34ASP12B4M6RT
34ASP12B4M6RT
    GRAYHILLINC.
    插件
    钮子开关 单刀双掷 4万次 直插 400mA 20V -30℃~+85℃
34ASP12B4M6RT 数据手册
Series 34A: Miniature Toggle Switches SERIES 34A Miniature Toggle Switches MODELS DIP Switches Toggle Switches FEATURES • Save Space and Weight • SPDT, DPDT, 3PDT, and 4DPT Circuitry • Choice of Actuators, Bushings and Terminations • UL Recognized In inches (and millimeters) SPDT MODEL NO. SP1 SP2 SP3 SP4 SP5 TERM. COMM. KEYWAY SWITCH POSITION NONE ON ON ON NONE (ON) OFF ON ON OFF (ON) (ON) OFF ON (ON) 2-1 2-3 OPEN .270 (6.86) .155 (3.94) .350 (8.89) .410 (10.41) 3 .500 (12.7) 2 1 1/4-40NS ()=MOMENTARY Ø.115 (Ø 2.92) 02COMM. SCHEMATIC .350 (8.89) .185 (4.70) EPOXY SEAL 3 1 .505 (12.83) DPDT MODEL NO. DP1 DP2 DP3 DP4 DP5 TERM. COMM. SWITCH POSITION NONE ON NONE ON OFF ON OFF (ON) OFF ON 2-3, OPEN 5-6 ON (ON) ON (ON) (ON) 2-1, 5-4 .500 (12.7) .450 (11.43) 05COMM. 3 4 KEYWAY THIS SIDE .060 (1.52) .410 (10.41) 1/4-40NS 1 .350 (8.89) KEYWAY ()=MOMENTARY 02COMM. KEYWAY THIS SIDE .030 (0.76) 6 Ø.115 (Ø 2.92) 6 3 5 2 4 1 .190 (4.83) .185 (4.70) .350 (8.89) .030 (0.76) EPOXY SEAL SCHEMATIC .570 (14.48) 3PDT SWITCH POSITION ON NONE ON NONE ON OFF OFF (ON) OFF ON 2-3,5-6 TERM. COMM. OPEN 8-9 MODEL NO. 3P1 3P2 3P3 3P4 3P5 1 05COMM. 3 4 08COMM. 6 7 KEYWAY THIS SIDE .500 (12.7) ()=MOMENTARY 02COMM. .415 (10.54) KEYWAY ON (ON) ON (ON) (ON) 2-1,5-4 8-7 .030 (0.76) 9 .650 (16.51) 1/4-40NS Ø.115 (Ø 2.92) .350 (8.89) .410 (10.41) .185 (4.70) 9 6 3 8 5 2 7 4 1 .190 (4.83) EPOXY SEAL .060 (1.52) SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com F-4 Series 34A: Miniature Toggle Switches MODELS In inches (and millimeters) 4PDT .570 (14.48) SCALE:1.5:1 SWITCH POSITION MODEL NO. ON ON NONE 4P1 ON NONE (ON) 4P2 ON ON OFF 4P3 (ON) (ON) OFF 4P4 ON (ON) OFF 4P5 2-3,5-6 2-1,5-4 TERM. COMM. 8-9,11-12 OPEN 8-7,11-10 KEYWAY Toggle Switches 1 05COMM. .500 (12.7) 08COMM. 3 4 6 7 KEYWAY THIS SIDE .415 (10.54) ()=MOMENTARY 02COMM. .030 (0.76) .850 (21.59) 1/4-40NS .350 (8.89) .410 (10.41) Ø.115 (Ø 2.92) 011COMM. 9 10 .185 (4.70) 12 9 6 3 11 8 5 2 10 7 4 1 .190 (4.83) EPOXY SEAL .060 (1.52) 12 SCHEMATIC ACTUATOR OPTIONS 1 Std .115 DIA. (Ø3.01) In inches (and millimeters) 2 .410 (10.41) 6 3 .107 DIA. (Ø2.71) .200 (5.08) 7 .487 (12.37) .550 (13.97) .240 DIA. (Ø6.09) 15/32-32NS .131 (3.32) Nylon Black .687 (17.45) .840 (21.32) .640 (16.26) 10 .100 (2.54) Ø.129 (Ø3.28) .465 (11.80) .450 (11.43) 5 .131 DIA. (Ø3.32) 9 KEYWAY KEYWAY With Bushing Options B1, B2, B5 only. .134 DIA. (Ø3.40) 8 .240 DIA. (Ø6.09) .200 DIA. (Ø5.08) 4 .840 (21.34) .645 (16.38) .450 (11.43) .465 (11.80) 15/32-32NS For 7, 8 Bushing Option code not required. All other actuator lengths shown with Bushing Option B1. Actuators 1-5 shown with standard B1 bushing. Add .070 (1.78) for B3, subtract .020 (0.51) for B6 bushing. F-5 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34A: Miniature Toggle Switches BUSHING OPTIONS B1 B2 In inches (and millimeters) B3 B4 Thd (Std) Non-Thd .040 (1.02) Thd Non-Thd .040 (1.02) Ø.244 (Ø6.20) B5 B6 High Torque High Torque .225 (5.72) Ø.244 (Ø6.20) Ø.314 (Ø7.98) .040 (1.02) Ø.314 (Ø7.98) .028 (0.71) .296 (7.52) 1/4-40NS .315 (8.00) .350 (8.89) B7 1/4-40NS 1/4-40NS 1/4-40NS .244 DIA. (Ø6.20) .020 (0.51) .280 (7.10) Long B8 Splash-Proof .040 (1.02) .315 DIA. (Ø8.00) .040 (1.02) .020 (0.51) .040 (1.02) B9 Metric .465 DIA. (Ø11.81) .225 (5.72) .028 (0.71) .225 (5.72) .296 (7.52) SEALS 1/4-40NS M6P 0.75 THD. 1/4-40NS .350 (8.89) .350 (8.89) PANEL MOUNTING DIP Switches Toggle Switches .028 (0.71) .028 (0.71) .020 (0.51) .057 (1.44) In inches (and millimeters) Ø.250 (Ø6.35) Ø.094 (Ø2.38) Ø.250 (Ø6.35) 1/4" BUSHING .234 (5.95) .022 (0.56) .033 (0.85) Ø.496 (Ø11.91) Ø.150 (Ø3.81) Ø.078 (Ø1.98) Ø.250 (Ø6.35) .240 (6.10) Ø.250 (Ø6.35) .187 (4.75) Ø.496 (Ø11.91) .065 (1.65) 15/32" BUSHING .378 (9.60) Ø.250 (Ø6.35) METRIC BUSHING .031 (0.80) .028 (0.70) .031 (0.79) Ø.094 (Ø2.38) Ø.250 (Ø6.35) .248 (6.30) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com F-6 Series 34A: Miniature Toggle Switches TERMINATION OPTIONS M1 In inches (and millimeters) Solder Lug (Std) M2 P.C. Mount M3 P.C. Mount, Quick Connect DIM."A" WX EPOXY SEAL .078 (1.98) .156 (3.96) .189 (4.80) .189 (4.80) .075 1.91 .250 (6.35) .250 (6.36) .080 (2.03) .047 (1.19) .050 1.27 OPTION CODE .050 (1.27) Toggle Switches .062 (1.57) THK. .030 (0.76) THK. .030 (0.76) W1 W2 W3 W4 .030 (0.76) THK. M6 Right Angle P.C. Mount, Horizontal Actuation .500 (12.7) .030 (0.76) .050 (1.27) .288 (7.31) .450 (11.43) .254 (6.46) .288 (7.31) .050 (1.27) .150 (3.81) .500 (12.7) .270 (6.86) SPDT .254 (6.46) .288 (7.31) .190 (4.83) F-7 2 3 .500 (12.7) KEYWAY THIS SIDE .150 (3.81) P.C. MOUNTING .500 (12.7) .150 (3.81) 3 2 1 .500 (12.7) .288 (7.31) .500 (12.7) .073 DIA. .200 (Ø1.85) (5.08) P.C. MOUNTING .200 (5.08) .150 (3.81) .030 (0.76) .150 (3.81) .190 (4.83) .500 (12.7) KEYWAY THIS SIDE .125 (3.18) .500 (12.70) .048 (1.22) .030 (0.76) .150 (3.81) .254 (6.46) Ø.245 (Ø6.22) .050 (1.27) DPDT 5 6 1 .125 (3.18) .450 (11.43) .125 (3.17) 4 .185 (4.70) .200 (5.08) KEYWAY THIS SIDE Ø.245 (Ø6.22) .500 (12.7) .050 (1.27) Ø.073 (Ø1.85) .185 (4.70) .106 (2.69) .030 (0.76) Right Angle P.C. Mount, Vertical Actuation P.C. MOUNTING .500 (12.7) Ø.105 (Ø2.67) DPDT M7 KEYWAY THIS SIDE Ø.245 (Ø6.22) .500 (12.7) .126 (3.17) 2 3 .500 (12.7) .254 (6.46) .106 (2.69) .185 (4.69) .185 (4.70) 1 SPDT .425(10.80) WIRE WRAP .200 (5.08) .270 (6.86) Ø.105 (Ø2.67) .964(24.48) 1.062(26.97) Ø.073 (Ø1.85) Ø.245 (Ø6.22) .125 (3.17) DIM."A" .750(19.05) 6 3 5 2 4 1 .048 (1.22) .200 (5.08) .200 (5.08) .073 DIA. (Ø1.85) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34A: Miniature Toggle Switches TERMINATION OPTIONS M7 In inches (and millimeters) Right Angle P.C. Mount, Vertical Actuation .254 (6.46) Ø.245 (Ø6.22) .650 (16.51) KEYWAY THIS SIDE .125 9 (3.18) 8 .500 (12.7) 3 2 4 1 .288 (7.31) .050 (1.27) .565 (14.35) .190 (4.83) .200 (5.08) .030 (0.76) .254 (6.46) .125 (3.18) 4PDT 12 11 9 8 6 5 3 2 10 7 4 1 .500 12.7 .200 (5.08) .030 (0.76) .565 (14.35) .150 (3.81) .190 (4.83) .288 (7.31) .050 (1.27) .073 DIA. (Ø1.85) P.C. MOUNTING .565 (14.35) KEYWAY THIS SIDE Ø.245 (Ø6.22) .190 (4.83) .200 (5.08) .048 (1.22) .150 (3.81) .850 (21.59) V2-V3 6 5 .190 (4.83) DIP Switches Toggle Switches 7 3PDT .150 (3.81) .565 (14.35) .048 (1.22) .150 (3.81) .200 (5.08) .073 DIA. (Ø1.85) P.C. MOUNTING Vertical Bracket P.C. Mount .280 (7.11) DIM. "A" SPDT OPTION DIM."A" CODE .185 (4.70) .254 (6.46) 1 .048 (1.22) .020 (0.51) .125 (3.18) .185 (4.70) .320 (8.13) 2 V3 .630 (16,00) .185 (4.70) .620 (15.75) 3 EPOXY SEAL .073 DIA. (Ø1.85) .030 (0.76) P.C. MOUNTING .620 (15.75) DIM. "A" OPTION DIM."A" CODE DPDT .450 (11.43) V2 .460 (11,68) .125 (3.18) .280 (7.11) .254 (6.46) 4 5 V2 .460 (11,68) V3 .630 (16,00) .125 (3.18) .620 (15.75) 6 .073 DIA. (Ø1.85) EPOXY SEAL .048 (1.22) .185 (4.70) .125 (3.18) .020 (0.51) .030 (0.76) .185 (4.70) .320 (8.13) .185 (4.70) .190 (4.83) P.C. MOUNTING .620 (15.75) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com F-8 Series 34A: Miniature Toggle Switches SPECIFICATIONS MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Toggle Handle: Brass, chrome-plated Bushing: Brass, nickle-plated Housing: Stainless steel Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C RATINGS Contact Rating: Q option - 5A with resistive load @ 125VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 40,000 make-and-break cycles at full load ORDERING INFORMATION Toggle Switches SERIES MODEL NO. ACTUATOR BUSHING TERMINATION CONTACT SEAL 34A SP1 2 B4 M2 R E 34A = Miniature Toggle Switches Options: SP1, SP2, SP3, SP4, SP5, DP1, DP2, DP3, DP4, DP5, 3P1, 3P2, 3P3, 3P4, 3P5, 4P1, 4P2, 4P3, 4P4, 4P5 (see models for switching positions) Options: 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 (see actuator options) Options: B1, B2, B3, B4, B5, B6, B7, B8, B9 (see bushing options) R = Copper alloy, gold plate over nickel plate. Options: M1, M2, M3, M6, M7, V2, V3 (see termination options) E = Epoxy seal Q = Copper alloy, Silver plated Example Part Number: 34ASP12B4M2RE Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. HARDWARE In inches (and millimeters) NUTS Series 34A (Std) ( Dress Nut ( ) ( ( ) ( ) ( ( ) ( HDW3 For Actuator Options 7, 8 ( ( ( ( ) ) ( ) ( ) ) ) ( Series 34A (Std) ( For Actuator Options 7, 8 ( ) ) ( ) ( ( F-9 ) ) ) ( HDW15 ) HDW5 ( ) ( ( ) LOCK WASHERS Series 34A (Std) ) ( HDW4 LOCKING RINGS ( ) ) ) HDW2 Knurled Nut (Sealed) For Actuator Options 7, 8 (Std) ) ( ) ( HDW16 ) ( ) ) ) HDW17 HDW11 HDW12 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
34ASP12B4M6RT 价格&库存
很抱歉,暂时无法提供与“34ASP12B4M6RT”相匹配的价格&库存,您可以联系我们找货
34ASP12B4M6RT
  • 100+41.66560
  • 500+35.48710
  • 1000+32.30716
库存:16
