TL46W005000
TL46W005000
    APEM(埃斐)
    插件
    钮子开关 双刀双掷 6万次 直插 400mA 20V -30℃~+85℃
TL46W005000 数据手册
TL series Tiny washable toggle switches Distinctive features and specifications ❑ Sealed • Single piece case • O-ring seal between actuator and bushing • Epoxy sealed terminals A ❑ Wide variety of contact materials ❑ Same PCB layout as TP, TR and TG tiny switches ELECTRICAL SPECIFICATIONS MATERIALS • Max. current/voltage rating with resistive load : - gold plated contacts : 0,4VA 20V max. AC or DC - silver plated contacts : 0,5A 48V max. AC or DC • Minimum load : 10mA 50mV - 10µA 5VDC • Contact resistance : 20 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals and frame 500 Vrms 50 Hz min. between terminals • Electrical life at full load : Contacts Number of cycles 2 positions Gold plated Silver plated • Case : PBT • Actuator : brass, nickel plated • Contacts and terminals : 0 : brass, gold plated 1 : brass, silver plated 3 : brass, gold plated (1,27 micron gold) 8 : contact brass, gold plated + tin plated terminals 9 : contact brass, gold plated (1,27 micron gold) + tin plated terminals • Terminal seal : epoxy 60.000 20.000 3 positions 30.000 10.000 GENERAL SPECIFICATIONS • Strength of terminals : pull-out force - 10N max. • Operating temperature : -30°C to +85°C • Moisture : 21 days 95 % (NFC 20-603 - IEC 68-2-3) • Cleaning : solvents or water + detergent • Wave soldering : 260°C - 5 sec. APEM www.apem.com A-7 TL series Tiny washable toggle switches Overview TL SERIES A Number of poles 3 4 Electrical functions Single pole Double pole 6 9 7 8 2 Contact and terminal materials 0 1 3 8 9 ON ON MOM ON ON OFF OFF OFF - ON ON MOM MOM MOM Terminals P0 Y0 W0 WW MW Lever and case styles Lever styles : Brass, gold plated Brass, silver plated Brass, gold plated (1,27 micron gold) Contact brass, gold plated + tin plated terminals Contact brass, gold plated (1,27 micron gold) + tin plated terminals • Short - standard • Medium • Long • Cylindrical Codes according to lever finish and case colours : see "options" pages. Straight PC Bracket mounting Right angle, horizontal mounting Right angle, vertical mounting Wire-wrap Special options 00 07 08 18 20 25 30 50 No special requirement Trimmed terminals - length 3,2 (.125) Extended terminals Switch without ground plate Ground plate with 2 pins Trimmed terminals - length 5 (.196) Wire-wrap on bracket mounting models Crimped ground plate pins Insulated levers available. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Packaging unit : 100 pieces, except for models with WW terminals (50 pieces) A-8 www.apem.com APEM TL series Tiny washable toggle switches • Straight PC, right angle or wire-wrap terminals • 1 and 2 pole configurations 3.30 (.129) 15.20 (.598) 0.70 (.027) 1 2 3 0.70 (.027) A MODEL STRUCTURE Shown with standard lever Straight PC terminals : TL..P0 III II I 5.30 (.208) III Ø2.50 (.098 DIA) II I Ø1.10 (.043 DIA) 3.80 (.149) 24˚ Ø4.60 (.181 DIA) 6.10 (.240) 1 Straight PC terminals - bracket mounting : TL..Y0 II III I 5.30 (.208) III 5.08 (.200) 9.10 (.358) 8.10 (.318) 5.00 (.196) Ø2.50 (.098 DIA) 0.50 (.019) II 5.08 (.200) 1 2 3 2.54 4 5 6 (.100) 0.70 (.027) Ø1.10 (.043 DIA) 4 1.00 (.039) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 2.54 (.100) 4.20 (.165) Ø5.00 (.196 DIA) 8.10 (.318) Double pole TL46P0 TL49P0 TL47P0 TL48P0 TL42P0 3.30 (.129) Single pole TL36P0 TL39P0 TL37P0 TL38P0 TL32P0 2.54 (.100) I Ø1.10 (.043 DIA) 3.80 (.149) 24˚ 10.16 (.400) Ø4.60 (.181 DIA) Ø5.00 (.196 DIA) 10.16 (.400) 0.50 (.019) 0.70 (.027) 5.08 (.200) 2.54 (.100) 2.54 (.100) 9.10 (.358) 10.16 (.400) 5.00 (.196) Ø1.10 (.043 DIA) 4 APEM ø4.60 (.181 DIA) 3.30 (.129) 5.55 (.218) www.apem.com 3 2 1 6 5 4 3 6 2.54 (.100) 0.50 (.019) 8.10 (.318) 2.54 (.100) 9.60 (.377) 5.08 (.200) ø5.00 (.196 DIA) 9.20 (.362) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 3.80 (.149) 5.08 (.200) 5.08 (.200) 4.20 (.165) ø1.10 (.043 DIA) 3.50 (.137) Double pole TL46W0 TL49W0 TL47W0 TL48W0 TL42W0 I 0.70 (.027) Single pole TL36W0 TL39W0 TL37W0 TL38W0 TL32W0 II II III 24° 5.30 (.208) III I 5.08 (.200) Right angle terminals - horizontal mounting : TL..W0 ø2.50 (.0.98 DIA) 5.08 (.200) 1 2 3 4 5 6 1 2.54 (.100) 0.40 (.015) 2.54 (.100) 4.20 (.165) 1.00 (.039) 5.70 (.224) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 8.60 (.338) Double pole TL46Y0 TL49Y0 TL47Y0 TL48Y0 TL42Y0 3.30 (.129) Single pole TL36Y0 TL39Y0 TL37Y0 TL38Y0 TL32Y0 3.30 (.129) 2.54 (.100) ø1.10 (.043 DIA) A-9 TL series Tiny washable toggle switches 8.65 (.340) 5.00 (.196) III 5.30 (.208) 5.08 (.200) 2.54 (.100) 5.08 (.200) Ø1.10 (.043 DIA) I Ø1.10 (.043 DIA) 3.80 (.149) 24˚ Ø5.00 (.196 DIA) 6.10 (.240) 1 2 3 4 5 6 5.00 (.196) 1 4 2.54 (.100) Ø1.10 (.043 DIA) 0.50 (.019) 9.10 (.358) 8.10 (.318) 0.70 (.027) 4.20 (.165) 2.54 (.100) 5.08 (.200) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 9.10 (.358) Ø4.60 (.181 DIA) 8.10 (.318) Double pole TL46MW TL49MW TL47MW TL48MW TL42MW I 15.20 (.598) Single pole TL36MW TL39MW TL37MW TL38MW TL32MW II II 3 5.08 (.200) 3.30 (.129) 5.08 (.200) Wire-wrap terminals : TL..MW III 2 5 3 6 0.70 (.027) Ø2.50 (.098 DIA) 5.08 (.200) 6 1 4 5.08 (.200) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 1.00 (.039) A Double pole TL46WW TL49WW TL47WW TL48WW* TL42WW* Ø5.00 (.196 DIA) 0.50 (.019) Single pole TL36WW TL39WW TL37WW TL38WW* TL32WW* 5.30 (.208) Ø4.60 (.181 DIA) 4.20 (.165) Ø1.10 (.043 DIA) 3.80 (.149) 2.54 (.100) I III 9.20 (.362) II II 24˚ 3.50 (.137) III I Ø2.5 (.098 DIA) 5.08 (.200) Right angle terminals - vertical mounting : TL..WW 5.08 (.200) 2.54 (.100) * Functions 2 and 8 : reversed connection available. Consult factory. A-10 www.apem.com 8.65 (.340) 4.60 (.181) 9.60 (.377) 5.00 (.196) 5.55 (.218) 3.05 (.120) 14.30 (.562) 14.20 (.559) PCB MOUNTING APEM TL series Tiny washable toggle switches CONTACT AND TERMINAL MATERIALS Brass, gold plated Brass, silver plated Brass, gold plated (1,27 micron gold) Contact brass, gold plated + tin plated terminals Contact brass, gold plated (1,27 micron gold) + tin plated terminals 0 1 3 8 9 A LEVER AND CASE STYLES Ø5.00 (.196 DIA) Short - standard Ø4.60 (.181 DIA) Ø5.00 (.196 DIA) Long CASE LEVER Nickel plated Matt black Blue Black 00 01 50 51 6.50 (.255) Ø1.60 (.062 DIA) 4.20 (.165) 9.40 (.370) 4.20 (.165) 3.80 (.149) 6.10 (.240) 5.30 (.208) Ø4.60 (.181 DIA) 6.10 (.240) 3.80 (0149) Ø2.50 (.098 DIA) 24˚ 24˚ Nickel plated Matt black 3.80 (.149) Ø4.60 (.181 DIA) 4.20 (.165) Ø5.00 (.196 DIA) Medium CASE LEVER 24˚ 7.40 6.10 (.240) (.291) Ø2.50 (.098 DIA) Ø2.50 (.098 DIA) Blue Black 02 03 52 53 CASE LEVER Nickel plated Matt black Blue Black 04 05 54 55 24˚ Ø4.60 (.181 DIA) 4.20 (.165) Ø5.00 (.196 DIA) 6.10 (.240) 3.80 (.149) Cylindrical CASE LEVER Nickel plated APEM Blue Black - 56 www.apem.com A-11 TL series Tiny washable toggle switches LEVER AND CASE STYLES (continued) Insulated levers - Protected against electrostatic discharges (ESD) up to 10KV. Black colour. Ø4.60 (.181 DIA) 3.80 (.149) 4.20 (.165) Ø5.00 (.196 DIA) 4.20 (.165) With blue case With black case 30 90 6.10 7.60 (.240) (.299) 3.80 (.149) 40 94 24˚ 24˚ 6.10 (.240) A Ø2.50 (.098 DIA) 5.50 (.216) Ø2.50 (.098 DIA) Ø4.60 (.181 DIA) Ø5.00 (.196 DIA) With blue case With black case SPECIAL OPTIONS 00 No special requirement 07 Trimmed terminals - length 3,2 mm (.125) for TL..WW models only 3.20 (.125) 07 12.50 (.492) Extended terminals for TL..W0 models only 18 Switch without ground plate for TL..WW models only 08 18 5.08 (.200) Ground plate with 2 pins for TL..WW models only 2.54 (.100) 20 10.16 (.400) 2.70 (.106) 10.16 (.400) 08 Ø1.10 (.043 DIA) 20 Trimmed terminals - length 5 mm (.196) for all models, except TL..WW 30 Wire-wrap terminals on models with mounting bracket 50 Crimped ground plate pins. Retains switch on PCB during handling and wave soldering. For models TL..W0, TL..WW and TL..Y0 single and double pole. A-12 www.apem.com 5.00 (.196) 25 15.20 (.598) 25 30 50 APEM
TL46W005000 价格&库存
很抱歉,暂时无法提供与“TL46W005000”相匹配的价格&库存,您可以联系我们找货
TL46W005000
  • 50+142.1659350+18.36646
