04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page12
S and SF series
Washable miniature toggle switches
Distinctive features and specifications
UG1410A
❑ Sealed
• Secure assembly of the two case parts
• Internally sealed bushing
• Epoxy sealed terminals
❑ Process compatible (S series)
A
• Wave solderable
• Washable
❑ Optional ESD protection
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (A or 1) : 4A 30VDC
- gold plated brass contacts (CD or 0) : 0,4VA 20VAC or DC
- gold plated silver contacts (AD or 2) : 4A 30VDC (300mA 30VDC for
gold plating)
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1.000 MΩ min.
• Dielectric strength : 1.000 Vrms 50 Hz min.
• Electrical life at full load :
Contacts
A or 1
CD or 0
AD or 2
MATERIALS
• Case and cover : UL94-VO,
polyamide, glass filled or PES
• Actuator : brass, nickel plated
• Contacts
CD or 0 : brass, gold plated
A or 1 : silver
AD or 2 : silver, gold plated
• Terminal seal : epoxy
Number of cycles
2 positions
3 positions
40.000
100.000
40.000
40.000
50.000
40.000
GENERAL SPECIFICATIONS
• Mechanical strength :
Terminals are strengthened by a bracket or a ground plate ensuring the rigidity of the switch on the board.
Actuator strength is 10N max.
• Operating temperature : -20°C to +85°C
• Storage temperature : -40°C to +85°C
• Moisture :
The insulating materials employed and the complete seal permit the switches to withstand a 56 days moisture test
(IEC 68-2-3).
• Soldering - thermal shock (S series only) :
The switches are especially designed for flow soldering at 260°C during 5 seconds owing to high temperature
polymer parts.
• Iron soldering (SF series) : 300°C 5 sec. max.
• Solderability : The switches are tested at 235°C according to IEC 68-2-20 after accelerated aging.
AGENCY APPROVALS
2A 250VAC
4A 125VAC
CECC 96201-006
Availability : consult factory for details of approved models.
Marking : to order switches marked UL or CECC, complete appropriate box
of ordering format.
The company reserves the right to change specifications without notice.
A-12
www.apem.com
APEM
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page13
S series
Washable toggle switches - plain bushing
Overview
S
Terminals
SERIES
W
WW
Y
Bushing and terminals
Right angle,
horizontal
mounting
Right angle,
vertical mounting
Bracket mounting
2
Terminal spacing
4,7 (.185) or 3,81
(.150)
Terminal spacing
5,08 (.200)
(SW switches)
Number of poles
3
4
Single pole
Double pole
Electrical functions
6
9
7
8
2
4TH
ON
ON
MOM
ON
ON
ON
OFF
OFF
OFF
ON
ON
ON
MOM
MOM
MOM
ON
All models with plain bushing.
Contact materials
A
AD
CD
Silver
Silver, gold plated
Brass, gold plated
Levers
-7
-13
Short
Standard
Long
Insulated levers
-11 Long
-8
Short
Approvals
UL
CECC
Availability :
Consult factory for
details of approved
models.
Special options
X601 Silver plated
brass contacts
X696 Higher bushing
(for insulated
levers)
Insulating caps
U270
U1710
For lever 13
For lever 7
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- options in the same order as above
Dimensions : first dimensions are in mm while inches are shown as bracketted numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
Packaging unit : 50 or 25 pieces depending on model.
APEM
www.apem.com
A-13
A
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page14
S series
• Straight PC or right angle terminals
• Terminal spacing 4,7 (.185) or 5,08 (.200)
on SW switches
• 1 and 2 pole configurations
1
A
2
3
MODEL
STRUCTURE
Shown with lever (-7)
ON
ON
MOM
ON
ON
ON
ON
OFF ON
OFF MOM
OFF MOM
- MOM
ON ON
EPOXY
3
3.18
(.125)
2
1
4.70
(.185)
15.75
(.620)
12.70
(.500)
12.70
(.500)
3.81
(.150)
12.70
(.500)
3.18
(.125)
Ø2.70
(.106 DIA)
0.40
(.015)
3.81
(.150)
3.81
(.150)
1.10
(.043)
4.75
(.187)
3.81
(.150)
5.08
(.200)
Ø1.60
(.062 DIA)
8.20
(.322)
4.70
(.185)
11.35
(.446)
1.10
(.043)
15.75
(.620)
Ø6.20
(.244)
Ø1.60
(.062 DIA)
6.60
(.259)
5.90
(.232)
20˚
12.70
(.500)
7.50
(.295)
0.40
(.015)
5.08
(.200)
6.10 7.50
(.240) (.295)
3.81
(.150)
3.10
(.122)
13.00
(.511)
0.90
(.035)
4.70
(.185)
4.70
(.185)
SY246
SY249
SY247
SY248
SY242
SY244TH*
Ø1.60
(.062 DIA)
15.75
(.620)
SY236
SY239
SY237
SY238
SY232
I
2-1
4-5
4.40
(.173)
Single pole Double pole
II
2
3
EPOXY
5.30
(.208)
Bracket mounting
III
2-3
5-6
1
0.50
(.019)
4.75
(.187)
12.70
(.500)
11.35
(.446)
ON
OFF ON
OFF MOM
OFF MOM
- MOM
ON ON
11.65
(.458)
7.50
(.295)
ON
ON
MOM
ON
ON
ON
Ø6.20
(.244 DIA)
4.70
(.185)
5.08
(.200)
Ø2.70
(.106 DIA)
0.80
(.039)
SWW246
SWW249
SWW247
SWW248**
SWW242**
SWW244TH*
20˚
0.80
(.031)
4.70
(.185)
I
SWW236
SWW239
SWW237
SWW238
SWW232
III
2-1
4-5
1
II
II
12.70
(.500)
III
I
2-3
5-6
2
0.50
(.019)
5.30
(.208)
Right angle terminals - vertical
5.30
(.208)
11.70
(.460)
6.10
(.240)
12.70
(.500)
1.10
(.043)
3.90
(.153)
6.90
(.271)
3
EPOXY
III
ON
OFF ON
OFF MOM
OFF MOM
- MOM
ON ON
20˚
Ø6.20
(.244 DIA)
II
ON
ON
MOM
ON
ON
ON
SW246
SW249
SW247
SW248
SW242
SW244TH*
Ø2.70
(.106 DIA)
I
SW236
SW239
SW237
SW238
SW232
I
2-1
4-5
I
II
II
III
2-3
5-6
5.08
(.200)
III
Right angle terminals - horizontal - spacing 4,7 (.185)
4.75
(.187)
* Function 4 : SP in DP case - TH connection, see end of catalogue.
** Functions 2 and 8 : reversed connection available. Consult factory.
A-14
www.apem.com
APEM
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page15
S series
0.60
(.023)
5.08
(.200)
Ø1.10
(.043 DIA)
5.08
(.200)
11.65
(.458)
5.08
(.200)
A
12.70
(.500)
0.40
(.015)
7.50
(.295)
1
5.08
(.200)
3.81
(.150)
0.60
(.023)
2
12.70
(.500)
3.81
(.150)
6.90
(.271)
3
EPOXY
5.30
(.208)
0.60
(.023)
6.10
(.240)
3.90
(.153)
20˚
Ø6.20
(.244 DIA)
12.70
(.500)
ON
OFF ON
OFF MOM
OFF MOM
- MOM
ON ON
0.60
(.023)
ON
ON
MOM
ON
ON
ON
Ø2.70
(.106 DIA)
I
SW046
SW049
SW047
SW048
SW042
SW044TH*
I
2-1
4-5
II
SW036
SW039
SW037
SW038
SW032
II
III
III
2-3
5-6
12.70
(.500)
5.08
(.200)
Right angle terminals - horizontal - spacing 5,08 (.200)
* Function 4 : SP in DP case, see end of catalogue.
2.00
(.078)
17.10
(.673)
13.00
(.511)
6.65
(.261)
11.65
(.458)
6.00
(.236)
6.90
(.271)
3.60
(.141)
PCB MOUNTING
CAP FOR PCB PROCESSING
16.00
(.629)
Provide additional protection during PCB processing.
Supplied mounted on the switch or separately.
Material : vinyl
U3012
APEM
Ø4.76
(.187 DIA)
www.apem.com
A-15
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page16
S series
CONTACT MATERIALS
Silver
Silver, gold plated
Brass, gold plated
A
AD
CD
A
LEVERS
Dash compulsory before lever code.
13.30
(.523)
6.30
(.248)
7.50
(.295)
6.30
(.248)
Ø3.00
(.118 DIA)
Ø2.70
(.106)
-7
-13
Standard
Long
If actuator not specified, we
supply former default option -13.
Insulated levers
Protected against electrostatic discharges (ESD) up to 12 KV. Black colour.
13.00
(.511)
7.50
(.295)
6.80
(.267)
7.50
(.295)
Ø2.90
(.114 DIA)
Ø2.90
(.114 DIA)
To combine with option X696.
-8
-11
Short
Long
SPECIAL OPTIONS
X601
Silver plated brass contacts
Lower rating - Minimum quantity : 5.000 pieces per model and shipment.
X696
Higher bushing 7,50 (.295). Compulsory for insulated levers 11 and 8.
A-16
www.apem.com
APEM
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page17
S series
AGENCY APPROVALS
UL
CECC
A
Marking : to order switches marked UL or CECC, please complete above box with desired approvals.
Blank : no agency approval required.
INSULATING CAPS
Ø3.50
(.137 DIA)
7.30
(.287)
11.00
(.433)
+ U...
U270
U1710
For lever 13
For lever 7
APEM
Ø3.50
(.137 DIA)
www.apem.com
Cap colours
Replace "0" by
number
1
1/4
2
3
4
5
6
7/1
9
blue
dark blue
black
green
grey
yellow
red
white
orange
A-17
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page18
SF series
Washable toggle switches - insulated threaded bushing
Overview
SF
SERIES
A
Number of poles
3
Single pole
Contact and terminal
materials
2
5
6
9
7
8
2
ON
ON
MOM
ON
ON
OFF
OFF
OFF
Levers
00
01
Brass, gold plated
Silver
Silver, gold plated
Special contact,
lower rating
Terminals
Long
Short
ON
ON
MOM
MOM
MOM
S0
P0
Solder lug terminals
Straight PC terminals
Model
00
Standard
Insulating cap
10
P/N U270
For lever 00 only
Insulated levers
08 Short
11 Long
ABOUT THIS SERIES
Specifications are at the beginning of the S series.
Mounting accessories : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher
Standard and special hardware available are presented in section I.
Packaging unit : 50 to 25 pieces depending on model.
A-18
www.apem.com
APEM
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page19
SF series
1
2
MODEL
STRUCTURE
4.15
(.163)
1.90
(.070)
3
1.10
(.043)
1.90
(.074)
• Single pole configurations
• Max. torque : 0,25 Nm (.184 Ft.lb)
• Iron soldering : 300°C max. 5 sec. max.
• Max. panel thickness :
2,5 mm (.098) with 2 nuts
4 mm (.157) with 1 nut
➞ Keyway
2.45
(.096)
Solder lug or straight PC terminals
1.10
(.043)
00
Shown with standard lever 00
12.70
(.500)
6.60
(.259)
1.80
(.070)
8.90
(.350)
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
ON
- MOM
10.70
(.421)
Ø6.35-40UNS
(1/4 40UNS)
EPOXY
0.80
(.031)
1
2
10.80
(.425)
I
1-2
3
0.50
(.019)
4.70
(.185)
➞ Keyway
SF36P0
SF39P0
SF37P0
SF38P0
SF32P0
I
1-2
Ø6.35-40UNS
(1/4 40UNS)
ON
ON
ON OFF ON
MOM OFF MOM
ON OFF MOM
ON
- MOM
10.70
(.421)
II
I
20˚
12.70
(.500)
6.60
(.259)
1.10
(.043)
Ø1.60
(.062)
8.90
(.350)
III
2-3
III II
Ø3.00
(.118 DIA)
EPOXY
4.70
(.185)
Straight PC terminals : SF..P0
2.45
(.096)
SF36S0
SF39S0
SF37S0
SF38S0
SF32S0
II
I
20˚
0.80
(.031)
1
2
3
0.50
(.019)
4.70
(.185)
10.80
(.425)
III
2-3
III II
Ø3.00
(.118 DIA)
4.15
(.163)
Solder lugs : SF..S0
Keyway
PANEL CUT-OUT
Ø6.50
(.255 DIA)
Ø2.20
(.086 DIA)
5.20
(.204)
APEM
www.apem.com
A-19
A
04-Serie S-SF-A_04-Serie S-SF-A 30/10/14 14:55 Page20
SF series
CONTACT AND TERMINAL MATERIALS
00
LEVERS
00
Ø3.00
(.118 DIA)
8.90
(.350)
8.90
(.350)
10.70
(.421)
4.90
(.192)
Ø2.70
(.106 DIA)
00
01
Standard
Insulated levers
Protected against electrostatic discharges (ESD) up to 12KV. Black colour.
Ø2.90
(.114 DIA)
8.90
(.350)
5.40
(.212)
8.90
(.350)
11.50
(.452)
Ø2.90
(.114 DIA)
08
11
Short
Long
INSULATING CAP
Cap colours
00
Blank
Without cap
To order cap separately, use its part
number (U270).
11.00
(.433)
A
Brass, gold plated (standard)
Silver
Silver, gold plated
Special contact, lower rating, minimum quantity : consult factory.
2
5
Ø3.50
(.137 DIA)
10
P/N U270 - For lever 00
A-20
www.apem.com
Replace "0" by
number
1
1/4
2
3
4
5
6
7/1
9
blue
dark blue
black
green
grey
yellow
red
white
orange
APEM
很抱歉,暂时无法提供与“SF32S00000016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+157.30200
- 200+62.76960
- 500+60.67440
- 国内价格
- 20+56.11435
- 40+55.05034
- 50+51.94295
