PANEL SWITCHES
M
00
9
5000M series
SW
Miniature toggle switches •
threaded bushing Ø 11.9 mm
DISTINCTIVE FEATURES
Bushing Ø 11.9 (15/32)
Panel mounting and PCB terminal combination available
1 to 4 pole configurations
UL and CSA approved
ELECTRICAL SPECIFICATIONS
• Current/voltage rating with resistive load :
Contact
Maximum
Minimum
Level*
Silver (A)
4 A 30 VDC
50 mA 10 VDC
III and IV
Silver, gold
plated (AD)
4 A 30 VDC
Gold plating withstands up to 100 mA 30 VDC
10 mA 50 mV
10 µA 5 V
I to IV
Brass, gold
plated (CD)
0.4 VA at 20 VAC or DC
10 mA 50 mV
10 µA 5 V
I and II
*For details, see Technical Information on website.
• For inductive, lamp or capacitive load, consult factory.
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
1,000 Vrms 50 Hz min. between terminals
1,500 Vrms 50 Hz min. between poles
1,500 Vrms 50 Hz min. between terminals and frame
• Contact bounce : 2 ms max.
• Electrical life at full load :
50,000 cycles for single and double pole
40,000 cycles for 3 pole
30,000 cycles for 4 pole
• Low level or mechanical life : 100,000 cycles
GENERAL SPECIFICATIONS
• Torque : 1.25 Nm (.922 Ft.lb) max. applied to nut
• Panel thickness : up to 6 mm (.236)
• Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F)
The company reserves the right to change specifications without notice.
1
PANEL CUT-OUT
MATERIALS
• Case : diallylphthalate (DAP) or high temperature plastic material
(UL94-V0)
Ø12.50
(.492 DIA)
Ø3.50
(.137 DIA)
• Actuator : brass, nickel plated
• Bushing : brass, nickel plated
• Housing : stainless steel or steel tin plated
• Contacts
A : silver
AD : silver, gold plated
CD : brass, gold plated
X814 : for peak currrents, see "Special options".
9.60
(.377)
Standard
Ø12.50
(.492 DIA)
Ø3.50
(.137 DIA)
AGENCY APPROVALS
9.60
(.377)
3 A 250 VAC, 6 A 125 VAC
Availability : consult factory for details of approved models.
Marking : to order switches marked UL or CSA, complete appropriate
box of ordering format. The preferential list does not appear on the
switches.
ELECTRICAL FUNCTION
KEYWAY
1
2
3
1.90
(.074)
TERMINALS
1.10
(.043)
1.80
(.070)
2
Ø12.50
(.492 DIA)
1.70
(.066)
• Terminal seal : epoxy
3.70
(.145)
PANEL SWITCHES
5000M series
5.10
(.200)
With K sealing option
Ø12.50
(.492 DIA)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
5
TERMINALS
SERIES
2
6
NUMBER OF POLES
Straight PC
terminals, 4.70
(.185) terminal
spacing - On
request.
3
Single pole
4
Double pole
5
Three pole
Solder lug
terminals
6
Four pole
TERMINALS
M
Solder lugs with Ø 11.9
(15/32) bushing
ON
1R
ON ON MOM
2R
MOM ON MOM
Leave blank for other
functions.
ELECTRICAL FUNCTIONS
6
MOMENTARY FOR FUNCTION 4
ON
9
ON
OFF
ON
7
MOM
OFF
MOM
CONNECTIONS FOR FUNCTION 4
8
ON
OFF
MOM
4
ON
ON
MOM
ON
ON
ON
ON
MOM
MOM
TH
Standard
CT
Reversed
For functions 4, 4-1R, 4-2R (leave
blank for all other functions).
Wiring diagrams, see
Technical information on
website.
Function 4
Must not have blank in «momentary» box.
Wiring diagrams, see Technical information, on website.
OPTIONS
CONTACT MATERIALS
A
Silver
AD
Silver, gold plated
CD
Brass, gold plated
FINISH
Blank
G
Nickel plated
Black finish on
bushing, actuator
and hardware.
LEVERS
SEALING
Blank
No sealing
K
Front panel
sealing by one
O-ring and
sealing washer
B
Epoxy sealed
terminals
Blank
(std)
Length 17.5
(.688)
-27
Length 11.7
(.460)
AGENCY APPROVALS
UL,
CSA
Availability :
Consult factory
for details of
approved models.
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Mounting accessories : standard hardware supplied with all models : 2 hex nuts 14 mm (.551) across flats and 1 locking ring. Standard and
special hardware is presented in the “Hardware“ section of website.
3
PANEL SWITCHES
5000M series
Shown with standard lever
KEYWAY
7.00
(.275)
11.00
(.433)
MOM
OFF
MOM
5638M
ON
OFF
MOM
Ø11.9-32UNS
(15/32-32UNS)
KEYWAY
11.00
(.433)
12.00
(.472)
ON
5647M
MOM
OFF
MOM
5648M
ON
OFF
MOM
5644 M*
ON
ON
ON
5644M 1R*
ON
ON
MOM
5644M 2R*
MOM
ON
MOM
5
1
4
0.50
(.019)
OFF
2
I
II
III
17.50
(.688)
11.90
(.468)
1.80
(.070)
ON
6
3.70
(.145)
24˚
5649M
3
Ø5.00
(.196 DIA)
I
1-2
4-5
ON
4.70
(.185)
II
5646M
III
2-3
5-6
ON
13.20
(.519)
SOLDER LUG TERMINALS
DOUBLE POLE
11.90
(.468)
4.75
(.187)
5637M
17.50
(.688)
0.80
(.031)
ON
III
1.80
(.070)
OFF
24˚
ON
II
1
Ø5.00
(.196 DIA)
5639M
2
4.70
(.185)
I
1-2
ON
13.20
(.519)
5636M
II
0.50
(.019)
I
3
III
2-3
ON
3.70
(.145)
0.80
(.031)
SINGLE POLE
Ø11.9-32UNS
(15/32-32UNS)
*Function 4 : DP in 4P case - specify CT or TH connections,
see “Technical information“ on website.
KEYWAY
OFF
MOM
4
III
17.50
(.688)
11.90
(.468)
Ø11.9-32UNS
(15/32-32UNS)
KEYWAY
12.10
(.476)
21.20
(.834)
5667M
MOM
OFF
MOM
5668M
ON
OFF
MOM
5664 M*
ON
ON
ON
5664M 1R*
ON
ON
MOM
5664M 2R*
MOM
ON
MOM
11
1
10
II
III
17.50
(.688)
11.90
(.468)
4.75
(.187)
ON
2
I
0.50
(.019)
OFF
12
1.80
(.070)
ON
3
3.70
(.145)
24˚
5669M
I
1-2
4-5
7-8
10-11
ON
4.70
(.185)
II
Ø5.00
(.196 DIA)
5666M
III
2-3
5-6
8-9
11-12
ON
4.75
(.187)
ON
II
0.50
(.019)
5658M
7
1.80
(.070)
MOM
8
1
I
0.80
(.031)
ON
OFF
2
3.70
(.145)
24˚
OFF
MOM
9
Ø5.00
(.196 DIA)
ON
5657M
3
4.70
(.185)
5659M
I
1-2
4-5
7-8
ON
13.20
(.519)
II
5656M
III
2-3
5-6
8-9
ON
FOUR POLE
12.10
(.476)
16.50
(.649)
0.80
(.031)
THREE POLE
13.20
(.519)
PANEL SWITCHES
5000M series
Ø11.9-32UNS
(15/32-32UNS)
CONTACT MATERIAL
BASIC P/N
A
AD
CD
Silver
Silver, gold plated
Brass, gold plated
FINISH
BASIC P/N
Blank Nickel plated
G
Black finish on bushing, actuator and hardware
SEALING
BASIC P/N
Blank No sealing required
B
Epoxy sealed terminals
KB
Combined sealings
1
O-ring
4 Maxi
(.157 MAX)
K Keyway bushing, Includes washer U60
Front panel sealing by one O-ring and sealing washer.
Protects the switch against water and dust.
Panel seal withstands 1 bar pressure and remains sealed
even when switch is operated.
2
Sealing washer
K
Ø11.9
B
LEVERS
BASIC P/N
Ø5.00
(.196 DIA)
11.90
(.468)
11.90
(.468)
11.70
(.460)
17.50
(.688)
Ø5.00
(.196 DIA)
Blank
Standard
-27
5
PANEL SWITCHES
5000M series
PANEL SWITCHES
5000M series
AGENCY APPROVALS
BASIC P/N
UL
CSA
Blank No agency approval required.
Availability : consult factory for details of approved combinations or options.
Marking : to order switches marked UL or CSA, complete above box with desired approvals, in this order & without space
(ex. : ULCSA).
6
很抱歉,暂时无法提供与“5244THCDB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+146.791601+18.99813
- 10+126.6782110+16.39500
- 25+119.4417425+15.45844
- 50+114.2318850+14.78417
- 100+109.24190100+14.13835
- 250+102.96530250+13.32602
- 500+98.44772500+12.74135
- 国内价格
- 1+95.83920
- 200+38.24280
- 500+36.96840
