A123S3CWZB
A123S3CWZB
    ELECTROSWITCH
    钮子开关 单刀双掷 6万次 面板安装 500mA 28V -30℃~+90℃
A123S3CWZB 数据手册
MINIATURE SWITCHES Ordering Table — Standard Toggle Switches HOW TO ORDER YOUR DESIGN (Bold Face Type indicates items normally in Distributor Stock) To determine a part number select the options desired and fill in Following the table from left to right, the designer is able to specify the boxes in the selection guides illustrated below. the options wanted. The options are described and illustrated on pages 24-31. Refer to page 57 for mounting hardware. Toggle Switch Selection Guide Toggle Switch Series Poles and Throw + Series No. Code A SPDT 1 DPDT Circuit + Poles and Throw 2 Lever Options + Circuits ON + Code Type Code K1 21 Lever Lock K Bushing Only .840 Bat .640 Bat 3PDT 3 ON NONE ON 23 4PDT 4 ON NONE ON* 26 ON* OFF ON* 27 .550 Bat Long Mod Cap Short Mod Cap .200 Bat .840 Flat ON OFF ON ON ON ON* ON ON ON* NONE ON ON* ON* ON ON* NONE ON ON 31 32 .450 Flat .250 Flat .410 Bat 33 .468 Large .687 Large Finish Bright Chrome Stain Chrome L0 L1 L2 L3 Black Nylon L4 M White Nylon Black Red Nylon Bushing Options + Lever Options and Finishes POS. "C" ON OFF Lever Finish Terminal Type + Bushing Options Code 1 2 3 4 5 6 P1 P3 P4 S T1 T 34 35 53 Type Splashproof Lever CW & Bushing Seal Splashproof CX Lever Seal Only D .280 Threaded Type Available on S, M and P3 only. Add .070 to lever length when using these bushings. Available with S, M, L0, L1, L2, L3, L4 lever options. Consult factory for availability. Standard on P1, P3, P4 and K1 lever options. Available on all other levers except T & T1. These circuits are NOT available with the following 3 and 4 pole options: A, AV, AV2, V30, V40, V60 and V70. 1 and 2 pole only. Epoxy seal standard on all terminal options. + Contact Material Code Type Code A AV Gold/Nickel/Brass Gold/Nickel/Silver Coin Silver B G Right Angle PC .280 Smooth .350 Flatted With Shoulder .350 Keyway With Shoulder D9 H Vertical PC .100 Spacing Vertical PC .150 Spacing Printed Circuit Terminals Right Angle Same Throw R H3 K Right Angle Opposite Throw R2 Locking K1 Lever Only 15/32 Dia. Splashproof Lever 15/32 & Panel Seal 15/32 Splashproof Lever Seal Only .350 Threaded .437 Threaded (With P3 Only) .350 Smooth T TW Q AV2 K C M Other Option Type Epoxy Sealed Terminals Anti-Rotation Anti-Jam Bushing Code P L PC & Support V30 PC & Support V40 PC & Support V60 TX PC & Support Y Y5 .750 Wire Wrap .964 Wire Wrap Y9 .425 Wire Wrap 1.062 Wire Wrap Solder Lugs Quick Connect *Momentary Contact Other + Terminal Options Code Contact Material V70 W W1 W3 W4 Z Z3 Available only with L3 and L4 levers. Available in 1 pole only. See page 58 for construction detail, wiring and electrical diagrams. 1, 2 and 3 pole only. Available on T or T1 lever options only. Available on T, TW, and TX bushing options. (Bright chrome only.) Not available on K1 lever. Same as B, G and Q respectively except terminals brass with tin nickel alloy over nickel plate. Consult plant for availability. EXAMPLES: A232L01YW1B = DPDT toggle switch with an ON-ON-ON circuit, .840" long lever in a bright chrome finish, .350 threaded bushing, .964" long wire wrap terminals, gold/brass contacts and epoxy sealed terminals. SPECIFICATIONS: MATERIALS: Contact Ratings — Letter codes G and Q — 6 amp at 125 VAC, 3 amp @ 250 VAC (U.L. recognized, CSA certified) or 6 amp at 28 VDC resistive. Letter codes B and G – 0.5. volt-amp (VA) maximum @ 28 V maximum (AC or DC). Life Under Load — 60,000 make-and-break cycles — resistive load only. Initial Contact Resistance — 10 milliohms maximum 3 VDC, 100 ma for both silver and gold plated contacts. Insulation Resistance — 1 & 2 pole —1,000 megohms, min. 3 & 4 pole —1,000 megohms, min. Dielectric Strength — 1,000 volts rms at sea level. Bushing Strength — 12 pound-inches without physical damage to switch. Weight (including hardware) — SP 0.19 oz.; DP 0.23 oz.; 3-pole 0.28 oz.; 4-pole 0.32 oz. Base (body) — 1- and 2-pole —Diallyl Phthalate (DAP). 3- and 4-pole — high strength phenolic. Lever (toggle) — Brass, chrome plated. Flat Lever — Brass, satin chrome finish. Locking lever cap — Anodized aluminum. Bushing — Brass, nickel plated. Clamp (frame) — Stainless steel. Support brackets — Steel, tin plated. Switching Contacts and Rockers — Letter Code B — gold/nickel/brass Letter Code G — gold/nickel/silver Letter Code Q — Coin silver Center Terminal Letter Codes B, G — Gold flash/nickel/brass Letter Code Q — Silver plated brass. Hardware — See page 55-57. 38 Litho in U.S.A GG MINIATURE SWITCHES Toggle Switches — Base Dimensions and Lever Options APPROXIMATE BASE DIMENSIONS ONE POLE TWO POLE THREE POLE FOUR POLE TOGGLE LEVER OPTIONS K1 Locking Lever L0 Long (.840") L1 Long (.640") L2 Long (.550") L3 Plastic (.840") L4 Plastic (.571") Litho in U.S.A GG 39 MINIATURE SWITCHES Toggle Lever Options — Contd. M Short (.200") P1 Flatted (.840") P3 Flatted (.448") S Std. Bat (.410") T Large Toggle T1 Large Toggle P4 Flatted (.250") BUSHING OPTIONS CW Splashproof Sealed Lever and Panel Seal D D9 Threaded Smooth (No Keyway) CW = Flatted bushing H TW K High Torque Flatted with Shoulder H3 High Torque P Anti-Rotation Splashproof Sealed Lever and Panel Seal OX Y Y9 Threaded with Lever Seal Threaded Smooth (No Keyway) Y5 Long Bushing (.437") Refer to K1 lever drawing for dimensions. T &TX Refer to T or T1 lever drawing for dimensions. 40 Note: For hardware refer to pages 55-57. Litho in U.S.A GG MINIATURE SWITCHES Termination Options C Printed W Wire-Wrap W1 Wire-Wrap W3 Wire-Wrap W4 Wire-Wrap Z STANDARD CIRCUIT Z3 Quick CONNECT Mating Receptacle from AMP SPECIAL IND., P.O. Box 984, Paoli, Pa. 19301 Amp P/N single piece 61454 series, strip from 60900 NOTE: Wire-Wrap is a registered trademark of the Gardner-Denver Company. TERMINATION/MOUNTING OPTIONS A One Pole A Right Angle P.C. Terminal EPOXY SEAL STD. FOR THIS OPTION Two Pole A Three Pole R Contacts Make on Opposite Side Toggle Thrown One Pole R2 One Pole Litho in U.S.A GG Contacts Make on Opposite Side Toggle Thrown 41 MINIATURE SWITCHES Termination/Mounting Options AV1 w/.100" terminal spacing AV2 w/.150" terminal spacing (pictured below) ONE POLE Epoxy sealed P.C. terminals are supplied as standard for these options. AV1 w/.100" terminal spacing AV2 w/.150" terminal spacing (pictured below) TWO POLE Epoxy sealed P.C. terminals are supplied as standard for these options. AV w/.100" terminal spacing AV2 w/.150" terminal spacing (pictured below) THREE POLE Epoxy sealed P.C. terminals are supplied as standard for these options. AV w/.100" terminal spacing AV2 w/.150" terminal spacing (pictured below) FOUR POLE Epoxy sealed P.C. terminals are supplied as standard for these options. 42 Litho in U.S.A GG MINIATURE SWITCHES Termination/Mounting Options V30 1 Pole P.C. Mounting ONE POLE TWO POLE 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V40 1 Pole P.C. Mounting ONE POLE TWO POLE 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V60 1 Pole P.C. Mounting ONE POLE TWO POLE 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V70 1 Pole P.C. Mounting ONE POLE TWO POLE 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS Litho in U.S.A GG 43
A123S3CWZB 价格&库存
很抱歉,暂时无法提供与“A123S3CWZB”相匹配的价格&库存,您可以联系我们找货
A123S3CWZB
    • 1+196.947751+25.51426
