34DWMSP15B4M2RT
34DWMSP15B4M2RT
    GRAYHILLINC.
    插件
    钮子开关 单刀双掷 3万次 直插 400mA 20V -30℃~+85℃
34DWMSP15B4M2RT 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34D: Sealed Sub-Miniature Toggle Switches Series 34D Sealed Sub-Miniature Toggle Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuators, Bushings, and Terminations • Sealed per IP67 Toggle Switches Models in inches (and millimeters) SPDT EPOXY SEAL Model No. Switching Position WMSP1 ON NONE ON WMSP2 ON NONE (ON) WMSP3 ON OFF ON 3 WMSP4 (ON) OFF (ON) 2 WMSP5 ON OFF (ON) OPEN 2-1 Term. Comm. 2-3 .185 (4.70) .416 (10.57) .148 (3.76) Ø.100 (Ø2.52) ()=MOMENTARY DPDT .130 (3.30) EPOXY SEAL .185 (4.70) WMDP1 ON NONE ON WMDP2 ON NONE (ON) WMDP3 ON OFF ON 5 WMDP4 (ON) OFF (ON) 4 ON OFF (ON) OPEN 2-1 5-4 .416 (10.57) .148 (3.76) Ø.100 (Ø2.52) .543 (13.80) .029 (0.75) 05COMM. 3 4 1 .100 (2.54) .130 (3.30) ()=MOMENTARY 02COMM. .364 (5.08) .320 (8.13) 6 Ø.180 (Ø4.58) .200 (5.08) .020 TYP. (0.51) Switching Position 2-3 5-6 .029 (0.75) .100 (2.54) .543 (13.80) Model No. Term. Comm. .320 (8.13) 3 1 WMDP5 .200 (5.08) 1 Ø.180 (Ø4.58) 02COMM. SCHEMATIC .020 TYP. (0.51) 6 SCHEMATIC ACTUATOr OPTIONS 1 2 in inches (and millimeters) 3 Std Ø.100 (Ø2.52) Ø.100 (Ø2.52) Ø.100 (Ø2.52) Ø.100 (Ø2.52) 5 ESD Resistant 4 Plastic Toggle ESD Resistant Plastic Toggle Ø.100 (Ø2.52) Ø.100 (Ø2.52) .264 (6.70) .240 (6.10) .421 (10.70) 6 .342 (8.70) .550 (13.97) .421 (10.70) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34D: Sealed Sub-Miniature Toggle Switches BUSHING OPTION in inches (and millimeters) B4 M1 EPOXY SEAL .059 (1,50) THK. .020 (0.51) Ø.180 (Ø4.57) Termination OPTIONS M2 in inches (and millimeters) .150 (3,80) .028 (0,70) .061 (1,55) P.C.MOUNT .130 (3.30) .100 (2.54) .030 (0.76) SINGLE POLE .020 (0.51) .240 (6.10) .015 (0.38) .030 (0.76) .200 (5.08) DPDT .200 (5.08) .165 (4.19) .200 (5.08) .200 (5.08) .320 (8.13) .030 (0.76) .200 (5.08) DOUBLE POLE .370 (9.40) EPOXY SEAL .159 (4.05) EPOXY SEAL .162 (4.11) Ø.043 (Ø1.09) .030 (0.76) .200 (5.08) P.C. MOUNT Right Angle P.C. Mount, Horizontal Actuation .240 (6.10) .130 (3.30) .200 (5.08) .142 (3.61) .031 (0.81) .016 (0.42) .163 (4.15) 4 .200 (5.08) 5 1 2 .100 (2.54) 3 .020 (0.51) Ø.100 (Ø2.52) .336 (8.53) SPDT .030 (0.76) 2 .240 (6.10) .019 (0.48) .031 (0.80) EPOXY SEAL .130 (3.30) .162 (4.11) .015 (0.38) .165 (4.19) .200 (5.08) .200 (5.08) 3 .200 (5.08) P.C. MOUNTING M7 Right Angle P.C. Mount, .236 (6.00) Vertical Actuation 1 .100 (2.54) .035 (0.90) 6 Ø.043 (Ø1.09) Ø.043 (Ø1.09) .150 (3,80) .100 P.C. MOUNTING (2.54) P.C. MOUNTING Ø.043 (Ø1.09) EPOXY SEAL .148 (3.78) .158 (4,00) M2 .130 (3.30) SPDT .110 (2,80) THK. .020 (0.51) DP SP .061 (1,55) M6 .039 (1,00) .530 (13.46) .100 (2.54) .200 (5.08) .100 (2.54) .320 (8.13) 3 2 1 P.C. MOUNTING .100 (2.54) Ø.043 (Ø1.09) .200 (5.08) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP Switches Toggle Switches .177 (4.50) EPOXY SEAL .110 (2,80) Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34D: Sealed Sub-Miniature Toggle Switches Termination OPTIONS in inches (and millimeters) Ø.194 (Ø4.91) M7 .391 (9.94) .019 (0.48) .240 (6.10) Ø.100 (Ø2.52) .364 (9.25) .130 (3.30) DPDT .162 (4.11) .336 (8.53) .320 (8.13) 6 3 5 2 4 1 .200 (5.08) .530 (13.46) .015 (0.38) .165 (4.19) Toggle Switches .030 (0.76) V2 P.C. MOUNTING .100 (2.54) Vertical Bracket P.C. Mount .230 (5.84) Ø.043 (Ø1.09) .200 (5.08) .200 (5.08) .200 (5.08) .100 (2.54) .240 (6.10) .240 (6.10) .165 (4.20) .165 (4.20) .130 (3.30) .366 (9.30) .130 (3.30) .366 (9.30) 1 .030 (0.76) .200 (5.08) Ø.043 (Ø1.09) 2 3 .020 (0.51) .100 (2.54) .030 (0.76) .015 (0.38) .100 (2.54) .400 (10.16) .400 (10.16) EPOXY SEAL SPDT 1 .400 (10.16) EPOXY SEAL .015 (0.38) .100 (2.54) .400 (10.16) P.C. MOUNTING DPDT P.C. MOUNTING .100 (2.54) .200 (5.08) Specifications Ratings Contact Rating: Q option - 3A with resistive load @ 125VAC or 28 VDC; 1.5A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 make-and-break cycles at full load 3 .020 (0.51) .200 (5.08) Ø.043 (Ø1.09) 2 Contact Resistance: 20 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,500 V RMS @ sea level Operating Temperature: -30°C to 85°C Ordering Information MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Toggle Handle: Brass, chrome plated Bushing: Brass, nickel plated Housing: Stainless steel Terminal/Switch Support: Brass, electrotin plated Contacts & Terminals: Copper alloy, gold plate over nickel plate or silver plate Terminal Seal: Epoxy Series 34B Sealed Sub-Miniature Toggle Switches Model: SPDT: WMSP1, WMSP2, WMSP3, WMSP4, WMSP5 DPDT: WMDP1, WMDP2, WMDP3, WMDP4, WMDP5 (See model no. for switching positions) Actuator: 1, 2, 3, 4, 5, 6 (See Actuator options) Bushing Option: B4 (See Bushing option) 34DWMSP12B4M2RT RoHS Compliant Contact: R = Copper alloy, gold plate over nickel plate, Q = Copper alloy, gold plate over silver plate Termination Options: M1, M2, M6, M7, V2 (See termination options) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
34DWMSP15B4M2RT 价格&库存
很抱歉,暂时无法提供与“34DWMSP15B4M2RT”相匹配的价格&库存,您可以联系我们找货
34DWMSP15B4M2RT
  • 30+32.02907
  • 75+31.46079
  • 100+29.65923
库存:170
34DWMSP15B4M2RT
    • 15+50.7746215+6.55400
    • 80+44.9092880+5.79690
    • 100+42.37055100+5.46920
    库存:170
    34DWMSP15B4M2RT
      • 1+89.27280
      • 200+35.61840
      • 500+34.43040
