SF38P000000
SF38P000000
    APEM(埃斐)
    钮子开关 单刀双掷 5万次 面板安装 400mA 20V -20℃~+85℃
SF38P000000 数据手册
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page12 S and SF series Washable miniature toggle switches Distinctive features and specifications UG1410A ❑ Sealed • Secure assembly of the two case parts • Internally sealed bushing • Epoxy sealed terminals ❑ Process compatible (S series) A • Wave solderable • Washable ❑ Optional ESD protection ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A or 1) : 4A 30VDC - gold plated brass contacts (CD or 0) : 0,4VA 20VAC or DC - gold plated silver contacts (AD or 2) : 4A 30VDC (300mA 30VDC for gold plating) • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. • Dielectric strength : 1.000 Vrms 50 Hz min. • Electrical life at full load : Contacts A or 1 CD or 0 AD or 2 MATERIALS • Case and cover : UL94-VO, polyamide, glass filled or PES • Actuator : brass, nickel plated • Contacts CD or 0 : brass, gold plated A or 1 : silver AD or 2 : silver, gold plated • Terminal seal : epoxy Number of cycles 2 positions 3 positions 40.000 100.000 40.000 40.000 50.000 40.000 GENERAL SPECIFICATIONS • Mechanical strength : Terminals are strengthened by a bracket or a ground plate ensuring the rigidity of the switch on the board. Actuator strength is 10N max. • Operating temperature : -20°C to +85°C • Storage temperature : -40°C to +85°C • Moisture : The insulating materials employed and the complete seal permit the switches to withstand a 56 days moisture test (IEC 68-2-3). • Soldering - thermal shock (S series only) : The switches are especially designed for flow soldering at 260°C during 5 seconds owing to high temperature polymer parts. • Iron soldering (SF series) : 300°C 5 sec. max. • Solderability : The switches are tested at 235°C according to IEC 68-2-20 after accelerated aging. AGENCY APPROVALS 2A 250VAC 4A 125VAC CECC 96201-006 Availability : consult factory for details of approved models. Marking : to order switches marked UL or CECC, complete appropriate box of ordering format. The company reserves the right to change specifications without notice. A-12 www.apem.com APEM 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page13 S series Washable toggle switches - plain bushing Overview S Terminals SERIES W WW Y Bushing and terminals Right angle, horizontal mounting Right angle, vertical mounting Bracket mounting 2 0 Terminal spacing 4,7 (.185) or 3,81 (.150) Terminal spacing 5,08 (.200) (SW switches) Number of poles 3 4 Single pole Double pole Electrical functions 6 9 7 8 2 4TH ON ON MOM ON ON ON OFF OFF OFF ON ON ON MOM MOM MOM ON All models with plain bushing. Contact materials A AD CD Silver Silver, gold plated Brass, gold plated Levers -7 -13 Short Standard Long Insulated levers -11 Long -8 Short Approvals UL CECC Availability : Consult factory for details of approved models. Special options X601 Silver plated brass contacts X696 Higher bushing (for insulated levers) Insulating caps U270 U1710 For lever 13 For lever 7 ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as above Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Packaging unit : 50 or 25 pieces depending on model. APEM www.apem.com A-13 A 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page14 S series Washable toggle switches - plain bushing • Straight PC or right angle terminals • Terminal spacing 4,7 (.185) or 5,08 (.200) on SW switches • 1 and 2 pole configurations 1 A 2 3 MODEL STRUCTURE Shown with lever (-7) ON ON MOM ON ON ON ON OFF ON OFF MOM OFF MOM - MOM ON ON EPOXY 3 3.18 (.125) 2 1 4.70 (.185) 15.75 (.620) 12.70 (.500) 12.70 (.500) 3.81 (.150) 12.70 (.500) 3.18 (.125) Ø2.70 (.106 DIA) 0.40 (.015) 3.81 (.150) 3.81 (.150) 1.10 (.043) 4.75 (.187) 3.81 (.150) 5.08 (.200) Ø1.60 (.062 DIA) 8.20 (.322) 4.70 (.185) 11.35 (.446) 1.10 (.043) 15.75 (.620) Ø6.20 (.244) Ø1.60 (.062 DIA) 6.60 (.259) 5.90 (.232) 20˚ 12.70 (.500) 7.50 (.295) 0.40 (.015) 5.08 (.200) 6.10 7.50 (.240) (.295) 3.81 (.150) 3.10 (.122) 13.00 (.511) 0.90 (.035) 4.70 (.185) 4.70 (.185) SY246 SY249 SY247 SY248 SY242 SY244TH* Ø1.60 (.062 DIA) 15.75 (.620) SY236 SY239 SY237 SY238 SY232 I 2-1 4-5 4.40 (.173) Single pole Double pole II 2 3 EPOXY 5.30 (.208) Bracket mounting III 2-3 5-6 1 0.50 (.019) 4.75 (.187) 12.70 (.500) 11.35 (.446) ON OFF ON OFF MOM OFF MOM - MOM ON ON 11.65 (.458) 7.50 (.295) ON ON MOM ON ON ON Ø6.20 (.244 DIA) 4.70 (.185) 5.08 (.200) Ø2.70 (.106 DIA) 0.80 (.039) SWW246 SWW249 SWW247 SWW248** SWW242** SWW244TH* 20˚ 0.80 (.031) 4.70 (.185) I SWW236 SWW239 SWW237 SWW238 SWW232 III 2-1 4-5 1 II Single pole Double pole II 12.70 (.500) III I 2-3 5-6 2 0.50 (.019) 5.30 (.208) Right angle terminals - vertical 5.30 (.208) 11.70 (.460) 6.10 (.240) 12.70 (.500) 1.10 (.043) 3.90 (.153) 6.90 (.271) 3 EPOXY III ON OFF ON OFF MOM OFF MOM - MOM ON ON 20˚ Ø6.20 (.244 DIA) II ON ON MOM ON ON ON SW246 SW249 SW247 SW248 SW242 SW244TH* Ø2.70 (.106 DIA) I SW236 SW239 SW237 SW238 SW232 I 2-1 4-5 I Single pole Double pole II II III 2-3 5-6 5.08 (.200) III Right angle terminals - horizontal - spacing 4,7 (.185) 4.75 (.187) * Function 4 : SP in DP case - TH connection, see end of catalogue. ** Functions 2 and 8 : reversed connection available. Consult factory. A-14 www.apem.com APEM 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page15 S series Washable toggle switches - plain bushing 0.60 (.023) 5.08 (.200) Ø1.10 (.043 DIA) 5.08 (.200) 11.65 (.458) 5.08 (.200) A 12.70 (.500) 0.40 (.015) 7.50 (.295) 1 5.08 (.200) 3.81 (.150) 0.60 (.023) 2 12.70 (.500) 3.81 (.150) 6.90 (.271) 3 EPOXY 5.30 (.208) 0.60 (.023) 6.10 (.240) 3.90 (.153) 20˚ Ø6.20 (.244 DIA) 12.70 (.500) ON OFF ON OFF MOM OFF MOM - MOM ON ON 0.60 (.023) ON ON MOM ON ON ON Ø2.70 (.106 DIA) I SW046 SW049 SW047 SW048 SW042 SW044TH* I 2-1 4-5 II SW036 SW039 SW037 SW038 SW032 II III Single pole Double pole III 2-3 5-6 12.70 (.500) 5.08 (.200) Right angle terminals - horizontal - spacing 5,08 (.200) * Function 4 : SP in DP case, see end of catalogue. 2.00 (.078) 17.10 (.673) 13.00 (.511) 6.65 (.261) 11.65 (.458) 6.00 (.236) 6.90 (.271) 3.60 (.141) PCB MOUNTING CAP FOR PCB PROCESSING 16.00 (.629) Provide additional protection during PCB processing. Supplied mounted on the switch or separately. Material : vinyl U3012 APEM Ø4.76 (.187 DIA) www.apem.com A-15 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page16 S series Washable toggle switches - plain bushing CONTACT MATERIALS Silver Silver, gold plated Brass, gold plated A AD CD A LEVERS Dash compulsory before lever code. 13.30 (.523) 6.30 (.248) 7.50 (.295) 6.30 (.248) Ø3.00 (.118 DIA) Ø2.70 (.106) -7 -13 Standard Long If actuator not specified, we supply former default option -13. Insulated levers Protected against electrostatic discharges (ESD) up to 12 KV. Black colour. 13.00 (.511) 7.50 (.295) 6.80 (.267) 7.50 (.295) Ø2.90 (.114 DIA) Ø2.90 (.114 DIA) To combine with option X696. -8 -11 Short Long SPECIAL OPTIONS X601 Silver plated brass contacts Lower rating - Minimum quantity : 5.000 pieces per model and shipment. X696 Higher bushing 7,50 (.295). Compulsory for insulated levers 11 and 8. A-16 www.apem.com APEM 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page17 S series Washable toggle switches - plain bushing AGENCY APPROVALS UL CECC Availability : consult factory for details of approved models. A Marking : to order switches marked UL or CECC, please complete above box with desired approvals. Blank : no agency approval required. INSULATING CAPS Ø3.50 (.137 DIA) 7.30 (.287) 11.00 (.433) + U... U270 U1710 For lever 13 For lever 7 APEM Ø3.50 (.137 DIA) www.apem.com Cap colours Replace "0" by number 1 1/4 2 3 4 5 6 7/1 9 blue dark blue black green grey yellow red white orange A-17 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page18 SF series Washable toggle switches - insulated threaded bushing Overview SF SERIES A Number of poles 3 Single pole Contact and terminal materials 0 1 2 5 6 9 7 8 2 ON ON MOM ON ON OFF OFF OFF - Levers 00 01 Brass, gold plated Silver Silver, gold plated Special contact, lower rating Terminals Electrical functions Long Short ON ON MOM MOM MOM S0 P0 Solder lug terminals Straight PC terminals Model 00 Standard Insulating cap 10 P/N U270 For lever 00 only Insulated levers 08 Short 11 Long ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as above Specifications are at the beginning of the S series. Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. Mounting accessories : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher Standard and special hardware available are presented in section I. Packaging unit : 50 to 25 pieces depending on model. A-18 www.apem.com APEM 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page19 SF series Washable toggle switches - insulated threaded bushing 1 2 MODEL STRUCTURE 4.15 (.163) 1.90 (.070) 3 1.10 (.043) 1.90 (.074) • Single pole configurations • Max. torque : 0,25 Nm (.184 Ft.lb) • Iron soldering : 300°C max. 5 sec. max. • Max. panel thickness : 2,5 mm (.098) with 2 nuts 4 mm (.157) with 1 nut ➞ Keyway 2.45 (.096) Solder lug or straight PC terminals 1.10 (.043) 00 Shown with standard lever 00 12.70 (.500) 6.60 (.259) 1.80 (.070) 8.90 (.350) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 10.70 (.421) Ø6.35-40UNS (1/4 40UNS) EPOXY 0.80 (.031) 1 2 10.80 (.425) I 1-2 3 0.50 (.019) 4.70 (.185) ➞ Keyway SF36P0 SF39P0 SF37P0 SF38P0 SF32P0 I 1-2 Ø6.35-40UNS (1/4 40UNS) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 10.70 (.421) II I 20˚ 12.70 (.500) 6.60 (.259) 1.10 (.043) Ø1.60 (.062) 8.90 (.350) III 2-3 III II Ø3.00 (.118 DIA) EPOXY 4.70 (.185) Straight PC terminals : SF..P0 2.45 (.096) SF36S0 SF39S0 SF37S0 SF38S0 SF32S0 II I 20˚ 0.80 (.031) 1 2 3 0.50 (.019) 4.70 (.185) 10.80 (.425) III 2-3 III II Ø3.00 (.118 DIA) 4.15 (.163) ➞ Solder lugs : SF..S0 Keyway PANEL CUT-OUT Ø6.50 (.255 DIA) Ø2.20 (.086 DIA) 5.20 (.204) APEM www.apem.com A-19 A 04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page20 SF series Washable toggle switches - insulated threaded bushing CONTACT AND TERMINAL MATERIALS 00 LEVERS 00 Ø3.00 (.118 DIA) 8.90 (.350) 8.90 (.350) 10.70 (.421) 4.90 (.192) Ø2.70 (.106 DIA) 00 01 Standard Insulated levers Protected against electrostatic discharges (ESD) up to 12KV. Black colour. Ø2.90 (.114 DIA) 8.90 (.350) 5.40 (.212) 8.90 (.350) 11.50 (.452) Ø2.90 (.114 DIA) 08 11 Short Long INSULATING CAP Cap colours 00 Blank Without cap To order cap separately, use its part number (U270). 11.00 (.433) A Brass, gold plated (standard) Silver Silver, gold plated Special contact, lower rating, minimum quantity : consult factory. 0 1 2 5 Ø3.50 (.137 DIA) 10 P/N U270 - For lever 00 A-20 www.apem.com Replace "0" by number 1 1/4 2 3 4 5 6 7/1 9 blue dark blue black green grey yellow red white orange APEM
SF38P000000 价格&库存
很抱歉,暂时无法提供与“SF38P000000”相匹配的价格&库存,您可以联系我们找货
SF38P000000
    • 50+86.7258950+11.22031
