34DWMSP22B4M6RT
34DWMSP22B4M6RT
    GRAYHILLINC.
    插件
    钮子开关 单刀双掷 3万次 直插 400mA 20V -30℃~+85℃
34DWMSP22B4M6RT 数据手册
Series 34D: Sealed Sub-Miniature Toggle Switches SERIES 34D Sealed Sub-Miniature Toggle Switches MODELS DIP Switches Toggle Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuators, Bushings, and Terminations • Sealed per IP67 In inches (and millimeters) SPDT EPOXY SEAL Model No. Switching Position WMSP1 ON NONE ON WMSP2 ON NONE (ON) WMSP3 ON OFF ON 3 WMSP4 (ON) OFF (ON) 2 WMSP5 ON OFF (ON) OPEN 2-1 Term. Comm. 2-3 .185 (4.70) .416 (10.57) .148 (3.76) .020 TYP. (0.51) .200 (5.08) .320 (8.13) 1 Ø.180 (Ø4.58) Ø.100 (Ø2.52) ()=MOMENTARY .029 (0.75) .100 (2.54) .543 (13.80) .130 (3.30) 02COMM. SCHEMATIC 3 1 DPDT EPOXY SEAL .185 (4.70) Switching Position WMDP1 ON NONE ON WMDP2 ON NONE (ON) WMDP3 ON OFF ON 5 WMDP4 (ON) OFF (ON) 4 ON OFF (ON) OPEN 2-1 5-4 WMDP5 Term. Comm. 2-3 5-6 .416 (10.57) .148 (3.76) .364 (5.08) 6 Ø.180 (Ø4.58) Ø.100 (Ø2.52) .543 (13.80) .320 (8.13) .100 (2.54) 05COMM. 3 4 1 .029 (0.75) .130 (3.30) ()=MOMENTARY 02COMM. .200 (5.08) .020 TYP. (0.51) Model No. 6 SCHEMATIC ACTUATOR OPTIONS 1 2 In inches (and millimeters) Std 3 5 Ø.100 (Ø2.52) Ø.100 (Ø2.52) Ø.100 (Ø2.52) Ø.100 (Ø2.52) 4 ESD Resistant Plastic Toggle ESD Resistant Plastic Toggle Ø.100 (Ø2.52) Ø.100 (Ø2.52) .264 (6.70) .240 (6.10) .421 (10.70) 6 .342 (8.70) .550 (13.97) .421 (10.70) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Toggle 18 Series 34D: Sealed Sub-Miniature Toggle Switches BUSHING OPTION In inches (and millimeters) B4 M1 .177 (4.50) EPOXY SEAL EPOXY SEAL .059 (1,50) THK. .020 (0.51) Ø.180 (Ø4.57) .110 (2,80) .039 (1,00) THK. .020 (0.51) DP SP .061 (1,55) Toggle Switches TERMINATION OPTIONS .028 (0,70) .061 (1,55) .130 (3.30) .100 (2.54) SINGLE POLE P.C.MOUNT .148 (3.78) .020 (0.51) .015 (0.38) .030 (0.76) .200 (5.08) .165 (4.19) .200 (5.08) DOUBLE POLE .370 (9.40) EPOXY SEAL .240 (6.10) .130 (3.30) .200 (5.08) .142 (3.61) .031 (0.81) .016 (0.42) .163 (4.15) 4 .200 (5.08) .320 (8.13) .030 (0.76) .200 (5.08) .159 (4.05) EPOXY SEAL .240 (6.10) Ø.043 (Ø1.09) .030 (0.76) .200 (5.08) P.C. MOUNT Right Angle P.C. Mount, Horizontal Actuation .162 (4.11) 5 .200 (5.08) 1 .200 (5.08) M7 2 3 .020 (0.51) Right Angle P.C. .236 Mount, (6.00) Vertical Actuation Ø.100 (Ø2.52) SPDT .030 (0.76) 1 2 .240 (6.10) .019 (0.48) .031 (0.80) EPOXY SEAL .130 (3.30) .162 (4.11) .015 (0.38) .165 (4.19) .200 (5.08) .200 (5.08) 3 .200 (5.08) P.C. MOUNTING .336 (8.53) Toggle 19 .100 (2.54) Ø.043 (Ø1.09) .100 (2.54) .035 (0.90) 6 Ø.043 (Ø1.09) DPDT .150 (3,80) .100 P.C. MOUNTING (2.54) P.C. MOUNTING Ø.043 (Ø1.09) .030 (0.76) SPDT .158 (4,00) M2 .130 (3.30) EPOXY SEAL M6 .150 (3,80) M2 In inches (and millimeters) .110 (2,80) .530 (13.46) .200 (5.08) .100 (2.54) .320 (8.13) P.C. MOUNTING .100 (2.54) 3 2 1 Ø.043 (Ø1.09) .200 (5.08) P.C. MOUNTING .100 (2.54) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34D: Sealed Sub-Miniature Toggle Switches TERMINATION OPTIONS In inches (and millimeters) Ø.194 (Ø4.91) M7 .019 (0.48) .240 (6.10) Ø.100 (Ø2.52) .391 (9.94) .364 (9.25) .130 (3.30) DPDT .320 (8.13) .162 (4.11) 3 5 2 4 1 .100 (2.54) .200 (5.08) .530 (13.46) .015 (0.38) .165 (4.19) .030 (0.76) V2 .200 (5.08) .200 (5.08) Ø.043 (Ø1.09) .200 (5.08) P.C. MOUNTING .100 (2.54) Vertical Bracket P.C. Mount .230 (5.84) .240 (6.10) .240 (6.10) .165 (4.20) .165 (4.20) .366 (9.30) .130 (3.30) .130 (3.30) .366 (9.30) 1 .030 (0.76) .200 (5.08) 2 3 EPOXY SEAL .015 (0.38) Ø.043 (Ø1.09) Ø.043 (Ø1.09) .400 (10.16) .100 (2.54) .400 (10.16) .015 (0.38) P.C. MOUNTING DPDT .200 (5.08) RATINGS Contact Rating: Q option - 3A with resistive load @ 125VAC or 28 VDC; 1.5A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 make-and-break cycles at full load EPOXY SEAL .400 (10.16) P.C. MOUNTING SPECIFICATIONS 3 .100 (2.54) .400 (10.16) SPDT 2 .020 (0.51) .200 (5.08) .020 (0.51) .100 (2.54) 1 .030 (0.76) Contact Resistance: 20 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,500 V RMS @ sea level Operating Temperature: -30°C to 85°C ORDERING INFORMATION .100 (2.54) MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Toggle Handle: Brass, chrome plated Bushing: Brass, nickel plated Housing: Stainless steel Terminal/Switch Support: Brass, electrotin plated Contacts & Terminals: Copper alloy, gold plate over nickel plate or silver plate Terminal Seal: Epoxy Series 34B Sealed Sub-Miniature Toggle Switches Model: SPDT: WMSP1, WMSP2, WMSP3, WMSP4, WMSP5 DPDT: WMDP1, WMDP2, WMDP3, WMDP4, WMDP5 (See model no. for switching positions) Actuator: 1, 2, 3, 4, 5, 6 (See Actuator options) Bushing Option: B4 (See Bushing option) 34DWMSP12B4M2RT RoHS Compliant Contact: R = Copper alloy, gold plate over nickel plate, Q = Copper alloy, gold plate over silver plate Termination Options: M1, M2, M6, M7, V2 (See termination options) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Toggle 20 DIP Switches Toggle Switches .336 (8.53) 6
34DWMSP22B4M6RT 价格&库存
很抱歉,暂时无法提供与“34DWMSP22B4M6RT”相匹配的价格&库存,您可以联系我们找货
