15-Serie_IA-A_09-Serie IA-A 21/11/12 14:39 Page85
IA series
Low profile pushbutton switches for harsh environments - bushing Ø 16 mm - momentary
Distinctive features - Specifications - Overview
❑ Resistant to frost, sand and hydrocarbons
❑ Tactile feedback
❑ Front panel sealed to IP67
B1
ENVIRONMENTALSPECIFICATIONS
MATERIALS
• Front panel sealing (see drawing opposite) : IP67
• Salt spray : IEC 512-6, test 11f
• Operating temperature : -20°C to +65°C
• Case/bushing : thermoplastic
• Actuator : polyurethane
• Contacts : silver, gold plated
• Multi-wire lead AWG20,
section 0,6 mm2.
• Terminal seal : epoxy
ELECTRICALANDGENERALSPECIFICATIONS
• Max. current/voltage rating with resistive load : 2A 24VDC
• Initial contact resistance : 100mΩ max.
• Insulation resistance : 100 MΩ min. at 500VDC
• Dielectric strength : 500 Vrms
• Electrical life at full load : 1.000.000 cycles
PANELMOUNTING
➀ Flat seal
1
• Panel thickness : 7 mm (.276) max.
• Total travel : 1,5 mm (.059) +/- 0,3 mm
• Typical operating force : 7N +/- 2N
• Low level or mechanical life : 1.000.000 cycles
• Torque : 0,5 to 1Nm max. applied to nut
IA
Actuator
shape
SERIES
R
round
Electrical
functions
3 Normally
open (NO)
5 NC/NO
combined
Terminals
F
Flying leads
Contacts
1
Silver,
gold plated
Actuator colours
Case colour
1
2
3
5
6
7/1
9
00 Black
Blue
Black
Green
Yellow
Red
White
Orange
Dimensions : First dimensions are in mm while inches are shown as bracketed numbers.
A sealing boot is available to protect the switches against frost and sand. See end of this catalogue.
Mounting accessories : Standard hardware supplied : 1 hex nut 19 mm (.748) across flats and 1 flat seal.
Knurled nut U3327 available on request.
Packaging unit : 25 pieces
APEMwww.apem.com
B1-85
15-Serie_IA-A_09-Serie IA-A 21/11/12 14:39 Page86
IA series
• Panel cut-out Ø 16,2 mm (.657)
• Min. pitch for matrix mounting :
- with standard hex nut : 27 x 27 mm (1.062 x 1.062)
- with knurled nut U3327: 20 x 20 mm (.787x.787)
C
NO
NO
NC/NO combined
MODEL
STRUCTURE
Normally open (NO)
Ø15.00
(.590 DIA)
15.50
(.610)
18.50 maxi
(.728MAX.)
1.20
(.047)
Ø16.00x1.00SI
(.629DIAx1.00IS)
IAR3F
EPOXY
NC/NO combined
IAR5F
C NC
NO
500.00±10
(19.685±.393)
Models
3.30
(.129)
NO model has 2 terminals only.
10.00
(.393)
B1
NC
Ø19.80
(.779 DIA)
Wire colours (NC/NO) : black = common, brown = NC, blue = NO
CONTACT MATERIAL
1
Silver, gold plated
ACTUATOR COLOURS
1 : blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7/1 : white - 9 : orange
CASE COLOUR
00 : black
B1-86
www.apem.com
APEM
很抱歉,暂时无法提供与“IAR3F1200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+148.655841+19.23260
- 10+135.3798810+17.51500
- 25+124.9861925+16.17030
- 50+115.7279650+14.97250
- 100+106.55706100+13.78600
- 125+105.07225125+13.59390
- 250+101.31655250+13.10800
- 国内价格
- 1+136.14480
- 200+54.32400
- 500+52.50960
- 国内价格 香港价格
- 3+257.797203+33.35295
- 5+211.533945+27.36757
- 10+182.8535710+23.65699
- 25+125.5284525+16.24046
- 50+123.7502750+16.01040
