ZL36W0000
ZL36W0000
    APEM(埃斐)
    插件
    钮子开关 单刀双掷 6万次 直插 400mA 20V -30℃~+85℃
ZL36W0000 数据手册
- PANEL SWITCHES SW 11 22 ZL series ZL Subminiature toggle switches • metal bushing DISTINCTIVE FEATURES Ø 4.83 mm threaded bushing Solder lug and straight PC terminals ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -30 °C to +85 °C (-22 °F to +185 °F) • Moisture : 21 days 95 % (NFC 20-603 - IEC 8-2-3) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - gold plated contacts : 0.4 VA 20 V max. AC or DC - silver plated contacts : 0.5 A 48 V max. AC or DC • Minimum load : 10 mA 50 mV - 10 µA 5 VDC • Contact resistance : 20 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength: 1,000 Vrms 50 Hz min. between terminals and frame, 500 Vrms 50 Hz min. between terminals • Electrical life at full load : Contacts Number of cycles 2 positions 3 positions Gold plated 60,000 30,000 Silver plated 20,000 10,000 GENERAL SPECIFICATIONS • Strength of terminals : pull-out force 10 N max. • Torque : 1 Nm max. applied between the 2 nuts • Max. panel thickness : 1.5 mm (.059) with 2 nuts The company reserves the right to change specifications without notice. 1 Subminiature toggle switches • metal bushing PANEL CUT-OUT MATERIALS • Case : thermoplastic UL94-V0 WITH FLAT • Actuator : brass, nickel plated Ø4.90 (.193 DIA) • Bushing : zamac, tin plated • Contacts and terminals : 0 : brass, gold plated (standard) 1 : brass, silver plated 3 : brass, gold plated (1.27 micron gold) • Terminal seal : epoxy TERMINALS 0.75 (.029) 3.30 (.129) 0.70 (.027) Straight P0 ELECTRICAL FUNCTIONS 1 3 Function 1 2 Ø2.40 (.094 DIA) 6.10 (.240) 1 2 3 Other function 4.39 (.172) Ø4.90 (.193 DIA) 4.50 (.177) 0.60 (.024) • Wave soldering : 260 °C (500 °F) max. for 5 seconds max. 0.76 (.030) Ø4.90 (.193 DIA) • Hand soldering : 280 °C (536 °F) max. for 5 seconds max. Solder lug S0 4.50 (.177) 4.39 (.172) SOLDERING 1.50 (.059) Ø4.90 (.193 DIA) WITH KEYWAY 1.50 (.059) PANEL SWITCHES ZL series Ø2.40 (.094 DIA) 6.10 (.240) Subminiature toggle switches • metal bushing BUILD YOUR PART NUMBER BASIC PART NUMBER ZL NUMBER OF POLES SERIES 3 ELECTRICAL FUNCTIONS Single pole TERMINALS 1 ON - OFF S0 Solder lug 6 ON - ON P0 Straight PC 9 ON OFF ON 8 ON OFF MOM 2 ON - MOM OPTIONS CONTACT AND TERMINAL MATERIALS BUSHINGS 0 Brass, gold plated 01 Threaded, with flat 1 Brass, silver plated 02 Threaded, with keyway 3 Brass, gold plated (1.27 micron gold) MODELS 00 Standard model ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Mounting accessories : Standard hardware supplied with all models : 2 hex nuts 7 mm (.275) across flats P/N U5731, 1 locking ring P/N U5821 (with keyway) or U5831 (with flat) and 1 lockwasher P/N U5841. 3 PANEL SWITCHES ZL series Subminiature toggle switches • metal bushing III Ø2.40 (.094 DIA) ZL31S0 ON - OFF ZL36S0 ON - ON ZL39S0 ON OFF ON ZL38S0 MOM OFF ON ZL32S0 MOM - ON Ø6.00 (.236 DIA) 0.50 (.019) I 4.00 8.60 (.157) (.338) II EPOXY 3 1.50 (.059) 2.54 (.100) 2 1 0.50 (.019) 8.10 (.318) 5.00 (.196) III I 2.80 (.110) Ø4.83-48UNS-2A (10-48UNS-2A) II 24 5.60 5.50 (.220) (.216) FLAT SOLDER LUG TERMINALS 4.39 (.172) III Ø2.40 (.094 DIA) II I ZL31P0 ON - OFF ZL36P0 ON - ON ZL39P0 ON OFF ON ZL38P0 MOM OFF ON ZL32P0 MOM - ON Ø6.00 (.236 DIA) EPOXY 3 2 1 2.54 (.100) 0.50 (.019) 8.10 (.318) Ø1.10 (.043 DIA) 5.00 (.196) III 0.50 (.019) (10-48UNS-2A) I 3.30 (.129) Ø4.83-48UNS-2A II 24 8.60 5.60 5.50 (.338) (.220) (.216) FLAT STRAIGHT PC TERMINALS 2.54 (.100) PANEL SWITCHES ZL series 4.39 (.172) Shown with threaded bushing code 01 CONTACT & TERMINAL MATERIALS BASIC P/N 0 1 3 00 Brass, gold plated (standard) Brass, silver plated Brass, gold plated (1.27 micron gold) BUSHINGS BASIC P/N 01 02 4 Threaded, with flat Threaded, with keyway 00
ZL36W0000 价格&库存
很抱歉,暂时无法提供与“ZL36W0000”相匹配的价格&库存,您可以联系我们找货
ZL36W0000
    • 1+59.75640
    • 200+23.84640
    • 500+23.04720
    ZL36W0000
    • 100+59.41243100+7.65773
