MINIATURE SWITCHES
Ordering Table — Standard Toggle Switches
HOW TO ORDER YOUR DESIGN (Bold Face Type indicates items normally in Distributor Stock)
To determine a part number select the options desired and fill in
Following the table from left to right, the designer is able to specify
the boxes in the selection guides illustrated below.
the options wanted. The options are described and illustrated on
pages 24-31. Refer to page 57 for mounting hardware.
Toggle Switch Selection Guide
Toggle
Switch
Series
Poles
and
Throw
Series
No.
Code
A
SPDT
1
DPDT
Circuit
Poles and Throw
2
Lever
Options
Circuits
ON
Code
Type
Code
K1
21
Lever Lock
K Bushing Only
.840 Bat
.640 Bat
3PDT
3
ON NONE
ON
23
4PDT
4
ON NONE
ON*
26
ON* OFF
ON*
27
.550 Bat
Long Mod Cap
Short Mod Cap
.200 Bat
.840 Flat
ON OFF
ON
ON
ON
ON*
ON
ON
ON*
NONE ON
ON*
ON* ON
ON*
NONE ON
ON
31
32
.450 Flat
.250 Flat
.410 Bat
33
.468 Large
.687 Large
Finish
Bright Chrome
Stain Chrome
L0
L1
L2
L3
Black Nylon
L4
M
White Nylon
Black
Red Nylon
Bushing
Options
Lever Options and Finishes
POS. "C"
ON OFF
Lever
Finish
Terminal
Type
Bushing Options
Code
1
2
3
4
5
6
P1
P3
P4
S
T1
T
34
35
53
Type
Splashproof Lever CW
& Bushing Seal
Splashproof
CX
Lever Seal Only
D
.280 Threaded
Type
Available on S, M and P3 only.
Add .070 to lever length when using these bushings.
Available with S, M, L0, L1, L2, L3, L4 lever options. Consult factory for availability.
Standard on P1, P3, P4 and K1 lever options. Available on all other levers except T & T1.
These circuits are NOT available with the following 3 and 4 pole options: A, AV, AV2, V30, V40,
V60 and V70.
1 and 2 pole only.
Epoxy seal standard on all terminal options.
Contact Material
Code
Type
Code
A
AV
Gold/Nickel/Brass
Gold/Nickel/Silver
Coin Silver
B
G
Right Angle PC
.280 Smooth
.350 Flatted
With Shoulder
.350 Keyway
With Shoulder
D9
H
Vertical PC
.100 Spacing
Vertical PC
.150 Spacing
Printed Circuit
Terminals
Right Angle
Same Throw
R
H3
K
Right Angle
Opposite Throw
R2
Locking K1
Lever Only
15/32 Dia.
Splashproof Lever
15/32 &
Panel Seal
15/32 Splashproof
Lever
Seal Only
.350 Threaded
.437 Threaded
(With P3 Only)
.350 Smooth
T
TW
Q
AV2
K
C
M
Other Option
Type
Epoxy Sealed
Terminals
Anti-Rotation
Anti-Jam
Bushing
Code
P
L
PC & Support
V30
PC & Support
V40
PC & Support
V60
TX
PC & Support
Y
Y5
.750 Wire Wrap
.964 Wire Wrap
Y9
.425 Wire Wrap
1.062 Wire Wrap
Solder Lugs
Quick Connect
*Momentary Contact
Other
Terminal Options
Code
Contact
Material
V70
W
W1
W3
W4
Z
Z3
Available only with L3 and L4 levers.
Available in 1 pole only.
See page 58 for construction detail, wiring and electrical diagrams.
1, 2 and 3 pole only.
Available on T or T1 lever options only.
Available on T, TW, and TX bushing options. (Bright chrome only.)
Not available on K1 lever.
Same as B, G and Q respectively except terminals brass with tin nickel alloy over nickel plate.
Consult plant for availability.
EXAMPLES:
A232L01YW1B = DPDT toggle switch with an ON-ON-ON circuit, .840" long lever in a bright chrome finish, .350 threaded bushing, .964" long
wire wrap terminals, gold/brass contacts and epoxy sealed terminals.
SPECIFICATIONS:
MATERIALS:
Contact Ratings —
Letter codes G and Q — 6 amp at 125 VAC, 3 amp @ 250 VAC (U.L.
recognized, CSA certified) or 6 amp at 28 VDC resistive.
Letter codes B and G – 0.5. volt-amp (VA) maximum @ 28 V
maximum (AC or DC).
Life Under Load — 60,000 make-and-break cycles — resistive
load only.
Initial Contact Resistance — 10 milliohms maximum 3 VDC, 100
ma for both silver and gold plated contacts.
Insulation Resistance — 1 & 2 pole —1,000 megohms, min.
3 & 4 pole —1,000 megohms, min.
Dielectric Strength — 1,000 volts rms at sea level.
Bushing Strength — 12 pound-inches without physical damage to
switch.
Weight (including hardware) — SP 0.19 oz.; DP 0.23 oz.; 3-pole
0.28 oz.; 4-pole 0.32 oz.
Base (body) — 1- and 2-pole —Diallyl Phthalate (DAP).
3- and 4-pole — high strength phenolic.
Lever (toggle) — Brass, chrome plated.
Flat Lever — Brass, satin chrome finish.
Locking lever cap — Anodized aluminum.
Bushing — Brass, nickel plated.
Clamp (frame) — Stainless steel.
Support brackets — Steel, tin plated.
Switching Contacts and Rockers —
Letter Code B — gold/nickel/brass
Letter Code G — gold/nickel/silver
Letter Code Q — Coin silver
Center Terminal
Letter Codes B, G — Gold flash/nickel/brass
Letter Code Q — Silver plated brass.
Hardware — See page 55-57.
38
Litho in U.S.A GG
MINIATURE SWITCHES
Toggle Switches — Base Dimensions and Lever Options
APPROXIMATE BASE DIMENSIONS
ONE POLE
TWO POLE
THREE POLE
FOUR POLE
TOGGLE LEVER OPTIONS
K1
Locking Lever
L0
Long (.840")
L1
Long (.640")
L2
Long (.550")
L3
Plastic (.840")
L4
Plastic (.571")
Litho in U.S.A GG
39
MINIATURE SWITCHES
Toggle Lever Options — Contd.
M
Short (.200")
P1
Flatted (.840")
P3
Flatted (.448")
S
Std. Bat (.410")
T
Large Toggle
T1
Large Toggle
P4
Flatted (.250")
BUSHING OPTIONS
CW
Splashproof Sealed Lever and Panel Seal
D
D9
Threaded
Smooth
(No Keyway)
CW = Flatted bushing
H
TW
K
High Torque Flatted with Shoulder
H3
High Torque
P
Anti-Rotation
and Panel Seal
OX
Y
Y9
Threaded with Lever Seal
Threaded
Smooth (No Keyway)
Y5
Long Bushing (.437")
Refer to K1 lever drawing for dimensions.
T &TX Refer to T or T1 lever drawing for dimensions.
40
Note: For hardware refer to pages 55-57.
Litho in U.S.A GG
MINIATURE SWITCHES
Termination Options
C Printed
W Wire-Wrap
W1 Wire-Wrap
W3 Wire-Wrap
W4 Wire-Wrap
Z STANDARD
CIRCUIT
Z3 Quick
CONNECT
Mating Receptacle from
AMP SPECIAL IND.,
P.O. Box 984, Paoli,
Pa. 19301 Amp P/N
single piece 61454
series, strip from 60900
NOTE: Wire-Wrap is a registered trademark of the Gardner-Denver Company.
TERMINATION/MOUNTING OPTIONS
A
One Pole
A
Right Angle P.C. Terminal
EPOXY SEAL
STD. FOR
THIS OPTION
Two Pole
A
Three Pole
R
Contacts
Make on
Opposite Side
Toggle
Thrown
One Pole
R2
One Pole
Litho in U.S.A GG
Contacts
Make on
Opposite Side
Toggle
Thrown
41
MINIATURE SWITCHES
Termination/Mounting Options
AV1
w/.100" terminal spacing
AV2
w/.150" terminal spacing (pictured below)
ONE POLE Epoxy sealed P.C. terminals are supplied as standard for these options.
AV1
AV2
TWO POLE Epoxy sealed P.C. terminals are supplied as standard for these options.
AV
AV2
THREE POLE Epoxy sealed P.C. terminals are supplied as standard for these options.
AV
AV2
FOUR POLE Epoxy sealed P.C. terminals are supplied as standard for these options.
42
Litho in U.S.A GG
MINIATURE SWITCHES
V30
1 Pole P.C. Mounting
ONE POLE
TWO POLE
2 Pole P.C. Mounting
EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS
V40
ONE POLE
TWO POLE
V60
ONE POLE
TWO POLE
V70
ONE POLE
TWO POLE
Litho in U.S.A GG
43
很抱歉,暂时无法提供与“A127T11TXCB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+165.723471+21.46699
