SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE
S SERIES - WASHABLE MINIATURE TOGGLE SWITCHES, P.C. MOUNTING
A
FEATURES
Wave solderable.
Fully sealed for process compatibility.
SPDT & DPDT models.
Compact case size with ESD protection options.
Agency recognition (see below).
SPECIFICATIONS
Contact ratings (resistive loads):
Initial contact resistance:
Insulation resistance:
Dielectric strength:
Electrical life:
Operating temperature range:
Washing:
Gold plated brass; 0.4 Volt-Amps max. at 20 V max.
Silver; 2 Amps at 250 VAC, 5 Amps at 125 VAC or 4 Amps at 30 VDC.
Gold plated silver; 2 Amps at 250 VAC, 5 Amps at 125 VAC or 4 Amps at 30
VDC. Gold plating withstands up to 300 mA at 30 VDC.
10 milliohms maximum
1000 megohms minimum
1000 V rms minimum
Gold: 2 positions - 100,000 cycles min. 3 positions - 50,000 cycles min.
Silver: 40,000 cycles minimum.
-20°C to +85°C
Permissible with water, detergents and freons.
MATERIALS
Contacts & Terminals:
Actuator:
Bracket:
Case:
Terminal seal:
Gold plated brass, silver or gold plated silver
Chrome plated brass
Tin plated steel
UL94V-0 - Polyamide, glass filled or PES
Epoxy
AGENCY RECOGNITION
UL, CECC, GAM T1 (military)
Availability: consult factory for details of recognized models.
Marking: to order switches marked UL or CECC, complete the appropriate box of the ordering
format.
GAM T1 listing does not appear on the switches.
ABOUT THIS SERIES
The material in this series is organized in the following sequence:
a. Completely specified switch models
b. 'build your own switch' order format
c. Option drawings & special options
d. Miscellaneous
A16
A16-A19
APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com
16
09:09:2000, 4:34 PM
Horizontal right angle terminals - .185" spacing - gold plated brass contacts
12.70
(.500)
0.80
(.031)
3.81
(.150)
0.50
(.019)
11.65
(.458)
5.08
(.200)
EPOXY
6.90
(.271)
3.90
(.153)
4.70
(.185)
12.70
(.500)
1
4.70
(.185)
3.81
(.150)
2
1.10
(.043)
3
1.10
(.043)
12.70
(.500)
6.10
(.240)
7.50
(.295)
1.60 DIA
(.062 DIA)
12.70
(.500)
* Function 4: SP in DP case - see diagram at end of section.
4.70
(.185)
6.20 DIA
(.244 DIA)
0.40
(.015)
ON
ON
MOM
MOM
MOM
ON
I
2-1
4-5
2.70 DIA
(.106 DIA)
SP
DP
Horizontal right angle terminals - .200" spacing - gold plated brass contacts
6.10
(.240)
7.50
(.295)
2
1
0.60
(.023)
3.81
(.150)
0.60
(.023)
11.65
(.458)
5.08
(.200)
EPOXY
6.90
(.271)
3.90
(.153)
5.08
(.200)
12.70
(.500)
3
12.70
(.500)
1.10 DIA
(.043 DIA)
0.60
(.023)
0.40
(.015)
6.20 DIA
(.244 DIA)
12.70
(.500)
5.08
(.200)
(.200)
3.81
(.150)
5.30
(.208)
ON
ON
MOM
MOM
MOM
ON
I
2-1
4-5
0.60
(.023)
OFF
OFF
OFF
ON
II
I
CIRCUIT
ON
ON
MOM
ON
ON
ON
III
2-3
5-6
II
SW036CD7
SW046CD7
SW039CD7
SW049CD7
SW037CD7
SW047CD7
SW038CD7
SW048CD7
SW032CD7
SW042CD7
SW044THCD7*
Handle position (see dwg.) :
Terminals connected:
SP & DP
DP
2.70 DIA
(.106 DIA)
12.70
(.500)
5.08
(.200)
SINGLE POLE DOUBLE POLE
MODEL NO.
MODEL NO.
III
OFF
OFF
OFF
ON
II
I
ON
ON
MOM
ON
ON
ON
III
2-3
5-6
II
SW236CD7
SW246CD7
SW239CD7
SW249CD7
SW237CD7
SW247CD7
SW238CD7
SW248CD7
SW232CD7
SW242CD7
SW244THCD7*
SP & DP
DP
5.30
(.208)
CIRCUIT
5.08
(.200)
III
MODEL NO.
MODEL NO.
A
SP
DP
Vertical right angle terminals - gold plated brass contacts
5.30
(.208)
1.10
(.043)
5.08
(.200)
4.75
(.187)
3.10
(.122)
13.00
(.511)
1.60 DIA
(.062 DIA)
12.70
(.500)
2
3
EPOXY
11.35
(.446)
3.81
(.150)
1
6.60
(.259)
3.81
(.150)
12.70
(.500)
6.20 DIA
(.244 DIA)
0.50
(.019)
ON
ON
MOM
MOM
MOM
ON
I
2-1
4-5
0.80
(.039)
OFF
OFF
OFF
ON
II
6.10 7.50
(.240) (.295)
CIRCUIT
ON
ON
MOM
ON
ON
ON
III
2-3
5-6
5.08
(.200)
3.81
(.150)
III
(.500)
II
SWW236CD7 SWW246CD7
SWW239CD7 SWW249CD7
SWW237CD7 SWW247CD7
SWW238CD7 SWW248CD7
SWW232CD7 SWW242CD7
SWW244THCD7*
SP & DP
DP
I
2.70 DIA
(.106 DIA)
MODEL NO.
MODEL NO.
4.75
(.187)
DP
SP
Straight p.c. terminals - mounting bracket - gold plated brass contacts
II
I
EPOXY
3
1.17
(.046)
3.18
(.125)
2
1
4.70
(.185)
4.70
(.185)
1.60 DIA
(.062 DIA)
0.40
(.015)
8.10
(.318)
15.75
(.620)
4.70
(.185)
11.35
(.446)
15.75
(.620)
6.20 DIA
(.244)
15.75
(.620)
5.90
(.232)
ON
ON
MOM
MOM
MOM
ON
I
2-1
4-5
11.70
(.460)
OFF
OFF
OFF
ON
II
7.50
(.295)
ON
ON
MOM
ON
ON
ON
III
2-3
5-6
3.18
(.125)
2.70 DIA
(.106 DIA)
CIRCUIT
4.70
(.185)
SY236CD7
SY246CD7
SY239CD7
SY249CD7
SY237CD7
SY247CD7
SY238CD7
SY248CD7
SY232CD7
SY242CD7
SY244THCD7*
SP & DP
DP
5.30
(.208)
III
MODEL NO.
MODEL NO.
4.75
(.187)
SP
DP
A16-A19
17
09:09:2000, 4:34 PM
A17
A
Additional ordering information: Commonly ordered models are shown above with complete model numbers and specifications.
Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply
selecting from all available options shown and filling in the boxes.
Fill in boxes with selections shown for Model Structure, then add Options selections for complete model number.
Allowable options are shown below each respective box.
Note: 'NONE' indicates box may be left empty.
Model Structure:
Series
Terminals
Bushing & terminals
Number of poles
Electrical functions
S
W
horizontal
rt. angle mtg.
W W vertical
rt. angle mtg.
Y
Bracket mtg.
2
Terminal spacing
.185" (4,7mm) or
.150" (3,81mm)
Terminal spacing
.200" (5,08mm)
(SY & SW models)
All models have plain bushing
3
4
Single pole
Double pole
6
9
7
8
2
4
ON
T
ON
MOM
ON
ON
H ON
ON
OFF
OFF
OFF
ON
ON
MOM
MOM
MOM
ON
Options:
Contact materials
A
Silver
A D Silver,
gold plated
C D Brass,
gold plated
Actuators
7
1
3
Agency recognition
Short
(standard)
Long
Insulated actuators:
1 1 Long
8
Short
(NONE)
U L
C E C C
Consult factory
for availability.
Special options
(NONE)
F
X
6
X
6
9
6
Examples of completely specified
model numbers:
Tin plated
terminals
Silver plated
brass contacts
Longer bushing
(for insulated
actuators)
SW236CD7, SW244THAD11ULX696
Although most combinations of options are available, some may result in incompatibilities. Consult factory if there is any question.
OPTION DRAWINGS
ACTUATORS
2.90 DIA
(.114 DIA)
2.90 DIA
(.114 DIA)
6.80
(.267)
7.50
(.295)
7.50
(.295)
6.30
(.248)
6.30
(.248)
13.30
(.523)
2.70
(.106)
7.50
(.295)
3.00 DIA
(.118 DIA)
INSULATED
Protects against electrostatic discharges (ESD) up to 12 KV.
Color: black Note: must be ordered with option X696.
13.00
(.511)
CHROME PLATED BRASS
7 Standard
13 Long
8 Short
11 Long
SPECIAL OPTIONS
F
X601
X696
A18
A16-A19
Tin plated terminals.
Silver plated brass contacts. Lower rating. Minimum quantity: 5000 pcs.
Longer bushing - .295" (7.5mm). Specify for actuators 8 and 11.
18
09:09:2000, 4:34 PM
'BUILD YOUR OWN SWITCH' ORDER FORMAT
A
OPTION DRAWINGS & MISCELLANEOUS
1
2
3
4
5
6
7/1
9
11.00
(.433)
3.50
(.137 DIA)
3.50
(.137 DIA)
7.30
(.287)
INSULATING CAPS (replace '0' in part numbers with color code)
U270 For actuator 13
blue
black
green
grey
yellow
red
white
orange
U1710 For actuator 7
WIRING for function 4 switch
6
6
5
5
III
4
6
II
5
I
4
4
S.4 I
E
3
6
9
12
3
6
9
12
3
6
9
12
2
5
8
11
2
5
8
11
2
5
8
11
1
4
7
10
1
4
7
10
1
4
7
10
5
S.1 II
S.3 III
S.10I
TH
E
11
S.7 II
S.9 III
Above diagrams are viewed from bottom of switch.
Equivalent to single pole 3 throw switch. Dotted lines between
terminals 2 & 6 and 8 & 12 indicate external jumpers to be added by customer
A16-A19
19
09:09:2000, 4:34 PM
A19
很抱歉,暂时无法提供与“SW249CD7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+267.46200
- 200+106.72560
- 500+103.15080
