9533NCD
9533NCD
    APEM(埃斐)
    按动开关 25万次 面板安装,后部 单刀单掷-常开 100mA 30V -30℃~+65℃
9533NCD 数据手册
PANEL SWITCHES SW 0- 10 -9 95 0- 0 92 01 18 00 9100-9200-9500 series Subminiature momentary pushbutton switches DISTINCTIVE FEATURES Panel and PC mount models, horizontal or vertical Self-cleaning and butt action contacts Several plunger options ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 100 mA 30 VDC • Initial contact resistance : 30 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 1,000 Vrms 50 Hz min. between terminals and frame • Electrical life at full load : 9100 - 9200N and 9500N : 250,000 cycles 9200 - 9500 : 100,000 cycles GENERAL SPECIFICATIONS • Torque : 0.5 Nm (.590 Ft.lb) max. applied to nut • Operating temperature : -30 °C to +65 °C (-22 °F to +146 °F) • Panel thickness : 1.50 mm (.059) max. • Travels : see table below . Tolerance : ± 0.3 mm (.011) 9533-9233 9532-9232 9533N 9233N-9133 Total travel 1.10 (.043) 1.80 (.070) 1 (.039) Pre-travel 0.80 (.031) 1.00 (.039) - Over travel 0.30 (.011) 0.75 (.029) - MATERIALS • Case : Pa6T • Actuator : polyamide, glass filled • Bushing : brass, nickel plated • Contacts : CD : brass, gold plated • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 Subminiature momentary pushbutton switches STANDARD HARDWARE TERMINALS (FOR THREADED BUSHING MODELS) 5.00 (.196) 1.50 (.059) 2.00 (.078) 4.00 (.157) 5.00 (.196) 3.00 (.118) 1.00 (.039) 1.00 (.039) 0.80 (.031) PANEL SWITCHES 9100-9200-9500 series 0.60 (.023) M4 X 0.70 SI (.157 DIA X 0.70 IS) U544 (nickel plated) ELECTRICAL FUNCTIONS Function 2 (NC) Function 3 (NO) PANEL CUT-OUT Ø4.20 (.165 DIA) 2 Subminiature momentary pushbutton switches BUILD YOUR PART NUMBER BASIC PART NUMBER 9 SERIES NUMBER OF POLES TERMINALS, CASE AND BUSHING 3 Case height 8 (.314) 2 Single pole Straight terminals - threaded bushing 2..Y ELECTRICAL FUNCTIONS 2 Normally closed (NC) 3 Normally open (NO) Tall bracket - plain bushing 2..WW 5 Right angle terminals - plain bushing Solder lugs - threaded bushing Case height 6.1 (.240) Straight terminals - threaded bushing 7.10 (.279) PCB to panel 1 1..Y Short bracket - plain bushing 1..WW Right angle terminals - plain bushing Straight terminals - threaded bushing 8.90 (.350) PCB to panel 2..N 2..NY Tall bracket - plain bushing 5..N Solder lugs - threaded bushing OPTIONS PLUNGER CONTACT MATERIALS CD Blank Gold plated brass (standard) MOUNTING BEZEL Standard -0 Flush -4 Long U4922 CAPS SEALING Blank Epoxy sealed terminals standard K Front panel sealing by two O-rings For 9500 model only. For plunger -4 U4310 Height 4 (.157) U4320 Height 3.9 (.153) ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Sealing boots are available to protect the switches. See "Sealing Boots" section of website. Mounting accessories : standard hardware supplied with all threaded bushing models : 1 nickel plated hex nut 5 (.196) across flats, part number U544. This nut is presented on previous page. 3 PANEL SWITCHES 9100-9200-9500 series Subminiature momentary pushbutton switches LONG CASE - SOLDER LUGS : 9500 3.50 (.137) Ø2.45 (.096 DIA) Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) Ø6.50 (.255 DIA) 8.00 (.314) Normally Closed 3.00 (.118) 9532 0.20 (.008) Normally Open 2.00 (.078) 3.00 (.118) 9533 2.54 (.100) EPOXY LONG CASE - STRAIGHT PC TERMINALS : 9200 Normally Closed 0.20 (.008) 2.54 (.100) 3.50 (.137) Ø1.10 (.043 DIA) 3.50 (.137) 2.70 (.106) 0.60 (.023) 9.50 (.374) Normally Open 5.08 (.200) 9233WW Ø3.00 (.118 DIA) 0.60 (.023) 0.60 (.023) 4 Ø1.10 (.043 DIA) 10.16 (.400) 5.08 (.200) 2.54 (.100) 2.54 (.100) 5.08 (.200) 10.16 (.400) Ø6.5 (.255) EPOXY 3.00 (.118) Normally Closed 7.62 (.300) 7.62 (.300) 0.20 (.008) 9232WW 0.40 (.015) 2.54 (.100) 5.08 (.200) LONG CASE - RIGHT ANGLE TERMINALS : 9200WW 5.08 (.200) EPOXY 0.20 (.008) 2.54 (.100) Normally Open 4.00 (.157) 0.60 (.023) 9233Y Ø3.00 (.118 DIA) 9.30 (.366) Normally Closed Ø2.45 (.096 DIA) 2.60 (.102) 9232Y EPOXY 0.60 (.023) 3.25 (.127) Normally Open LONG CASE - STRAIGHT PC TERMINALS BRACKET MOUNTING : 9200Y Ø1.10 (.043 DIA) 5.00 (.196) 9233 Ø6.50 (.255 DIA) 8.00 (.314) 3.00 (.118) 9232 Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 2.54 (.100) 3.50 (.137) Ø2.45 (.096 DIA) Ø2.45 (.096 DIA) PANEL SWITCHES 9100-9200-9500 series Subminiature momentary pushbutton switches SHORT CASE - SOLDER LUGS : 9500N Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 6.10 (.240) 3.50 (.137) Ø2.45 (.096 DIA) 0.40 (.015) 2.00 (.078) EPOXY 3.00 (.118) 2.54 (.100) SHORT CASE - STRAIGHT PC TERMINALS 8.90 (.350) PCB TO PANEL 6.10 (.240) 0.60 (.023) 2.54 (.100) SHORT CASE - STRAIGHT PC TERMINALS 7.10 (.279) PCB TO PANEL 3.00 (.118) 7.10 (.279) 6.10 (.240) 0.20 (.008) EPOXY 0.60 (.023) Ø3.00 (.118 DIA) EPOXY 0.40 (.015) 0.40 (.015) 2.54 (.100) 0.60 (.023) 0.60 (.023) 7.62 (.300) 4.00 (.157) Normally Open 9.30 (.366) 2.60 (.102) 9233NY Ø2.45 (.096 DIA) 3.50 (.137) 2.54 (.100) SHORT CASE - STRAIGHT PC TERMINALS TALL BRACKET : 9200NY Ø1.10 (.043 DIA) 4.00 (.157) Normally Open Ø1.10 (.043 DIA) 5.08 (.200) 7.62 (.300) Ø6.50 (.255 DIA) 9133 Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 3.25 (.127) Ø2.45 (.096 DIA) 2.54 (.100) EPOXY 0.40 (.015) Ø1.10 (.043 DIA) 4.00 (.157) Normally Open 8.90 (.350) 3.00 (.118) Ø6.50 (.255 DIA) 9233N Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 3.50 (.137) Ø2.45 (.096 DIA) 2.54 (.100) Normally Open 2.54 (.100) 9533N 3.00 (.118) Ø6.50 (.255 DIA) 5.08 (.200) 5 PANEL SWITCHES 9100-9200-9500 series Subminiature momentary pushbutton switches 3.50 (.137) Ø3.00 (.118 DIA) 2.60 (.102) EPOXY 0.40 (.015) Ø1.10 (.043 DIA) 0.60 (.023) 0.20 (.008) 2.54 (.100) 0.60 (.023) 5.08 (.200) 2.54 (.100) 7.62 (.300) 5.08 (.200) 7.62 (.300) Normally Open 4.00 (.157) 9133Y Ø2.45 (.096 DIA) 7.70 (.303) SHORT CASE - STRAIGHT PC TERMINALS SHORT BRACKET : 9100Y Ø6.5 (.255) 0.40 (.015) 3.25 (.127) EPOXY 0.60 (.023) 0.60 (.023) Ø1.10 (.043 DIA) 10.16 (.400) 5.08 (.200) 2.54 (.100) 5.08 (.200) 10.16 (.400) Ø3.00 (.118 DIA) 0.60 (.023) 7.60 (.299) Normally Open 2.70 (.106) 3.00 (.118) 9133WW 3.50 (.137) 5.08 (.200) SHORT CASE - RIGHT ANGLE TERMINALS VERTICAL : 9100WW Ø2.45 (.096 DIA) PANEL SWITCHES 9100-9200-9500 series CONTACT MATERIALS BASIC P/N CD Gold plated brass (standard) SEALING BASIC P/N Blank Epoxy sealed terminals standard K Front panel sealing by two O-rings. Protects the switch against water and dust. Panel seal withstands 0.1 bar pressure. Option K for models 9533N, 9233N and 9133 only. 6 1 O-ring 2.54 (.100) Subminiature momentary pushbutton switches PLUNGERS C95NP4-A BASIC P/N Ø2.45 (.096 DIA) Blank Standard with long case Blank Standard with short case Ø2.45 (.096 DIA) Ø2.5 (.098 DIA) -4 Long with long case 6.10 (.240) 4.30 (.169) 8.00 (.314) 4.70 (.185) 6.10 (.240) 3.20 (.126) Ø2.45 (.096 DIA) 8.00 (.314) 3.50 (.137) Ø2.45 (.096 DIA) -4 Long with short case -0 Flush C95NP13-A CAPS + U... U4310 For use with plunger -4 only U4320 For use with plunger -4 only U4310 3.90 (.153) 3.00 (.118) 4.00 (.157) For cap colors, replace "0" with number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7 Ivory 7/1 White 9 Orange Ø5.00 (.196 DIA) Ø6.50 (.255) 3.00 (.118) BASIC P/N U4320 If not combined with bezel U4922, caps are to be ordered separately. MOUTING BEZEL + U... BASIC P/N ø11.00 (.433) 15.60 (.614) 0.90 (.035) 2.30 (.090) For 9500 model (case height 8 mm) only U4922 The mounting bezel U4922 has been designed to facilitate the mounting of the 9500 series pushbutton switch onto a panel. The switch + bezel assembly is snapped into the equipment through the front of the panel, then electrically connected by solder lug terminals. Panel cut-out : Ø 8.15 mm ± 0.05 (.320 DIA ± .002) 7 PANEL SWITCHES 9100-9200-9500 series
9533NCD 价格&库存
很抱歉,暂时无法提供与“9533NCD”相匹配的价格&库存,您可以联系我们找货
9533NCD
  • 1+32.267541+4.15680
9533NCD
  • 1+31.402801+4.04540
  • 10+27.3678110+3.52560
  • 25+26.2274825+3.37870
  • 50+25.2625950+3.25440
  • 100+24.38542100+3.14140
  • 200+23.50824200+3.02840
  • 300+22.98194300+2.96060
  • 500+22.28020500+2.87020
  • 1000+21.578461000+2.77980
库存:444
