SW232CD7
SW232CD7
    APEM(埃斐)
    插件
    钮子开关 单刀双掷 10万次 直插 400mA 20V -20℃~+85℃
SW232CD7 数据手册
S series - SW PANEL SWITCHES L G G O ST 1 71 1 E- Washable miniature toggle switches • plain bushing DISTINCTIVE FEATURES Process sealed Front and rear sealing Process compatible Wave solderable Washable ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -20 °C to +85 °C (-4 °F to +185 °F) • Storage temperature : -40 °C to +85 °C (-40 °F to +185 °F) • Moisture : The insulating materials employed and the complete seal permit the switches to withstand a 56 days moisture test (IEC 68-2-3). • Solderability : The switches are tested at 235 °C ( 455 °F) according to IEC 68-2-20 after accelerated aging. ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (A) : 4 A 30 VDC - gold plated brass contacts (CD) : 0.4 VA 20 VAC or DC - gold plated silver contacts (AD) : 4 A 30 VDC (300 mA 30 VDC for gold plating) • Initial contact resistance : 10 mΩ max. • Insulation resistance : 1,000 MΩ min. • Dielectric strength : 1,000 Vrms 50 Hz min. • Electrical life at full load : Contacts Number of cycles 2 positions 3 positions A 40,000 40,000 CD 100,000 50,000 AD 40,000 40,000 The company reserves the right to change specifications without notice. 1 Washable miniature toggle switches • plain bushing ELECTRICAL FUNCTIONS GENERAL SPECIFICATIONS • Mechanical strength : Terminals are strengthened by a bracket or a ground plate ensuring the rigidity of the switch on the board. Actuator strength is 10 N max. • Soldering - thermal shock : The switches are especially designed for flow soldering at 260 °C (500 °F) during 5 seconds owing to high temperature polymer parts. 1 MATERIALS 2 3 CAP FOR PCB PROCESSING • Case and cover : UL94-VO, polyamide, glass filled or PES • Actuator : brass, nickel plated • Contacts CD : brass, gold plated A : silver AD : silver, gold plated • Provide additional protection during PCB processing. • Supplied mounted on the switch or separately. • Material : vinyl 16.00 (.629) • Terminal seal : epoxy Ø4.76 (.187 DIA) AGENCY APPROVALS U3012 17.45 (.687) 2 A 250 VAC 4 A 125 VAC Ø3.96 (.155 DIA) CECC 96201-006 2 2.00 (.078) 17.10 (.673) 13.00 (.511) 6.65 (.261) 11.65 (.458) 6.00 (.236) 6.90 (.271) PCB MOUNTING 3.60 (.141) PANEL SWITCHES S series Washable miniature toggle switches • plain bushing BUILD YOUR PART NUMBER BASIC PART NUMBER S TERMINALS SERIES W Right angle, horizontal mounting WW Right angle, vertical mounting Y TERMINAL SPACING 2 Terminal spacing 4.7 (.185) or 3.81 (.150) 0 Terminal spacing 5.08 (.200) (SW switches) ELECTRICAL FUNCTIONS NUMBER OF POLES 3 Single pole 6 ON - ON 4 Double pole 9 ON OFF ON 7 MOM OFF MOM 8 ON OFF MOM 2 ON - MOM 4TH ON ON Bracket mounting ON OPTIONS LEVERS CONTACT MATERIALS A Silver AD Silver, gold plated CD Brass, gold plated -7 -13 Short Standard Long Insulated levers -11 Long -8 Short APPROVALS UL CECC Availability : Consult factory for details of approved models. SPECIAL OPTIONS X601 Silver plated brass contacts X696 Higher bushing (for insulated levers) INSULATING CAPS U270 For lever 13 U1710 For lever 7 ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. 3 PANEL SWITCHES S series Washable miniature toggle switches • plain bushing ON SWW237 SWW247 MOM OFF MOM SWW238 SWW248** ON OFF MOM SWW232 SWW242** ON - MOM SWW244TH* ON ON 4.75 (.187) ON III 2-1 4-5 Double pole SY236 SY246 ON - ON SY239 SY249 ON OFF ON SY237 SY247 MOM OFF MOM SY238 SY248 ON OFF MOM SY232 SY242 ON - MOM SY244TH* ON ON Single pole Double pole SW036 SW046 ON - ON SW039 SW049 ON OFF ON SW037 SW047 MOM OFF MOM SW038 SW048 ON OFF MOM SW042 ON - MOM SW044TH* ON ON SW032 ON * Function 4 : SP in DP case - TH connection, see "Technical information" on website. ** Functions 2 and 8 : reversed connection available. On request. 4 EPOXY 3 2 12.70 (.500) 12.70 (.500) 3.81 (.150) 3.18 (.125) Ø2.70 (.106 DIA) Ø1.60 (.062 DIA) 0.40 (.015) 1 0.90 (.035) ON III 2-1 4-5 4.75 (.187) 11.35 (.446) 8.20 (.322) 4.70 (.185) 3.18 (.125) 15.75 (.620) 4.75 (.187) 5.08 (.200) Ø2.70 (.106 DIA) 5.30 (.208) 20˚ 6.10 (.240) II Ø6.20 (.244) Ø6.20 (.244 DIA) 3.90 (.153) 5.08 (.200) Ø1.10 (.043 DIA) 12.70 (.500) 12.70 (.500) I 2-3 5-6 5.08 (.200) 1.10 (.043) 20˚ 4.40 (.173) Single pole RIGHT ANGLE TERMINALS - HORIZONTAL SPACING 5.08 (.200) 5.30 (.208) Ø1.60 (.062 DIA) 6.60 (.259) 3.10 (.122) 13.00 (.511) 0.60 (.023) II 2 3 EPOXY BRACKET MOUNTING I 2-3 5-6 1 12.70 (.500) 12.70 (.500) 1.10 (.043) 11.35 (.446) 3.81 (.150) ON OFF 12.70 (.500) - ON 3.81 (.150) ON SWW249 Ø6.20 (.244 DIA) 4.70 (.185) SWW246 SWW239 5.08 (.200) 4.70 (.185) SWW236 Ø2.70 (.106 DIA) 20˚ 12.70 (.500) Double pole 5.30 (.208) 0.80 (.039) Single pole III I 2-3 5-6 4.70 (.185) 3 EPOXY 6.90 (.271) 0.60 (.023) 2 1 5.08 (.200) 0.60 (.023) 5.08 (.200) 11.65 (.458) 12.70 (.500) III 2-1 4-5 RIGHT ANGLE TERMINALS - VERTICAL 11.65 (.458) 4.70 (.185) 5.08 (.200) 3.81 (.150) II 3.90 (.153) 15.75 (.620) ON 15.75 (.620) ON 0.40 (.015) ON 3.81 (.150) SW244TH* 0.50 (.019) 6.90 (.271) 5.08 (.200) 0.80 (.031) 0.40 (.015) MOM Ø1.60 (.062 DIA) 3.81 (.150) - 1 1.10 (.043) ON 4.70 (.185) 6.10 7.50 (.240) (.295) SW242 2 12.70 (.500) SW232 3 EPOXY 3.81 (.150) MOM 5.90 (.232) OFF 11.70 (.460) ON 0.60 (.023) SW248 7.50 (.295) SW238 5.08 (.200) 12.70 (.500) 0.50 (.019) MOM 7.50 (.295) ON OFF 7.50 (.295) OFF MOM 6.10 (.240) ON SW247 I SW249 SW237 II SW239 Ø6.20 (.244 DIA) ON III - I ON II SW246 III Double pole SW236 5.30 (.208) 20˚ II Single pole Ø2.70 (.106 DIA) I I 2-1 4-5 I 2-3 5-6 Shown with lever -7 II RIGHT ANGLE TERMINALS - HORIZONTAL SPACING 4.7 (.185) II III III PANEL SWITCHES S series Washable miniature toggle switches • plain bushing CONTACT MATERIALS BASIC P/N A AD AC Silver Silver, gold plated Brass, gold plated LEVERS BASIC P/N METAL LEVERS INSULATED LEVERS 13.00 (.511) 7.50 (.295) 7.50 (.295) 6.80 (.267) 6.30 (.248) 13.30 (.523) Ø2.70 (.106) 6.30 (.248) Ø2.90 (.114 DIA) Ø2.90 (.114 DIA) 7.50 (.295) Ø3.00 (.118 DIA) -7 Standard -13 Long -8 Short If actuator not specified, we supply former default option -13. -11 Long Protected against electrostatic discharges (ESD) up to 12 KV. Black color. To combine with option X696. SPECIAL OPTIONS BASIC P/N X601 X696 Silver plated brass contacts Lower rating - Minimum quantity : 5,000 pieces per model and shipment. Higher bushing 7.50 (.295). Compulsory for insulated levers 11 and 8. AGENCY APPROVALS BASIC P/N UL CECC Blank No agency approval required. Availability : consult factory for details of approved models. Marking : to order switches marked UL or CECC, please complete above box with desired approvals. 5 PANEL SWITCHES S series Washable miniature toggle switches • plain bushing INSULATING CAPS + U... Ø3.50 (.137 DIA) U1710 For lever 7 11.00 (.433) BASIC P/N 7.30 (.287) PANEL SWITCHES S series Ø3.50 (.137 DIA) U270 For lever 13 For cap colors, replace "0" with number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7/1 White 9 Orange 6
SW232CD7 价格&库存
很抱歉,暂时无法提供与“SW232CD7”相匹配的价格&库存,您可以联系我们找货
SW232CD7
    • 1+162.41040
    • 200+64.81080
    • 500+62.64000
