MINIATURE SWITCHES
Ordering Table — Washable Toggle Switches
Designed to be wave soldered along with other Printed Circuit Board Components and withstand associated cleaning processes.
HOW TO ORDER YOUR DESIGN (Bold Face Type indicates items normally in Distributor Stock)
To determine a part number select the options desired and fill in
Following the table from left to right, the designer is able to specify
the boxes in the selection guides illustrated below.
the options wanted. The options are described and illustrated on
The following pages.
WashableToggle Switch Selection Guide
Poles
and
Throw
Toggle
Series
Series
Lever
Options
Circuit
Poles and Throw
Lever
Finish
Circuits
Bushing
Options
Terminal
Type
Lever Options and Finishes
Contact
Material
Bushing Options
Terminal Options
Contact Material
Keyway
Type
Code
No.
Code
Toggle
WT
SPDT
1
DPDT
Code
POS. "C"
2
ON
OFF
ON
21
Type
Code
Finish
Code
Type
.940 BAT.
L0
Bright Chrome
1
.250 Smooth
.740 BAT.
ON
NONE
ON
23
ON
NONE
ON*
26
.650 BAT.
Long Mod Cap
ON*
OFF
ON*
27
Short Mod Cap
ON
OFF
ON*
31
.510 BAT.
.300 BAT.
ON
ON
ON
32
ON
ON
ON*
33
ON*
ON
ON*
35
L1
Black
3
.280 Smooth
L2
Black Nylon
4
L3
L4
S
M
Red Nylon
5
White Nylon
6
.350
Threaded
.350
Smooth
*Momentary Contact
2 Pole Only.
Subtract .030 from lever length when using this bushing.
Available on S and M lever options only.
Available only with L3 and L4 lever options only.
Type
Code
Type
Code
D1
Right Angle PC
A
AV2
Gold/Brass
B
G
D9
Vertical PC
.150 Spacing
Y
PC Terminals
PC & Support
Coin/Silver
Y9
.750 Wire Wrap
.964 Wire Wrap
C
V30
W
W1
W3
W4
Z
Z3
Code
.425 Wire Wrap
1.062 Wire Wrap
Solder Lug
Quick Connect
Gold/Silver
Q
K
L
M
Subtract .100 from lever length when using these bushings.
Refer to page 59 for construction detail, wiring and electrical diagrams.
Not available on A, AV2, V30 terminal options.
Same as B, G and Q respectively except terminals brass with tin nickel alloy over nickel plate.
Consult plant for availability.
EXAMPLES:
WT123M1D9AB =
SPDT toggle switch with an ON-NONE-ON circuit, .270" long lever (see note 2 above) with a bright chrome finish, .280"
smooth bushing right angle P.C. terminals with gold/brass contacts.
WT232S1D1V30G =
DPDT toggle switch with an ON-ON-ON circuit, .510" long lever with a bright chrome finish, .250" smooth bushing,
P.C. terminals with support bracket and gold/silver contacts.
SPECIFICATIONS:
MATERIALS:
Contact Ratings —
Letter codes G and Q — 6 amp at 125 VAC, 3 amp @ 250 VAC (U.L.
recognized, CSA certified) or 6 amp at 28 VDC resistive.
Letter codes B and G – 0.5 volt amp (VA) maximum @ 28 V
maximum (AC or DC).
Base & Bushing —Thermoplastic high temperature
(UL 94V-O).
Life Under Load — 60,000 make-and-break cycles — resistive
load only.
Initial Contact Resistance — 10 milliohms maximum 3 VDC, 100
ma for both silver and gold plated contacts.
Lever (toggle) — Brass, chrome plated.
Support brackets — Brass or steel tin plated.
Switching Contacts and Rockers —
Letter Code B — gold/nickel/brass
Letter Code G — gold/nickel/silver
Letter Code Q — Coin silver
Insulation Resistance — 1,000 megohms, min.
Dielectric Strength — 1,000 volts rms at sea level.
Operating Temperature — -30 degrees C to 65 degrees C.
Center Terminal
Letter Codes B and G — Gold flash/nickel/brass
Letter Code Q — Silver plated brass.
Hardware — See pages 55-57.
44
Litho in U.S.A GG
MINIATURE SWITCHES
Washable Toggle Switches — Base Dimensions and Lever Options
APPROXIMATE BASE DIMENSIONS
ONE POLE
TWO POLE
TOGGLE LEVER OPTIONS
S
Std. Bat. (.510")
L0
Long (.940")
L3
Plastic (.940")
Litho in U.S.A GG
M
L1
Short (.300")
Long (.740")
L2
L4
Long (.650")
Plastic (.671")
45
MINIATURE SWITCHES
BUSHING OPTIONS
D1
Y
Standard (.250") Smooth
D9
(.280") Smooth
(.350") Threaded
Y9
(.350") Smooth
TERMINATION OPTIONS
C Printed Circuit
W Wire-Wrap
W1 Wire-Wrap
W3 Wire-Wrap
W4 Wire-Wrap
Z Standard
Z3 Quick Connect
Mating Receptacle from
AMP SPECIAL IND., P.O.
Box 984, Paoli, Pa. 19301
Amp P/N single piece
61454 series, strip from
60900
NOTE: Wire-Wrap is a registered trademark of the Gardner-Denver Company.
TERMINATION & MOUNTING OPTIONS
A
ONE POLE
P.C. MOUNTING
A
TWO POLE
46
P.C. MOUNTING
Litho in U.S.A GG
MINIATURE SWITCHES
TERMINATION & MOUNTING OPTIONS — Contd.
AV2
P.C. MOUNTING
ONE POLE
AV2
P.C. MOUNTING
TWO POLE
V30
P.C. MOUNTING
ONE POLE
V30
P.C. MOUNTING
TWO POLE
Litho in U.S.A GG
47
很抱歉,暂时无法提供与“WT232M1D1V30B”相匹配的价格&库存,您可以联系我们找货
