34BWSP12B4M7RT
34BWSP12B4M7RT
    GRAYHILLINC.
    插件
    钮子开关 单刀双掷 5万次 直插 400mA 20V -30℃~+85℃
34BWSP12B4M7RT 数据手册
Series 34B: Sealed Miniature Toggle Switches SERIES 34B Sealed Miniature Toggle Switches MODELS In inches (and millimeters) SPDT Model No. Switching Position WSP1 ON NONE ON WSP2 ON NONE (ON) WSP3 ON OFF ON WSP4 (ON) OFF (ON) WSP5 ON OFF (ON) OPEN 2-1 Ø.220 Ø5.60 .250 (6.35) .050 (1.27) .250 (6.35) 3 Term. Comm. 2-3 ()=MOMENTARY .504 (12.8) 2 Ø.107 (Ø2.72) .268 (6.8) .297 (7.54) .030 (0.76) .663 (16.85) 1 .185 (4.7) EPOXY SEAL 02COMM. SCHEMATIC 3 1 DPDT Ø.220 (Ø5.60) Model No. Switching Position WDP1 ON NONE ON WDP2 ON NONE (ON) WDP3 ON OFF ON WDP4 (ON) OFF (ON) OFF (ON) OPEN 2-1 5-4 WDP5 ON Term. Comm. 2-3 5-6 .250 (6.35) .504 (12.8) .030 (0.76) Ø.107 (Ø2.72) .457 (11.6) .663 (16.85) .297 (7.54) .185 (4.7) 6 3 5 2 4 1 .190 (4.83) EPOXY SEAL ()=MOMENTARY 02COMM. .050 (1.27) .250 (6.35) 05COMM. SCHEMATIC 3 4 1 6 3PDT Ø.220 (Ø5.60) Model No. Switching Position W3P1 ON NONE ON W3P2 ON NONE (ON) W3P3 ON OFF ON W3P4 (ON) OFF (ON) OFF (ON) OPEN 2-1 5-4 W3P5 Term. Comm. ON 2-3 5-6 1 05COMM. 3 4 .250 (6.35) .030 (0.76) .500 (12.7) Ø.107 (Ø2.72) .650 (16.5) .297 (7.54) .722 (18.35) .050 (1.27) 9 6 3 8 5 2 7 4 1 .185 .190 (4.7) (4.83) EPOXY SEAL ()=MOMENTARY 02COMM. .250 (6.35) 08COMM. 6 7 9 SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Toggle 10 DIP Switches Toggle Switches FEATURES • Save Space and Weight • SPDT, DPDT, and 3PDT Circuitry • Choice of Actuators, Bushings and Terminations • Sealed per IP67 Series 34B: Sealed Miniature Toggle Switches ACTUATOR OPTIONS In inches (and millimeters) 1 2 Ø.115 (Ø2.92) Std Ø.107 (Ø2.72) .496 (12.60) .299 (7.60) SUBTRACT .083 (2.10) FOR BUSHING OPTION B1 SUBTRACT .079 (2.00) FOR BUSHING OPTION B1 Toggle Switches BUSHING OPTIONS In inches (and millimeters) B1 B4 Std .250 (6.35) .350 (8.90) 1/4-40 UNS TERMINATION OPTIONS In inches (and millimeters) M1 .078 (1.98) Solder Lug .156 (3.96) .106 (2.70) Ø.220 (Ø5.60) .050 (1.27) Ø.107 (Ø2.72) .663 (16.85) EPOXY SEAL .125 (3.18) .200 (5.08) .500 (12.7) Ø.220 (Ø5.60) Toggle 11 Ø.073 (Ø1.85) P.C. MOUNTING .185 (4.70) EPOXY SEAL Ø.107 (Ø2.72) .200 (5.08) .185 (4.70) .030 (0.76) .125 (3.18) .050 (1.26) .200 (5.08) .050 (1.26) .663 (16.85) DPDT .504 (12.8) .500 (12.7) 3 .050 (1.27) .297 (7.54) SPDT .106 (2.70) 2 THK. .030 (0.76) .185 (4.70) .030 (0.76) .185 (4.70) 1 .050 (1.26) .220 (5.60) .189 P.C. Mount (4.80) (Std) THK. .030 (0.76) Right Angle P.C. Mount, Horizontal Actuation .504 (12.8) EPOXY SEAL .080 (2.03) .047 (1.19) M6 M2 EPOXY SEAL .297 (7.54) 4 5 6 1 2 3 .500 (12.7) .050 (1.26) .500 (12.7) .050 (1.26) Ø.073 (Ø1.85) .150 (3.81) .200 (5.08) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 34B: Sealed Miniature Toggle Switches TERMINATION OPTIONS In inches (and millimeters) .720 (16.85) .504 (12.8) Ø.220 (Ø5.60) EPOXY SEAL Ø.107 (Ø2.72) .106 (2.70) .125 (3.18) 9 4 5 6 1 2 3 Ø.073 (Ø1.85) .050 (1.26) .200 (5.08) .050 (1.26) Right Angle P.C. Mount, Vertical Actuation EPOXY SEAL .663 (16.85) Ø.107 (Ø2.72) Ø.220 (Ø5.60) .150 (3.81) .500 (12.7) .050 (1.26) .150 (3.81) 3 .106 (2.70) .504 (12.8) SPDT .125 (3.18) .663 (16.85) Ø.107 (Ø2.72) 3 EPOXY SEAL 6 .125 (3.18) 4 5 .150 (3.81) .190 (4.83) .050 (1.26) .106 (2.70) .500 (12.7) 3 5 2 4 1 .030 (0.76) Ø.073 (Ø1.85) .200 (5.08) .190 (4.83) 6 P.C. MOUNTING .050 (1.26) .200 (5.08) .500 (12.7) .457 (11.6) .150 (3.81) EPOXY SEAL .720 (18.30) Ø.107 (Ø2.72) .650 (12.8) Ø.220 (Ø5.60) .125 (3.18) .500 (12.7) .297 (7.54) 7 8 .190 (4.83) 9 6 3 8 5 2 7 4 1 .190 (4.83) Ø.073 (Ø1.85) .200 (5.08) .048 (1.22) .565 (14.35) .565 (14.35) 9 .050 (1.27) V2-V3 Ø.073 (Ø1.85) .200 (5.08) .150 (3.81) .297 (7.54) 3PDT .030 (0.76) P.C. MOUNTING .500 (12.7) .200 (5.08) DPDT 2 1 .050 (1.26) .504 (12.8) 2 1 .297 (7.54) Ø.220 (Ø5.60) DIP Switches Toggle Switches 8 P.C. MOUNTING .565 (14.35) .200 (5.08) M7 7 .185 (4.70) .565 (14.35) .297 (7.54) .050 (1.26) 3PDT .185 (4.70) .030 (0.76) .200 (5.08) .150 (3.81) P.C. MOUNTING .150 (3.81) Vertical Bracket P.C. Mount Ø.107 (Ø2.72) SPDT .230 (5.84) OPTION DIM."A" CODE .297 (7.54) DIM. "A" 1 .048 (1.22) .320 (8.13) .125 (3.18) 2 V3 .630 (16,00) .185 (4.70) .620 (15.75) 3 .020 (0.51) .185 (4.70) V2 .460 (11,68) .125 (3.18) .030 (0.76) .620 (15.75) .073 DIA. (Ø1.85) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Toggle 12 Series 34B: Sealed Miniature Toggle Switches TERMINATION OPTIONS In inches (and millimeters) .230 (5.84) Ø.107 (Ø2.72) .125 (3.18) DIM. "A" DPDT .297 (7.54) 4 .048 (1.22) .125 (3.18) Toggle Switches .320 (8.13) .185 (4.70) OPTION DIM."A" CODE 5 6 V2 .460 (11,68) V3 .630 (16,00) .030 (0.76) .020 (0.51) .185 (4.70) Ø.073 (Ø1.85) .190 (4.83) P.C. MOUNTING .620 (15.75) Ø.073 (Ø1.85) .230 (5.84) Ø.107 (Ø2.72) .620 (15.75) .185 (4.70) DIM. "A" OPTION DIM."A" CODE .297 (7.54) 3PDT 4 .048 (1.22) .125 (3.18) .320 (8.13) 5 6 .030 (0.76) .020 (0.51) .185 (4.70) SPECIFICATIONS RATINGS Contact Rating: Q option - 5A with resistive load @ 125VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 50,000 make-and-break cycles at full load Contact Resistance: 10 milliohms max. V2 .460 (11,68) V3 .630 (16,00) .620 (15.75) .190 (4.83) P.C. MOUNTING .620 (15.75) initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,500 V RMS @ sea level Operating Temperature: -30°C to 85°C MATERIALS Case and Bushings: Glass-filled nylon 6/6, ORDERING INFORMATION flame retardant, heat stabilized (UL94V-0) Actuator: Brass, chrome plated. Internal Oring seal standard with all actuators. Frame: Spring steel Switch Support: Brass, tin-plated Actuator Pivot & Mounting Bracket: Nylon Actuator Pivot Retainer: Stainless Steel Terminal and Contacts: Copper alloy with plated over nickel or silver plate Terminal Seal: Epoxy Series 34B Sealed Miniature Toggle Switches Model: SPDT: WSP1, WSP2, WSP3, WSP4, WSP5 DPDT: WDP1, WDP2, WDP3, WDP4, WDP5 3PDT: W3P1, W3P2, W3P3, W3P4, W3P5 (See Model options.) Actuator: 1, 2 (See Actuator options) Bushing Option: B1, B4 (See Bushing options.) 34BWSP12B4M2RT RoHS Compliant Contact: R = Copper alloy, gold plate over nickel plate, Q = Copper alloy, gold plate over silver plate Termination Options: M1, M2, M6, M7, V2, V3 (See Termination options.) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. HARDWARE In inches (and millimeters) NUT Toggle 13 LOCKING RING ( ) ( ) ( LOCK WASHER ) ( ) ( ) ( ) ( ) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
34BWSP12B4M7RT 价格&库存
很抱歉,暂时无法提供与“34BWSP12B4M7RT”相匹配的价格&库存,您可以联系我们找货
34BWSP12B4M7RT
  • 1+71.881501+9.29979
