PANEL SWITCHES
SW
11
17
SF
SF series
Washable miniature toggle switches •
insulated threaded bushing
DISTINCTIVE FEATURES
Process sealed
Front and rear sealing
Optional ESD protection
ENVIRONMENTAL SPECIFICATIONS
• Operating temperature : -20 °C to +85 °C (-4 °F to +185 °F)
• Storage temperature : -40 °C to +85 °C (-40 °F to +185 °F)
• Moisture : The insulating materials employed and the complete seal
permit the switches to withstand a 56 days moisture test (IEC 68-2-3).
• Solderability : The switches are tested at 235 °C (455 °F) according to
IEC 68-2-20 after accelerated aging.
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 4 A 30 VDC
- gold plated brass contacts (CD) : 0.4 VA 20 VAC or DC
- gold plated silver contacts (AD) : 4 A 30 VDC (300 mA 30 VDC for
gold plating)
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1,000 MΩ min.
• Dielectric strength : 1,000 Vrms 50 Hz min.
• Electrical life at full load :
Contacts
Number of cycles
2 positions
3 positions
A
40,000
40,000
CD
100,000
50,000
AD
40,000
40,000
The company reserves the right to change specifications without notice.
1
GENERAL SPECIFICATIONS
1.10
(.043)
• Max. torque : 0.25 Nm (.184 Ft.lb)
• Max. panel thickness : 2.5 mm (.098) with 2 nuts, 4 mm
(.157) with 1 nut
1.90
(.070)
Straight PC
MATERIALS
Solder lug / quickconnect
ELECTRICAL FUNCTIONS
• Case and cover : UL94-VO, polyamide, glass filled or PES
• Actuator : brass, nickel plated
KEYWAY
• Contacts
CD : brass, gold plated
A : silver
AD : silver, gold plated
• Terminal seal : epoxy
1
2
3
PANEL CUT-OUT
Ø6.50
(.255 DIA)
5.20
(.204)
2
1.10
(.043)
1.90
(.074)
• Iron soldering : 300 °C (572 °F) 5 sec. max.
2.45
(.096)
• Mechanical strength : Terminals are strengthened by a
bracket or a ground plate ensuring the rigidity of the switch
on the board. Actuator strength is 10 N max.
TERMINALS
4.15
(.163)
PANEL SWITCHES
SF series
Ø2.20
(.086 DIA)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
SF
NUMBER OF POLES
SERIES
3
TERMINALS
Single pole
6
ON
ON
S0
Solder lug terminals
9
ON
OFF
ON
P0
Staight PC terminals
7
MOM
OFF
MOM
8
ON
OFF
MOM
2
ON
MOM
OPTIONS
CONTACT AND TERMINAL
MATERIALS
Brass, gold plated
1
Silver
2
Silver, gold plated
5
Special contact,
lower rating
MODEL
LEVERS
00
Long
01
Short
00
Standard
INSULATING CAP
10
P/N U270
For lever 00 only
Insulated levers
08
Short
11
Long
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Mounting accessories : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware available is
presented in the "Accessories" section of website.
3
PANEL SWITCHES
SF series
Shown with standard lever 00
SOLDER LUGS TERMINALS
III II
Ø3.00
(.118 DIA)
ON
ON
SF39S0
ON
OFF
ON
SF37S0
MOM
OFF
MOM
SF38S0
ON
OFF
MOM
SF32S0
ON
MOM
10.70
(.421)
SF36S0
Ø6.35-40UNS
(1/4 40UNS)
8.90
(.350)
I
1-2
12.70
(.500)
6.60
(.259)
1
EPOXY
1.80
(.070)
10.80
(.425)
II
2
3
0.80
(.031)
2.45
(.096)
III
2-3
I
20˚
0.50
(.019)
4.70
(.185)
STRAIGHT PC TERMINALS
III II
Ø3.00
(.118 DIA)
ON
ON
SF39P0
ON
OFF
ON
SF37P0
MOM
OFF
MOM
SF38P0
ON
OFF
MOM
SF32P0
ON
MOM
10.70
(.421)
8.90
(.350)
SF36P0
Ø6.35-40UNS
(1/4 40UNS)
12.70
(.500)
6.60
(.259)
10.80
(.425)
I
1-2
1
EPOXY
0.80
(.031)
1.10
(.043)
Ø1.60
(.062)
2
3
0.50
(.019)
4.15
(.163)
II
I
20˚
4.70
(.185)
4.70
(.185)
III
2-3
CONTACT & TERMINAL
MATERIALS
00
BASIC P/N
2
5
Brass, gold plated (standard)
Silver
Silver, gold plated
Special contact, lower rating, minimum quantity : consult factory.
LEVERS
00
INSULATED LEVERS
5.40
(.212)
8.90
(.350)
11.50
(.452)
10.70
(.421)
00
Standard
01
Short
Ø2.90
(.114 DIA)
Ø2.90
(.114 DIA)
4.90
(.192)
Ø2.70
(.106 DIA)
8.90
(.350)
Ø3.00
(.118 DIA)
08
Short
8.90
(.350)
BASIC P/N
8.90
(.350)
PANEL SWITCHES
SF series
11
Long
Protected against electrostatic discharges (ESD) up to
12 KV. Black color.
4
INSULATING CAP
Blank Without caps
10
P/N U270 - For lever 00
For cap colors, replace "0" with number :
1
Blue
1/4
Dark blue
2
Black
3
Green
4
Grey
5
Yellow
6
Red
7/1
White
9
Orange
00
11.00
(.433)
BASIC P/N
Ø3.50
(.137 DIA)
10
To order cap separately, use its part number (U270).
5
PANEL SWITCHES
SF series
很抱歉,暂时无法提供与“SF39P000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+101.97360
- 200+40.69440
- 500+39.33360
