PANEL SWITCHES
SW
11
22
ZL series
ZL
Subminiature toggle switches • metal bushing
DISTINCTIVE FEATURES
Ø 4.83 mm threaded bushing
Solder lug and straight PC terminals
ENVIRONMENTAL SPECIFICATIONS
• Operating temperature : -30 °C to +85 °C (-22 °F to +185 °F)
• Moisture : 21 days 95 % (NFC 20-603 - IEC 8-2-3)
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- gold plated contacts : 0.4 VA 20 V max. AC or DC
- silver plated contacts : 0.5 A 48 V max. AC or DC
• Minimum load : 10 mA 50 mV - 10 µA 5 VDC
• Contact resistance : 20 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength: 1,000 Vrms 50 Hz min. between terminals and
frame, 500 Vrms 50 Hz min. between terminals
• Electrical life at full load :
Contacts
Number of cycles
2 positions
3 positions
Gold plated
60,000
30,000
Silver plated
20,000
10,000
GENERAL SPECIFICATIONS
• Strength of terminals : pull-out force 10 N max.
• Torque : 1 Nm max. applied between the 2 nuts
• Max. panel thickness : 1.5 mm (.059) with 2 nuts
The company reserves the right to change specifications without notice.
1
PANEL CUT-OUT
MATERIALS
• Case : thermoplastic UL94-V0
WITH FLAT
• Actuator : brass, nickel plated
Ø4.90
(.193 DIA)
• Bushing : zamac, tin plated
• Contacts and terminals :
0 : brass, gold plated (standard)
1 : brass, silver plated
3 : brass, gold plated (1.27 micron gold)
• Terminal seal : epoxy
TERMINALS
0.75
(.029)
3.30
(.129)
0.70
(.027)
Straight P0
ELECTRICAL FUNCTIONS
1
3
Function 1
2
Ø2.40
(.094 DIA)
6.10
(.240)
1 2 3
Other function
4.39
(.172)
Ø4.90
(.193 DIA)
4.50
(.177)
0.60
(.024)
• Wave soldering : 260 °C (500 °F) max. for 5 seconds max.
0.76
(.030)
Ø4.90
(.193 DIA)
• Hand soldering : 280 °C (536 °F) max. for 5 seconds max.
Solder lug S0
4.50
(.177)
4.39
(.172)
SOLDERING
1.50
(.059)
Ø4.90
(.193 DIA)
WITH KEYWAY
1.50
(.059)
PANEL SWITCHES
ZL series
Ø2.40
(.094 DIA)
6.10
(.240)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
ZL
NUMBER OF POLES
SERIES
3
Single pole
TERMINALS
1
ON
OFF
S0
Solder lug
6
ON
ON
P0
Straight PC
9
ON
OFF
ON
8
ON
OFF
MOM
2
ON
MOM
OPTIONS
CONTACT AND TERMINAL MATERIALS
BUSHINGS
Brass, gold plated
01
Threaded, with flat
1
Brass, silver plated
02
Threaded, with keyway
3
Brass, gold plated
(1.27 micron gold)
MODELS
00
Standard model
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Mounting accessories : Standard hardware supplied with all models : 2 hex nuts 7 mm (.275) across flats P/N U5731, 1 locking ring
P/N U5821 (with keyway) or U5831 (with flat) and 1 lockwasher P/N U5841.
3
PANEL SWITCHES
ZL series
III
Ø2.40
(.094 DIA)
ZL31S0
ON
OFF
ZL36S0
ON
ON
ZL39S0
ON
OFF
ON
ZL38S0
MOM
OFF
ON
ZL32S0
MOM
ON
Ø6.00
(.236 DIA)
0.50
(.019)
I
4.00 8.60
(.157) (.338)
II
EPOXY
3
1.50
(.059)
2.54
(.100)
2
1
0.50
(.019)
8.10
(.318)
5.00
(.196)
III
I
2.80
(.110)
Ø4.83-48UNS-2A
(10-48UNS-2A)
II
24
5.60 5.50
(.220) (.216)
FLAT
SOLDER LUG TERMINALS
4.39
(.172)
III
Ø2.40
(.094 DIA)
II
I
ZL31P0
ON
OFF
ZL36P0
ON
ON
ZL39P0
ON
OFF
ON
ZL38P0
MOM
OFF
ON
ZL32P0
MOM
ON
Ø6.00
(.236 DIA)
EPOXY
3 2 1
2.54
(.100)
0.50
(.019)
8.10
(.318)
Ø1.10
(.043 DIA)
5.00
(.196)
III
0.50
(.019)
(10-48UNS-2A)
I
3.30
(.129)
Ø4.83-48UNS-2A
II
24
8.60
5.60 5.50
(.338) (.220) (.216)
FLAT
STRAIGHT PC TERMINALS
2.54
(.100)
PANEL SWITCHES
ZL series
4.39
(.172)
Shown with threaded bushing code 01
CONTACT & TERMINAL
MATERIALS
BASIC P/N
3
00
Brass, gold plated (standard)
Brass, gold plated (1.27 micron gold)
BUSHINGS
BASIC P/N
01
02
4
Threaded, with flat
00
很抱歉,暂时无法提供与“ZL31S0001”相匹配的价格&库存,您可以联系我们找货
