TL42WW00000
TL42WW00000
    APEM(埃斐)
    插件
    钮子开关 双刀双掷 6万次 直插 400mA 20V -30℃~+85℃
TL42WW00000 数据手册
PANEL PCB SWITCHES - SW 03 18 TL TL series Subminiature washable toggle switches DISTINCTIVE FEATURES Process sealed Single piece case Front and rear sealing Wide variety of contact materials Same PCB layout as TP, TR and TG subminiature switches ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -30 °C to +85 °C (-22 °F to +185 °F) • Moisture : 21 days 95 % (NFC 20-603 - IEC 68-2-3) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - gold plated contacts : 0.4 VA 20 V max. AC or DC - silver plated contacts : 0.5 A 48 V max. AC or DC • Minimum load : 10 mA 50 mV - 10 µA 5 VDC • Contact resistance : 20 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals and frame 500 Vrms 50 Hz min. between terminals • Electrical life at full load : Contacts Number of cycles 2 positions 3 positions Gold plated 60,000 30,000 Silver plated 20,000 10,000 GENERAL SPECIFICATIONS • Strength of terminals : pull-out force - 10 N max. • Cleaning : solvents or water + detergent • Wave soldering : 260 °C (500 °F) - 5 sec. The company reserves the right to change specifications without notice. 1 Subminiature washable toggle switches MATERIALS • Case : PBT • Actuator : brass, nickel plated • Contacts and terminals : 0 : brass, gold plated 1 : brass, silver plated 3 : brass, gold plated (1,27 micron gold) 8 : contact brass, gold plated + tin plated terminals 9 : contact brass, gold plated (1,27 micron gold) + tin plated terminals • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. TERMINALS 3.30 (.129) 15.20 (.598) 0.70 (.027) 0.70 (.027) ELECTRICAL FUNCTIONS 1 2 3 2 8.65 (.340) 4.60 (.181) 9.60 (.377) 5.00 (.196) 5.55 (.218) 3.05 (.120) 14.30 (.562) PCB MOUNTING 14.20 (.559) PCB SWITCHES TL series Subminiature washable toggle switches BUILD YOUR PART NUMBER BASIC PART NUMBER TL ELECTRICAL FUNCTIONS NUMBER OF POLES SERIES TERMINALS 3 Single pole 6 ON - ON P0 Straight PC 4 Double pole 9 ON OFF ON Y0 Bracket mounting 7 MOM OFF MOM W0 8 ON OFF MOM Right angle, horizontal mounting 2 ON - MOM WW Right angle, vertical mounting OPTIONS CONTACT AND TERMINAL MATERIALS With blue case With black case 00 Short lever, nickel plated 50 Short lever, nickel plated Brass, gold plated (1.27 micron gold) 01 Short lever, black 51 Short lever, black Contact brass, gold plated + tin plated terminals 02 Long lever, nickel plated 52 Long lever, nickel plated 03 Long lever, black 53 Long lever, black 04 Medium lever, nickel plated 54 Medium lever, nickel plated 05 Medium lever, black 55 Medium lever, black 40 Short insulated lever 56 Cylindrical lever, nickel plated 30 Long insulated lever 94 Short insulated lever 90 Long insulated lever 0 Brass, gold plated 1 Brass, silver plated 3 8 9 Contact brass, gold plated (1.27 micron gold) + tin plated terminals (SP only) SPECIAL OPTIONS LEVER STYLES / CASE COLORS 00 No special requirement 07 Trimmed terminals - length 3.2 (.125) 08 Extended terminals 18 Switch without ground plate 20 Ground plate with 2 pins 25 Trimmed terminals - length 5 (.196) 50 Crimped ground plate pins ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. 3 PANEL PCB SWITCHES TL series Subminiature washable toggle switches Shown with standard lever STRAIGHT PC TERMINALS : TL..P0 III I Ø4.60 (.181 DIA) Single pole Double pole - ON TL39P0 TL49P0 ON OFF ON TL37P0 TL47P0 MOM OFF MOM TL38P0 TL48P0 ON OFF MOM TL32P0 TL42P0 ON - MOM 1 1 2 3 2.54 4 5 6 (.100) 0.70 (.027) III 5.08 (.200) 9.10 (.358) II 2.54 (.100) I Ø1.10 (.043 DIA) 3.80 (.149) 24˚ 5.30 (.208) Ø2.50 (.098 DIA) Ø1.10 (.043 DIA) 4 8.10 (.318) 5.00 (.196) STRAIGHT PC TERMINALS BRACKET MOUNTING : TL..Y0 0.50 (.019) 2.54 (.100) 4.20 (.165) Ø5.00 (.196 DIA) 6.10 (.240) ON 8.10 (.318) TL46P0 3.30 (.129) TL36P0 Ø1.10 (.043 DIA) 3.80 (.149) 5.08 (.200) II I 1.00 (.039) III II 24˚ 5.30 (.208) Ø2.50 (.098 DIA) 10.16 (.400) Ø4.60 (.181 DIA) TL38Y0 TL48Y0 ON OFF MOM TL32Y0 TL42Y0 ON - MOM ON Single pole Double pole TL36W0 TL46W0 ON - TL39W0 TL49W0 ON OFF ON TL37W0 TL47W0 MOM OFF MOM TL38W0 TL48W0 ON OFF MOM TL32W0 TL42W0 ON - MOM 4.20 (.165) ON Single pole Double pole TL36WW TL46WW ON - TL39WW TL49WW ON OFF ON TL37WW TL47WW MOM OFF MOM TL38WW* TL48WW* ON OFF MOM TL32WW* TL42WW* ON - MOM I II 4.20 (.165) 5.08 (.200) 2.54 (.100) ø1.10 (.043 DIA) III 6 8.65 (.340) 5.08 (.200) Ø1.10 (.043 DIA) 3.80 (.149) Ø5.00 (.196 DIA) 0.70 (.027) 2.54 (.100) 3.30 (.129) 24˚ Ø4.60 (.181 DIA) 5.00 (.196) 4 9.60 (.377) 8.10 (.318) 0.50 (.019) I 3 6 2.54 (.100) 0.50 (.019) Ø2.5 (.098 DIA) II ø5.00 (.196 DIA) 5.55 (.218) ø1.10 (.043 DIA) 3.80 (.149) ø4.60 (.181 DIA) 3 2 1 6 5 4 3.30 (.129) RIGHT ANGLE TERMINALS VERTICAL MOUNTING : TL..WW III II III 24° 5.30 (.208) I 2.54 (.100) 9.10 (.358) 0.70 (.027) II *Functions 2 and 8 : reversed connection available. On request. I ø2.50 (.0.98 DIA) III 5.08 (.200) 10.16 (.400) 5.00 (.196) RIGHT ANGLE TERMINALS HORIZONTAL MOUNTING : TL..W0 0.70 (.027) 2.54 (.100) 5.08 (.200) MOM 2.54 (.100) OFF 10.16 (.400) 3 6 2 5 1 4 3.30 (.129) 5.08 (.200) 2.54 (.100) MOM 0.50 (.019) 3 5.08 (.200) TL47Y0 1 2 3 4 5 6 5.08 (.200) TL37Y0 0.40 (.015) 2.54 (.100) ON 5.08 (.200) OFF 5.08 (.200) ON 9.20 (.362) TL49Y0 Ø1.10 (.043 DIA) 4 5.08 (.200) TL39Y0 1 3.50 (.137) ON 1.00 (.039) - 5.30 (.208) ON 9.20 (.362) TL46Y0 2.54 (.100) 4.20 (.165) 5.08 (.200) TL36Y0 Ø5.00 (.196 DIA) 3.50 (.137) I 5.70 (.224) II 8.60 (.338) III Single pole Double pole 3.30 (.129) PCB SWITCHES TL series 5.08 (.200) 9.10 (.358) 5.08 (.200) Ø1.10 (.043 DIA) Subminiature washable toggle switches CONTACT AND TERMINAL MATERIALS BASIC P/N 0 1 3 8 9 Brass, gold plated Brass, silver plated Brass, gold plated (1.27 micron gold) Contact brass, gold plated + tin plated terminals Contact brass, gold plated (1.27 micron gold) + tin plated terminals (single pole only) LEVER AND CASE STYLES BASIC P/N SHORT - STANDARD LONG Ø2.50 (.098 DIA) 6.10 (.240) 4.20 (.165) CASE Ø4.60 (.181 DIA) 3.80 (.149) Ø5.00 (.196 DIA) 4.20 (.165) Blue Black Nickel plated 00 50 Black 01 51 LEVER MEDIUM CASE 9.40 (.370) 3.80 (0149) 24˚ 24˚ Ø4.60 (.181 DIA) 6.10 (.240) 5.30 (.208) Ø2.50 (.098 DIA) Ø5.00 (.196 DIA) Blue Black Nickel plated 02 52 Black 03 53 LEVER CYLINDRICAL 7.40 6.10 (.240) (.291) 3.80 (.149) 4.20 (.165) CASE 24˚ Ø4.60 (.181 DIA) 3.80 (.149) Ø4.60 (.181 DIA) Ø5.00 (.196 DIA) 4.20 (.165) Ø5.00 (.196 DIA) Blue Black Nickel plated 04 54 Black 05 55 LEVER 6.50 (.255) Ø1.60 (.062 DIA) 24˚ 6.10 (.240) Ø2.50 (.098 DIA) CASE LEVER Nickel plated Blue Black - 56 INSULATED LEVERS Protected against electrostatic discharges (ESD) up to 10 KV. Ø2.50 (.098 DIA) 5.50 (.216) Ø4.60 (.181 DIA) 3.80 (.149) 4.20 (.165) Ø5.00 (.196 DIA) 4.20 (.165) 6.10 (.240) 3.80 (.149) CASE LEVER Black 24˚ 24˚ Blue Black 40 94 CASE LEVER Black Ø4.60 (.181 DIA) 7.60 6.10 (.240) (.299) Ø2.50 (.098 DIA) Ø5.00 (.196 DIA) Blue Black 30 90 5 PANEL PCB SWITCHES TL series Subminiature washable toggle switches SPECIAL OPTIONS BASIC P/N 00 No special requirement 07 Trimmed terminals - length 3,2 mm (.125) for TL..WW models only 08 Extended terminals for TL..W0 models only 18 Switch without ground plate for TL..WW models only 20 Ground plate with 2 pins for TL..WW models only 25 Trimmed terminals - length 5 mm (.196) for all models, except TL..WW 50 Crimped ground plate pins. Retains switch on PCB during handling and wave soldering. For models TL..W0, TL..WW and TL..Y0 single and double pole. 10.16 (.400) 5.08 (.200) 2.70 (.106) 12.50 (.492) 2.54 (.100) 3.20 (.125) 10.16 (.400) PCB SWITCHES TL series Ø1.10 (.043 DIA) 07 08 5.00 (.196) 25 6 50 18 20
TL42WW00000 价格&库存
很抱歉,暂时无法提供与“TL42WW00000”相匹配的价格&库存,您可以联系我们找货
TL42WW00000
    • 1+190.95480
    • 200+76.19400
    • 500+73.65600
