S series
SW
PANEL SWITCHES
L
G
G
O
ST
1
71
1
E-
Washable miniature toggle switches •
plain bushing
DISTINCTIVE FEATURES
Process sealed
Front and rear sealing
Process compatible
Wave solderable
Washable
ENVIRONMENTAL SPECIFICATIONS
• Operating temperature : -20 °C to +85 °C (-4 °F to +185 °F)
• Storage temperature : -40 °C to +85 °C (-40 °F to +185 °F)
• Moisture : The insulating materials employed and the complete seal
permit the switches to withstand a 56 days moisture test (IEC 68-2-3).
• Solderability : The switches are tested at 235 °C ( 455 °F) according to
IEC 68-2-20 after accelerated aging.
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 4 A 30 VDC
- gold plated brass contacts (CD) : 0.4 VA 20 VAC or DC
- gold plated silver contacts (AD) : 4 A 30 VDC (300 mA 30 VDC for
gold plating)
• Initial contact resistance : 10 mΩ max.
• Insulation resistance : 1,000 MΩ min.
• Dielectric strength : 1,000 Vrms 50 Hz min.
• Electrical life at full load :
Contacts
Number of cycles
2 positions
3 positions
A
40,000
40,000
CD
100,000
50,000
AD
40,000
40,000
The company reserves the right to change specifications without notice.
1
plain bushing
ELECTRICAL FUNCTIONS
GENERAL SPECIFICATIONS
• Mechanical strength : Terminals are strengthened by a
bracket or a ground plate ensuring the rigidity of the switch
on the board. Actuator strength is 10 N max.
• Soldering - thermal shock : The switches are especially
designed for flow soldering at 260 °C (500 °F) during
5 seconds owing to high temperature polymer parts.
1
MATERIALS
2
3
CAP FOR PCB PROCESSING
• Case and cover : UL94-VO, polyamide, glass filled or PES
• Actuator : brass, nickel plated
• Contacts
CD : brass, gold plated
A : silver
AD : silver, gold plated
• Provide additional protection during PCB
processing.
• Supplied mounted on the switch or separately.
• Material : vinyl
16.00
(.629)
• Terminal seal : epoxy
Ø4.76
(.187 DIA)
AGENCY APPROVALS
U3012
17.45
(.687)
2 A 250 VAC
4 A 125 VAC
Ø3.96
(.155 DIA)
CECC 96201-006
2
2.00
(.078)
17.10
(.673)
13.00
(.511)
6.65
(.261)
11.65
(.458)
6.00
(.236)
6.90
(.271)
PCB MOUNTING
3.60
(.141)
PANEL SWITCHES
S series
plain bushing
BUILD YOUR PART NUMBER
BASIC PART NUMBER
S
TERMINALS
SERIES
W
Right angle,
horizontal
mounting
WW
Right angle,
vertical
mounting
Y
TERMINAL SPACING
2
Terminal spacing
4.7 (.185) or 3.81
(.150)
Terminal spacing
5.08 (.200)
(SW switches)
NUMBER OF POLES
3
Single pole
6
ON
ON
4
Double pole
9
ON
OFF
ON
7
MOM
OFF
MOM
8
ON
OFF
MOM
2
ON
MOM
4TH
ON
ON
Bracket
mounting
ON
OPTIONS
LEVERS
CONTACT MATERIALS
A
Silver
AD
Silver, gold
plated
CD
Brass, gold
plated
-7
-13
Short
Standard
Long
Insulated levers
-11
Long
-8
Short
APPROVALS
UL
CECC
Availability :
Consult factory
for details of
approved models.
SPECIAL OPTIONS
X601
Silver plated
brass contacts
X696
Higher bushing
(for insulated
levers)
INSULATING CAPS
U270
For lever 13
U1710
For lever 7
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information.
3
PANEL SWITCHES
S series
plain bushing
ON
SWW237
SWW247
MOM
OFF
MOM
SWW238
SWW248**
ON
OFF
MOM
SWW232
SWW242**
ON
MOM
SWW244TH* ON
ON
4.75
(.187)
ON
III
2-1
4-5
Double pole
SY236
SY246
ON
ON
SY239
SY249
ON
OFF
ON
SY237
SY247
MOM
OFF
MOM
SY238
SY248
ON
OFF
MOM
SY232
SY242
ON
MOM
SY244TH*
ON
ON
Single pole
Double pole
SW036
SW046
ON
ON
SW039
SW049
ON
OFF
ON
SW037
SW047
MOM
OFF
MOM
SW038
SW048
ON
OFF
MOM
SW042
ON
MOM
SW044TH*
ON
ON
SW032
ON
* Function 4 : SP in DP case - TH connection, see "Technical information" on website.
** Functions 2 and 8 : reversed connection available. On request.
4
EPOXY
3
2
12.70
(.500)
12.70
(.500)
3.81
(.150)
3.18
(.125)
Ø2.70
(.106 DIA)
Ø1.60
(.062 DIA)
0.40
(.015)
1
0.90
(.035)
ON
III
2-1
4-5
4.75
(.187)
11.35
(.446)
8.20
(.322)
4.70
(.185)
3.18
(.125)
15.75
(.620)
4.75
(.187)
5.08
(.200)
Ø2.70
(.106 DIA)
5.30
(.208)
20˚
6.10
(.240)
II
Ø6.20
(.244)
Ø6.20
(.244 DIA)
3.90
(.153)
5.08
(.200)
Ø1.10
(.043 DIA)
12.70
(.500)
12.70
(.500)
I
2-3
5-6
5.08
(.200)
1.10
(.043)
20˚
4.40
(.173)
Single pole
RIGHT ANGLE TERMINALS - HORIZONTAL SPACING 5.08 (.200)
5.30
(.208)
Ø1.60
(.062 DIA)
6.60
(.259)
3.10
(.122)
13.00
(.511)
0.60
(.023)
II
2
3
EPOXY
BRACKET MOUNTING
I
2-3
5-6
1
12.70
(.500)
12.70
(.500)
1.10
(.043)
11.35
(.446)
3.81
(.150)
ON
OFF
12.70
(.500)
ON
3.81
(.150)
ON
SWW249
Ø6.20
(.244 DIA)
4.70
(.185)
SWW246
SWW239
5.08
(.200)
4.70
(.185)
SWW236
Ø2.70
(.106 DIA)
20˚
12.70
(.500)
Double pole
5.30
(.208)
0.80
(.039)
Single pole
III
I
2-3
5-6
4.70
(.185)
3
EPOXY
6.90
(.271)
0.60
(.023)
2
1
5.08
(.200)
0.60
(.023)
5.08
(.200)
11.65
(.458)
12.70
(.500)
III
2-1
4-5
RIGHT ANGLE TERMINALS - VERTICAL
11.65
(.458)
4.70
(.185)
5.08
(.200)
3.81
(.150)
II
3.90
(.153)
15.75
(.620)
ON
15.75
(.620)
ON
0.40
(.015)
ON
3.81
(.150)
SW244TH*
0.50
(.019)
6.90
(.271)
5.08
(.200)
0.80
(.031)
0.40
(.015)
MOM
Ø1.60
(.062 DIA)
3.81
(.150)
1
1.10
(.043)
ON
4.70
(.185)
6.10 7.50
(.240) (.295)
SW242
2
12.70
(.500)
SW232
3
EPOXY
3.81
(.150)
MOM
5.90
(.232)
OFF
11.70
(.460)
ON
0.60
(.023)
SW248
7.50
(.295)
SW238
5.08
(.200)
12.70
(.500)
0.50
(.019)
MOM
7.50
(.295)
ON
OFF
7.50
(.295)
OFF
MOM
6.10
(.240)
ON
SW247
I
SW249
SW237
II
SW239
Ø6.20
(.244 DIA)
ON
III
I
ON
II
SW246
III
Double pole
SW236
5.30
(.208)
20˚
II
Single pole
Ø2.70
(.106 DIA)
I
I
2-1
4-5
I
2-3
5-6
Shown with lever -7
II
SPACING 4.7 (.185)
II
III
III
PANEL SWITCHES
S series
plain bushing
CONTACT MATERIALS
BASIC P/N
A
AD
AC
Silver
Silver, gold plated
Brass, gold plated
LEVERS
BASIC P/N
METAL LEVERS
INSULATED LEVERS
13.00
(.511)
7.50
(.295)
7.50
(.295)
6.80
(.267)
6.30
(.248)
13.30
(.523)
Ø2.70
(.106)
6.30
(.248)
Ø2.90
(.114 DIA)
Ø2.90
(.114 DIA)
7.50
(.295)
Ø3.00
(.118 DIA)
-7
Standard
-13
Long
-8
Short
If actuator not specified, we supply former default
option -13.
-11
Long
Protected against electrostatic discharges (ESD) up to
12 KV. Black color.
To combine with option X696.
SPECIAL OPTIONS
BASIC P/N
X601
X696
Silver plated brass contacts
Lower rating - Minimum quantity : 5,000 pieces per model and shipment.
Higher bushing 7.50 (.295). Compulsory for insulated levers 11 and 8.
AGENCY APPROVALS
BASIC P/N
UL
CECC
Blank No agency approval required.
Availability : consult factory for details of approved models.
Marking : to order switches marked UL or CECC, please complete above box with desired approvals.
5
PANEL SWITCHES
S series
plain bushing
INSULATING CAPS
+ U...
Ø3.50
(.137 DIA)
U1710
For lever 7
11.00
(.433)
BASIC P/N
7.30
(.287)
PANEL SWITCHES
S series
Ø3.50
(.137 DIA)
U270
For lever 13
For cap colors, replace "0" with number :
1
Blue
1/4
Dark blue
2
Black
3
Green
4
Grey
5
Yellow
6
Red
7/1
White
9
Orange
6
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
SW232AD13UL SW236A13 SW236AD7 SW237CD13 SW239A7 SW246A7 SWW232A7 SWW236A13
SWW236A7 SWW236AD7UL SWW239A7 SWW246A7 SWW249A7 SY236A13 SY246A13 SW232CD7 SW236A7
SW236AD8X696UL SW236CD7 SW237CD8X696 SW239CD7 SW246CD7 SW248CD7 SWW236CD7
SWW237CD7 SWW238CD7 SWW239CD7 SWW246CD7 SWW249CD7 SY232CD7 SY236CD7 SY237CD7
SY239CD7 SY244THCD7 SY246CD7 SY247CD7 SY239A7X403UL SWW237A11X696 SY236CD13
很抱歉,暂时无法提供与“SW248CD7”相匹配的价格&库存,您可以联系我们找货
