5238WWCDB16X445
5238WWCDB16X445
    APEM(埃斐)
    插件
    钮子开关 单刀双掷 5万次 直插 400mA 20V -40℃~+85℃
5238WWCDB16X445 数据手册
PANEL SWITCHES M 00 0 -5 9 20 -2 5000M series SW Miniature toggle switches • threaded bushing Ø 11.9 mm DISTINCTIVE FEATURES Bushing Ø 11.9 (15/32) Panel mounting and PCB terminal combination available 1 to 4 pole configurations UL and CSA approved ELECTRICAL SPECIFICATIONS • Current/voltage rating with resistive load : Contact Maximum Minimum Level* Silver (A) 4 A 30 VDC 50 mA 10 VDC III and IV Silver, gold plated (AD) 4 A 30 VDC Gold plating withstands up to 100 mA 30 VDC 10 mA 50 mV 10 µA 5 V I to IV Brass, gold plated (CD) 0.4 VA at 20 VAC or DC 10 mA 50 mV 10 µA 5 V I and II *For details, see Technical Information on website. • For inductive, lamp or capacitive load, consult factory. • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals 1,500 Vrms 50 Hz min. between poles 1,500 Vrms 50 Hz min. between terminals and frame • Contact bounce : 2 ms max. • Electrical life at full load : 50,000 cycles for single and double pole 40,000 cycles for 3 pole 30,000 cycles for 4 pole • Low level or mechanical life : 100,000 cycles GENERAL SPECIFICATIONS • Torque : 1.25 Nm (.922 Ft.lb) max. applied to nut • Panel thickness : up to 6 mm (.236) • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) The company reserves the right to change specifications without notice. 1 Miniature toggle switches • threaded bushing Ø 11.9 mm PANEL CUT-OUT MATERIALS • Case : diallylphthalate (DAP) or high temperature plastic material (UL94-V0) Ø12.50 (.492 DIA) Ø3.50 (.137 DIA) • Actuator : brass, nickel plated • Bushing : brass, nickel plated • Housing : stainless steel or steel tin plated • Contacts A : silver AD : silver, gold plated CD : brass, gold plated X814 : for peak currrents, see "Special options". 9.60 (.377) Standard Ø12.50 (.492 DIA) Ø3.50 (.137 DIA) AGENCY APPROVALS 9.60 (.377) 3 A 250 VAC, 6 A 125 VAC Availability : consult factory for details of approved models. Marking : to order switches marked UL or CSA, complete appropriate box of ordering format. The preferential list does not appear on the switches. ELECTRICAL FUNCTION KEYWAY 1 2 3 1.90 (.074) TERMINALS 1.10 (.043) 1.80 (.070) 2 Ø12.50 (.492 DIA) 1.70 (.066) • Terminal seal : epoxy 3.70 (.145) PANEL SWITCHES 5000M series 5.10 (.200) With K sealing option Ø12.50 (.492 DIA) Miniature toggle switches • threaded bushing Ø 11.9 mm BUILD YOUR PART NUMBER BASIC PART NUMBER 5 TERMINALS SERIES 2 6 NUMBER OF POLES Straight PC terminals, 4.70 (.185) terminal spacing - On request. 3 Single pole 4 Double pole 5 Three pole Solder lug terminals 6 Four pole TERMINALS M Solder lugs with Ø 11.9 (15/32) bushing ON 1R ON ON MOM 2R MOM ON MOM Leave blank for other functions. ELECTRICAL FUNCTIONS 6 MOMENTARY FOR FUNCTION 4 - ON 9 ON OFF ON 7 MOM OFF MOM CONNECTIONS FOR FUNCTION 4 8 ON OFF MOM 4 ON ON MOM ON ON ON ON MOM MOM TH Standard CT Reversed For functions 4, 4-1R, 4-2R (leave blank for all other functions). Wiring diagrams, see Technical information on website. Function 4 Must not have blank in «momentary» box. Wiring diagrams, see Technical information, on website. OPTIONS CONTACT MATERIALS A Silver AD Silver, gold plated CD Brass, gold plated FINISH Blank G Nickel plated Black finish on bushing, actuator and hardware. LEVERS SEALING Blank No sealing K Front panel sealing by one O-ring and sealing washer B Epoxy sealed terminals Blank (std) Length 17.5 (.688) -27 Length 11.7 (.460) AGENCY APPROVALS UL, CSA Availability : Consult factory for details of approved models. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : standard hardware supplied with all models : 2 hex nuts 14 mm (.551) across flats and 1 locking ring. Standard and special hardware is presented in the “Hardware“ section of website. 3 PANEL SWITCHES 5000M series Miniature toggle switches • threaded bushing Ø 11.9 mm Shown with standard lever KEYWAY 7.00 (.275) 11.00 (.433) MOM OFF MOM 5638M ON OFF MOM Ø11.9-32UNS (15/32-32UNS) KEYWAY 11.00 (.433) 12.00 (.472) ON 5647M MOM OFF MOM 5648M ON OFF MOM 5644 M* ON ON ON 5644M 1R* ON ON MOM 5644M 2R* MOM ON MOM 5 1 4 0.50 (.019) OFF 2 I II III 17.50 (.688) 11.90 (.468) 1.80 (.070) ON 6 3.70 (.145) 24˚ 5649M 3 Ø5.00 (.196 DIA) - I 1-2 4-5 ON 4.70 (.185) II 5646M III 2-3 5-6 ON 13.20 (.519) SOLDER LUG TERMINALS DOUBLE POLE 11.90 (.468) 4.75 (.187) 5637M 17.50 (.688) 0.80 (.031) ON III 1.80 (.070) OFF 24˚ ON II 1 Ø5.00 (.196 DIA) 5639M 2 4.70 (.185) I 1-2 ON 13.20 (.519) 5636M II - 0.50 (.019) I 3 III 2-3 ON 3.70 (.145) 0.80 (.031) SOLDER LUG TERMINALS SINGLE POLE Ø11.9-32UNS (15/32-32UNS) *Function 4 : DP in 4P case - specify CT or TH connections, see “Technical information“ on website. KEYWAY OFF MOM 4 III 17.50 (.688) 11.90 (.468) Ø11.9-32UNS (15/32-32UNS) KEYWAY 12.10 (.476) 21.20 (.834) 5667M MOM OFF MOM 5668M ON OFF MOM 5664 M* ON ON ON 5664M 1R* ON ON MOM 5664M 2R* MOM ON MOM 11 1 10 II III 17.50 (.688) 11.90 (.468) 4.75 (.187) ON 2 I 0.50 (.019) OFF 12 1.80 (.070) ON 3 3.70 (.145) 24˚ 5669M - I 1-2 4-5 7-8 10-11 ON 4.70 (.185) II Ø5.00 (.196 DIA) 5666M III 2-3 5-6 8-9 11-12 ON 4.75 (.187) ON II 0.50 (.019) 5658M 7 1.80 (.070) MOM 8 1 I 0.80 (.031) ON OFF 2 3.70 (.145) 24˚ OFF MOM 9 Ø5.00 (.196 DIA) ON 5657M 3 4.70 (.185) 5659M - I 1-2 4-5 7-8 ON 13.20 (.519) II 5656M III 2-3 5-6 8-9 ON SOLDER LUG TERMINALS FOUR POLE 12.10 (.476) 16.50 (.649) 0.80 (.031) SOLDER LUG TERMINALS THREE POLE 13.20 (.519) PANEL SWITCHES 5000M series Ø11.9-32UNS (15/32-32UNS) *Function 4 : DP in 4P case - specify CT or TH connections, see “Technical information“ on website. Miniature toggle switches • threaded bushing Ø 11.9 mm CONTACT MATERIAL BASIC P/N A AD CD Silver Silver, gold plated Brass, gold plated FINISH BASIC P/N Blank Nickel plated G Black finish on bushing, actuator and hardware SEALING BASIC P/N Blank No sealing required B Epoxy sealed terminals KB Combined sealings 1 O-ring 4 Maxi (.157 MAX) K Keyway bushing, Includes washer U60 Front panel sealing by one O-ring and sealing washer. Protects the switch against water and dust. Panel seal withstands 1 bar pressure and remains sealed even when switch is operated. 2 Sealing washer K Ø11.9 B LEVERS BASIC P/N Ø5.00 (.196 DIA) 11.90 (.468) 11.90 (.468) 11.70 (.460) 17.50 (.688) Ø5.00 (.196 DIA) Blank Standard -27 5 PANEL SWITCHES 5000M series PANEL SWITCHES 5000M series Miniature toggle switches • threaded bushing Ø 11.9 mm AGENCY APPROVALS BASIC P/N UL CSA Blank No agency approval required. Availability : consult factory for details of approved combinations or options. Marking : to order switches marked UL or CSA, complete above box with desired approvals, in this order & without space (ex. : ULCSA). 6
5238WWCDB16X445 价格&库存
很抱歉,暂时无法提供与“5238WWCDB16X445”相匹配的价格&库存,您可以联系我们找货
5238WWCDB16X445
  • 20+46.26018
库存:33
