34CMDP13B2M6RT
34CMDP13B2M6RT
    GRAYHILLINC.
    插件
    钮子开关 双刀双掷 3万次 直插 400mA 20V -30℃~+85℃
34CMDP13B2M6RT 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34C: Sub-Miniature Toggle Switches Series 34C Sub-Miniature Toggle Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuators, Bushings, and Terminations • UL Recoginized Toggle Switches Models in inches (and millimeters) SPDT SWITCH POSITION NONE ON NONE ON OFF ON OFF (ON) OFF ON OPEN 2-3 MODEL NO. MSP1 MSP2 MSP3 MSP4 MSP5 TERM. COMM. .320 (8.13) ON (ON) ON (ON) (ON) 2-1 Ø.236 (Ø6.00) .173 (4.39) .200 (5.08) TERM. COMM. SWITCH POSITION ON NONE ON NONE ON OFF (ON) OFF ON OFF 2-3, OPEN 5-6 .320 (8.13) ON (ON) ON (ON) (ON) 2-1, 5-4 ()=MOMENTARY 02COMM. SCHEMATIC 1 ACTUATOr OPTIONS 1 Ø.236 (Ø6.00) .340 (8.64) .220 (5.59) .173 (4.39) .160 (4.06) .110 (2.79) .370 (9.40) .360 (9.14) .160 (4.06) .020 (0.51) 6 3 5 2 4 1 .060 (1.52) .100 (2.54) Ø.100 (Ø2.54) .340 (8.64) .160 (4.06) 6 in inches (and millimeters) 2 Ø.100 (Ø2.54) .370 (9.40) .100 (2.54) 05COMM. 3 4 3 2 1 3 DPDT MODEL NO. MDP1 MDP2 MDP3 MDP4 MDP5 .020 (0.51) .370 (9.40) Ø.100 (Ø2.54) 02COMM. 1 .110 (2.79) .060 (1.52) ()=MOMENTARY SCHEMATIC .220 (5.59) 3 .210 (5.33) Ø.100 (Ø2.54) 4 .290 (7.37) 5 Ø.100 (Ø2.54) Ø.100 (Ø2.54) .220 (5.59) Ø.100 (Ø2.54) .410 (10.41) Actuator options 1, 2 and 3 shown with B1 to B4 bushing, subtract 0.90 (2.29) for bushing B5, subtract 0.40 (1,02) for bushing B7. Actuators 4 and 5 shown with B5 and B6 bushing, add 0.90 (2.29) for bushing B1 to B3, add 0.50 (1,27) for bushing B7. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34C: Sub-Miniature Toggle Switches BUSHING OPTIONS B1 B2 in inches (and millimeters) Ø.236 (Ø6.00) Thd (Std) Non-Thd .220 (5.59) 10-48 UNS .173 FLAT (4.39) .310 (7.87) 1/4-40 UNS .225 FLAT (5.72) Panel MouNTing B7 B8 Thd (Std) Ø.280 Non-Thd (Ø7.10) .020 (0.51) Ø.195 (Ø4.95) Ø.195 (Ø4.95) WITH STD. LOCKING RING .160 (4.06) .160 (4.06) .060 (1.52) .030 (0.76) THK. .020 (0.51) M6 .028 (0.71) SP Ø.250 (Ø6.35) .234 (5.94) .033 (0.85) WITHOUT LOCKING RING M2 .110 (2.79) EPOXY SEAL EPOXY SEAL 1/4-40 UNS .020 (0.51) Ø.250 (Ø6.35) Ø.094 (Ø2.38) .022 (0.55) .240 (6.10) WITH STD. LOCKING RING in inches (and millimeters) Solder Lug .110 (2.79) Ø.250 (Ø6.35) .240 (6.10) Ø.094 (Ø2.38) Termination OPTIONS .060 (1.52) .260 (6.60) 1/4" Bushing Ø.195 (Ø4.95) WITHOUT LOCKING RING M1 .040 (1.02) in inches (and millimeters) .179 (4.55) .010 (0.25) .020 (0.51) .244 (6.20) 10-48 Bushing .023 (0.58) .220 (5.59) .030 (0.76) 10-48 UNS .015 (0.38) .020 (0.51) Ø.280 (Ø7.10) Thd (Std) Non-Thd Ø.236 (Ø6.00) Thd (Std) Non-Thd .030 (0.76) .060 (1.52) THK. .020 (0.51) dP .160 (4.06) P.C. Mount (Std) .130 (3.30) EPOXY SEAL .130 (3.30) EPOXY SEAL .030 (0.76) .200 (5.08) .030 (0.76) THK. .020 (0.51) SP THK. .020 (0.51) dP Right Angle P.C. Mount, Horizontal Actuation .320 (8.13) SPDT .220 (5.59) .194 (4.93) EPOXY SEAL .016 (0.41) .200 (5.08) .030 (0.7) .158 (4.01) .200 (5.08) 1 .030 (0.76) .200 (5.08) P.C. Mounting .020 (0.51) .130 (3.30) .100 (2.54) .020 (0.51) 2 .100 (2.54) 3 Ø.048 (Ø1.09) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP Switches Toggle Switches B5 B6 B3 B4 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34C: Sub-Miniature Toggle Switches Termination OPTIONS M6 .320 (8.13) DPDT in inches (and millimeters) .220 (5.59) .016 (0.41) .158 (4.01) .200 (5.08) Toggle Switches .030 (0.76) SPDT 2 6 .200 (5.08) .020 (0.51) .100 (2.54) .100 (2.54) .100 (2.54) EPOXY SEAL .200 (5.08) Ø.043 (Ø1.09) 3 .030 (0.76) P.C. MOUNTING .100 (2.54) .320 (8.13) .020 (0.51) 3 2 1 .220 (5.59) .030 (0.76) .016 (0.41) .158 (4.01) .194 (4.93) .200 (5.08) .200 (5.08) DPDT .130 (3.30) .030 (0.76) P.C. MOUNTING .360 (9.14) .320 (8.13) EPOXY SEAL 6 .200 (5.08) 2 4 1 Ø.043 (Ø1.09) .016 (0.41) .158 (4.01) .200 (5.08) .100 (2.54) 3 5 .220 (5.59) .030 (0.76) Ø.043 (Ø1.09) .200 (5.08) .100 (2.54) .020 (0.51) V2 5 .360 (9.14) 1 .194 (4.93) .200 (5.08) 4 .020 (0.51) .130 (3.30) .200 (5.08) M7 Right Angle P.C. Mount, Vertical Actuation EPOXY SEAL .194 (4.93) .200 (5.08) .130 (3.30) .200 (5.08) .100 (2.54) .200 (5.08) Vertical Bracket P.C. Mount .220 (5.59) .194 (4.93) .100 (2.54) P.C. MOUNTING .030 (0.76) V3 Vertical Bracket P.C. Mount .360 (9.14) .194 (4.93) .220 (5.59) .130 (3.30) .355 (9.02) 1 2 3 .020 (0.51) .030 (0.76) .200 (5.08) .100 (2.54) .016 (0.41) .400 (10.16) Ø.043 (Ø1.09) .400 (10.16) .100 (2.54) P.C. MOUNTING EPOXY SEAL .352 (8.94) .100 (2.54) .130 (3.30) 4 5 6 .020 (0.51) .100 (2.54) .200 (5.08) .100 (2.54) .100 (2.54) P.C. MOUNTING .016 (0.41) .400 (10.16) Ø.043 (Ø1.09) .400 (10.16) SPDT EPOXY SEAL DPDT .200 (5.08) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34C: Sub-Miniature Toggle Switches Specifications Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C UL Recognition: File number is E35289 MATERIALS Case: Diallyl phthalate (DAP) (UL 94V-0) Toggle Handle: Brass, chrome plated Bushing: Brass, nickel plated Housing: Stainless steel Terminal/Switch Support: Brass, electrotin plated Terminal Seal: Epoxy DIP Switches Toggle Switches Ratings Contact Rating: Q option - 3A with resistive load @ 125VAC or 28 VDC; 1.5A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 make-and-break cycles at full load Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Ordering Information Series 34C Sub-Miniature Toggle Switches Model: SPDT: MSP1, MSP2, MSP3, MSP4, MSP5 DPDT: MDP1, MDP2, MDP3, MDP4, MDP5 (See Model options.) 34CWSP12B4M2RT Actuator: 1, 2, 3, 4, 5 (See Actuator options.) Bushing Option: B1, B2, B3, B4, B5, B6, B7, B8 (See Bushing options.) RoHS Compliant Contact: R = Copper alloy, gold plate over nickel plate, Q = Copper alloy over silver plate Termination Options: M1, M2, M6, M7, V2, V3 (See Termination options.) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Hardware in inches (and millimeters) nut ( ) ( 10-48 UNS-2B ( ) lock washer ( ) ( ) ) HDW21 HDW22 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
34CMDP13B2M6RT 价格&库存
很抱歉,暂时无法提供与“34CMDP13B2M6RT”相匹配的价格&库存,您可以联系我们找货
34CMDP13B2M6RT
  • 25+44.72462
  • 55+43.86616
  • 100+41.41169
库存:145
34CMDP13B2M6RT
  • 500+58.50698500+7.56944
