34ASP21B1M6RT
34ASP21B1M6RT
    GRAYHILLINC.
    弯插
    钮子开关 单刀双掷 4万次 弯插 400mA 20V -30℃~+85℃
34ASP21B1M6RT 数据手册
Series 34A: Miniature Toggle Switches SERIES 34A Miniature Toggle Switches FEATURES • Save Space and Weight • SPDT, DPDT, 3PDT, and 4DPT Circuitry • Choice of Actuators, Bushings and Terminations • UL Recognized Toggle Switches MODELS in inches (and millimeters) SPDT .570 (14.48) MODEL NO. 3P1 3P2 3P3 3P4 3P5 TERM. COMM. 05COMM. 3 4 1 .650 (16.51) 1/4-40 UNS-2A .350 (8.89) Ø.115 (Ø 2.92) .410 (10.41) 08COMM. 6 .185 (4.70) 9 6 3 8 5 2 7 4 1 .190 (4.83) EPOXY SEAL .060 (1.52) 9 7 KEYWAY THIS SIDE .500 (12.7) ()=MOMENTARY 02COMM. .415 (10.54) KEYWAY SWITCH POSITION ON NONE ON ON NONE (ON) ON OFF ON OFF (ON) (ON) OFF (ON) ON 2-3,5-6 2-1,5-4 OPEN 8-9 8-7 .030 (0.76) SCHEMATIC DPDT MODEL NO. DP1 DP2 DP3 DP4 DP5 TERM. COMM. SWITCH POSITION NONE ON NONE ON OFF ON OFF (ON) OFF ON 2-3, OPEN 5-6 ON (ON) ON (ON) (ON) 2-1, 5-4 .410 (10.41) 05COMM. .450 (11.43) 1/4-40 UNS-2A 3 4 1 KEYWAY THIS SIDE .060 (1.52) .500 (12.7) ()=MOMENTARY 02COMM. .350 (8.89) KEYWAY .505 (12.83) 6 Ø.115 (Ø 2.92) .350 (8.89) 6 3 5 2 4 1 .190 (4.83) .185 (4.70) .030 (0.76) EPOXY SEAL SCHEMATIC .570 (14.48) 3PDT SWITCH POSITION ON NONE ON NONE ON OFF OFF (ON) OFF ON 2-3,5-6 TERM. COMM. OPEN 8-9 MODEL NO. 3P1 3P2 3P3 3P4 3P5 KEYWAY ON (ON) ON (ON) (ON) 2-1,5-4 8-7 1 05COMM. 3 4 08COMM. 6 7 KEYWAY THIS SIDE .500 (12.7) ()=MOMENTARY 02COMM. .415 (10.54) .030 (0.76) 9 .650 (16.51) 1/4-40 UNS-2A Ø.115 (Ø 2.92) .350 (8.89) .410 (10.41) .185 (4.70) 9 6 3 8 5 2 7 4 1 .190 (4.83) EPOXY SEAL .060 (1.52) SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34A: Miniature Toggle Switches MODELS in inches (and millimeters) 4PDT KEYWAY 05COMM. 3 4 08COMM. .415 (10.54) .850 (21.59) 1/4-40 UNS-2A .350 (8.89) .410 (10.41) Ø.115 (Ø 2.92) 011COMM. 9 10 6 7 KEYWAY THIS SIDE .500 (12.7) ()=MOMENTARY 02COMM. .030 (0.76) .185 (4.70) 12 9 6 3 11 8 5 2 10 7 4 1 .190 (4.83) EPOXY SEAL .060 (1.52) 12 SCHEMATIC ACTUATOR OPTIONS 1 Std 2 .115 DIA. (Ø3.01) 6 in inches (and millimeters) .410 (10.41) .107 DIA. (Ø2.71) .200 (5.08) 7 .487 (12.37) .134 DIA. (Ø3.40) .131 DIA. (Ø3.32) .550 (13.97) 9 .240 DIA. (Ø6.09) KEYWAY KEYWAY 15/32-32NS Use T7 Bushing Option only. .840 (21.32) .640 (16.26) Nylon Black .687 (17.45) 5 .131 (3.32) L THD. (STD.) N NON-THD L THD.(STD.) N NON-THD. Ø.129 (Ø3.28) .465 (11.80) .450 (11.43) Use with Bushing Options T1, T2, T5 and T6 only. 4 8 .240 DIA. (Ø6.09) .200 DIA. (Ø5.08) 3 Ø.214 (Ø5,44) .840 (21.34) .645 (16.38) .579 (14,73) LOCKED .640 (16,26) UNLOCKED .465 (11.80) .315 (8,00) L-Style 15/32-32NS Use T7 Bushing Option only. Use B1 & B2 bushing option only. Bushing dimension is .315 Actuators 1-5 shown with standard B1 bushing. Add .070 (1.78) for B3, subtract .020 (0.51) for B6 bushing. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP Switches Toggle Switches SWITCH POSITION ON NONE ON ON NONE (ON) ON OFF ON OFF (ON) (ON) OFF (ON) ON 2-3,5-6 2-1,5-4 TERM. COMM. 8-9,11-12 OPEN 8-7,11-10 MODEL NO. 4P1 4P2 4P3 4P4 4P5 1 .570 (14.48) SCALE:1.5:1 Series 34A: Miniature Toggle Switches BUSHING OPTIONS B1 B2 in inches (and millimeters) B3 B4 Thd (Std) Non-Thd .040 (1.02) Thd Non-Thd Ø.244 (Ø6.20) B5 Ø.244 (Ø6.20) .028 (0.71) .296 (7.52) 1/4-40 UNS-2A .028 (0.71) 1/4-40 UNS-2A 1/4-40 UNS-2A .315 (8.00) Toggle Switches .280 (7.10) B8 Long .020 (0.51) B9 Metric .225 (5.72) .040 (1.02) .020 (0.51) .040 (1.02) Splash-Proof .465 DIA. (Ø11.81) .040 (1.02) .225 (5.72) .028 (0.71) SEALS .296 (7.52) 1/4-40 UNS-2A M6P 0.75 THD. 1/4-40 UNS-2A .350 (8.89) .350 (8.89) T1 T2 Ø.314 (Ø7.98) .040 (1.02) Ø.314 (Ø7.98) .028 (0.71) .350 (8.89) B7 High Torque .225 (5.72) .040 (1.02) 1/4-40 UNS-2A B6 High Torque Thd (Std) Non-Thd T5 T6 .057 (1.44) .020 (0.51) .031 (0.79) T7 Thd (Std) Non-Thd *FOR USE WITH ACTUATORS .448 (11.38) 7 AND 8 ONLY. .065 (1.65) KEYWAY 15/32-32 UNS-2A PANEL MOUNTING .020 (0.51) in inches (and millimeters) Ø.250 (Ø6.35) Ø.094 (Ø2.38) Ø.250 (Ø6.35) 1/4" BUSHING .234 (5.95) .022 (0.56) .033 (0.85) Ø.496 (Ø11.91) Ø.150 (Ø3.81) Ø.078 (Ø1.98) Ø.250 (Ø6.35) .240 (6.10) Ø.250 (Ø6.35) .187 (4.75) Ø.496 (Ø11.91) .065 (1.65) 15/32" BUSHING .378 (9.60) Ø.250 (Ø6.35) METRIC BUSHING .031 (0.80) .028 (0.70) .031 (0.79) Ø.094 (Ø2.38) Ø.250 (Ø6.35) .248 (6.30) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34A: Miniature Toggle Switches TERMINATION OPTIONS M1 in inches (and millimeters) M2 Solder Lug (Std) P.C. Mount M3 P.C. Mount, Quick Connect WX DIM."A" EPOXY SEAL .078 (1.98) .156 (3.96) .189 (4.80) .189 (4.80) .250 (6.35) .250 (6.36) .050 1.27 OPTION CODE .050 (1.27) .062 (1.57) THK. .030 (0.76) THK. .030 (0.76) W1 W2 W3 W4 Right Angle P.C. Mount, Horizontal Actuation .500 (12.7) .185 (4.70) 1 SPDT .030 (0.76) SPDT .450 (11.43) .254 (6.46) .288 (7.31) .050 (1.27) .150 (3.81) .500 (12.7) .270 (6.86) DPDT 5 6 1 2 3 .500 (12.7) KEYWAY THIS SIDE .125 (3.18) .254 (6.46) .288 (7.31) P.C. MOUNTING .500 (12.7) .150 (3.81) 3 2 .500 (12.7) .048 (1.22) .030 (0.76) .150 (3.81) .500 (12.7) .500 (12.70) .288 (7.31) .150 (3.81) 1 .254 (6.46) Ø.245 (Ø6.22) .050 (1.27) .190 (4.83) 4 .185 (4.70) .200 (5.08) KEYWAY THIS SIDE Ø.245 (Ø6.22) .450 (11.43) .125 (3.17) Ø.073 (Ø1.85) .185 (4.70) .106 (2.69) .500 (12.7) .050 (1.27) P.C. MOUNTING .500 (12.7) Ø.105 (Ø2.67) .030 (0.76) Right Angle P.C. Mount, Vertical Actuation KEYWAY THIS SIDE Ø.245 (Ø6.22) DPDT M7 .050 (1.27) .288 (7.31) .500 (12.7) .126 (3.17) 2 3 .500 (12.7) .254 (6.46) .106 (2.69) .185 (4.69) .200 (5.08) .270 (6.86) Ø.105 (Ø2.67) .425(10.80) 1.062(26.97) Ø.073 (Ø1.85) Ø.245 (Ø6.22) .125 (3.17) .964(24.48) WIRE WRAP .030 (0.76) THK. M6 DIM."A" .750(19.05) .073 DIA. .200 (Ø1.85) (5.08) P.C. MOUNTING .200 (5.08) .150 (3.81) .125 (3.18) .030 (0.76) .150 (3.81) .190 (4.83) .500 (12.7) KEYWAY THIS SIDE 6 3 5 2 4 1 .048 (1.22) .200 (5.08) .200 (5.08) .073 DIA. (Ø1.85) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP Switches Toggle Switches .080 (2.03) .047 (1.19) .075 1.91 Series 34A: Miniature Toggle Switches TERMINATION OPTIONS M7 in inches (and millimeters) Right Angle P.C. Mount, Vertical Actuation .254 (6.46) Ø.245 (Ø6.22) .650 (16.51) KEYWAY THIS SIDE .125 9 (3.18) 8 7 .500 (12.7) 3PDT Toggle Switches .565 (14.35) .190 (4.83) 3 2 4 1 .200 (5.08) .030 (0.76) .254 (6.46) .125 (3.18) 4PDT 9 8 6 5 3 2 10 7 4 1 .050 (1.27) .150 (3.81) .500 12.7 .200 (5.08) .030 (0.76) .565 (14.35) .073 DIA. (Ø1.85) P.C. MOUNTING .190 (4.83) 12 11 .288 (7.31) .190 (4.83) .200 (5.08) .565 (14.35) KEYWAY THIS SIDE Ø.245 (Ø6.22) .190 (4.83) .048 (1.22) .150 (3.81) .850 (21.59) V2-V3 6 5 .288 (7.31) .050 (1.27) .150 (3.81) .565 (14.35) .048 (1.22) .150 (3.81) .200 (5.08) .073 DIA. (Ø1.85) P.C. MOUNTING Vertical Bracket P.C. Mount .280 (7.11) DIM. "A" SPDT OPTION DIM."A" CODE .185 (4.70) .254 (6.46) 1 .048 (1.22) .125 (3.18) 2 .185 (4.70) .125 (3.18) .073 DIA. (Ø1.85) P.C. MOUNTING OPTION DIM."A" CODE .020 (0.51) .254 (6.46) 4 5 6 V2 .460 (11,68) V3 .630 (16,00) .125 (3.18) .030 (0.76) .185 (4.70) .620 (15.75) .073 DIA. (Ø1.85) EPOXY SEAL .185 (4.70) .320 (8.13) .620 (15.75) .620 (15.75) .280 (7.11) .185 (4.70) .630 (16,00) EPOXY SEAL DPDT .048 (1.22) V3 .030 (0.76) DIM. "A" .450 (11.43) .460 (11,68) .185 (4.70) 3 .020 (0.51) .320 (8.13) V2 .125 (3.18) .190 (4.83) P.C. MOUNTING .620 (15.75) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34A: Miniature Toggle Switches SPECIFICATIONS RATINGS Contact Rating: Q option - 5A with resistive load @ 125VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 40,000 make-and-break cycles at full load UL Recognition: File number is E35289 Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA for both gold & silver contacts Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Toggle Handle: Brass, chrome-plated Bushing: Brass, nickle-plated Housing: Stainless steel DIP Switches Toggle Switches ORDERING INFORMATION 34ASP12B4M2RT Series 34A Miniature Toggle Switch Model: SPDT: SP1, SP2, SP3, SP4, SP5, DPDT: DP1, DP2, DP3, DP4, DP5 3PDT: 3P1, 3P2, 3P3, 3P4, 3P5 4PDT: 4P1, 4P2, 4P3, 4P4, 4P5 (See Model options) Actuator Options: 1, 2, 3, 4, 5, 6, 7, 8, 9, L, N (See Actuator options.) Bushing Options: B1, B2, B3, B4, B5, B6, B7, B8, B9, T1, T2, T5, T6 (See Bushing options.) RoHS Compliant Contact: R: Copper alloy, gold plate over nickel plate Q: Copper alloy, silver plated G: Copper alloy, gold plate over silver plate Termination Options: M1, M2, M3, M6, M7, V2, V3, W1, W2, W3 , W4 (See Termination options.) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. HARDWARE in inches (and millimeters) NUTS Series 34A (Std) ( Dress Nut ( ) ( ( ) ( ) ( ) ( ) ( ( ( ) For Actuator Options 7, 8 ) ( ) ( ) ( ) ) ( Series 34A (Std) ( For Actuator Options 7, 8 ( ) ) ( ) ( ) ) ) ( ( ) HDW5 ) ( ) ( ( ) LOCK WASHERS Series 34A (Std) ( ( HDW4 LOCKING RINGS ) ) ) HDW2 HDW3 ( Knurled Nut (Sealed) For Actuator Options 7, 8 (Std) ) ( ( ) ) HDW15 HDW16 HDW17 ( ) ) HDW11 HDW12 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
34ASP21B1M6RT 价格&库存
很抱歉,暂时无法提供与“34ASP21B1M6RT”相匹配的价格&库存,您可以联系我们找货
34ASP21B1M6RT
  • 20+48.85974
  • 60+42.64497
  • 100+36.90174
  • 500+31.53334
  • 1000+28.89750
库存:100
34ASP21B1M6RT
    • 10+77.8215910+10.06830
    • 60+61.1393060+7.91000
    • 100+52.84182100+6.83650
    库存:100
