Butt Contact Pushbutton Switches
SERIES 30
Snap-in Panel Mounting
FEATURES
• Convenient Snap-in Panel Mounting
• Choice of 6 Button Colors
• SPST (Momentary Contact)
• Gold Plated Contacts
• Sealed
• Butt Contact System
DIMENSIONS In inches (and millimeters)
(Unless otherwise noted, standard tolerances are +/- .020)
Pushbutton Switches
Ø.690
.240
.160
Ø.596 / .602
YYWW
GH
.540
.200
RECOMMENDED PANEL CUT-OUT
SCALE: 1 TO 1
SCALE 2.000
PANEL THICKNESS WITH "O" RING: .098-.106
PANEL THICKNESS WITHOUT "O" RING: .140-.144
MATERIAL
• Button, Housing, Base and Plunger: Nylon, 45%
Glass-filled
• Terminal: Brass, gold-plated over nickel
• Shorting Bar: Brass, gold-plated over nickel
• Internal Seal: Silicone Rubber
• O-ring Seal: Silicone
• Spring: Tinned music wire
• Travel: .090 Nominal
• Travel Before Make: .035 Nominal
RATINGS
• Cycles: 500,000 Actuations
• Operating Temperature: -40o C to +80o C
• Shock: 100 G’s/ 6 Milliseconds
• Rating at 24 VDC: 150 Milliamps
• Voltage Breakdown: 1000 VAC between mutually
insulated parts
• Contact Resistance: 25 milliohms max on new
switch
• Insulation: 1,000 megaohms minimum
ORDERING INFORMATION
CIRCUITRY
Part Number
Description
30-100
30-101
30-102
30-103
30-104
30-105
Black
Red
Green
Yellow
Orange
Blue
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
SPST N.O.
SPST
N.O.
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton
49
