or DC)
Mechanical and Electrical Life: 30,000
make-and-break cycles at full load
Contact Resistance: 20 milliohms max. typ.
initial @ 2-4 VDC, 100 mA
Insulation Resistance: 1,000 megaohms
minimum
Dielectic Strength: 1,500 V RMS @ sea
level
Operating Temperature: -30°C to 85°C
MATERIALS
Case and Bushings: Glass-filled nylon 4/6,
flame retardant, heat stabilized (UL94V-0)
Actuator: Brass, chrome plated
Contacts: Copper alloy, gold plate over nickel
plate
Terminals: Copper alloy, tin plate over nickel
plate
Terminal Seal: Epoxy
Tape and Reel: 500 pcs/per reel
Ordering Information
Toggle Switches
Series 34E Sealed Surface Mount Toggle Switches
Model: SPDT: WMSP1, WMSP2, WMSP3, WMSP4, WMSP5
(See Model options.)
Actuator: 1, 2, 3, 4 (See Actuator options.)
Termination Options: M6, S6, M7 (See Termination options.)
34EWMSP12M6RT
RoHS Compliant
Contact: R = Copper alloy, gold plate over nickel plate
Available from your local Grayhill Component Distributor.
For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill.
很抱歉,暂时无法提供与“34EWMSP22M6RT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+78.34320
- 200+31.26600
- 500+30.21840
- 国内价格 香港价格
- 500+38.08517500+4.91605
