Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product.
Butt Contact Pushbutton Switches
Series 30
Sealed, Front Panel Mounting
FEATURES
Pushbutton Switches
Threaded bushing
Choice of 6 button colors
SPST (momentary contact)
Gold plated contacts
Strong, lightweight aluminum housing
Sealed against dust and moisture to IP67
Optional Silicone Boot
Dimensions in inches (and millimeters)
rATinG
.298
[ 7,58 ]
.220
[ 5,59 ]
.050
[ 1,27 ]
.182
[ 4,62 ]
Ø .530 ±.003
[ 13,46 ]
.503
[ 12,78 ]
RECOMMENDED PANEL
CUTOUT
Ø.522
[ 13,26 ]
.510 ±.003
[ 12,95 ]
.110
[ 2,79 ]
1/2-32 UNEF THREADS
Ø.689
[ 17,51 ]
.780
REF.
[ 19,81 ]
Cycles: 500,000 actuations
operating Temperature: -40ºC to +80ºC
Shock: 100 G's/6 milliseconds
Travel: .090 nominal
Travel Before Make: .035 nominal
rating at 24 VDC: 150 milliamps
Voltage Breakdown: 1000 Vac
Contact resistance: 25 Milliohms max
(initial)
insulation resistance: 1,000 Megaohms
minimum
Seal: IP67
MATeriAL
Housing: Aluminum, black chrome finish
Button, Base, and Plunger: Nylon, 45%
glass-filled
Terminal: Brass, gold-plated over nickel
Shorting Bar: Brass, gold-plated over nickel
internal Seal: Silicone rubber
o-ring panel Seal: Silicone
Spring: Tinned music wire
Hex nut: 1/2-32, Brass with Nickel Plating,
P/N 635201
Lockwasher: Internal,1/2 dia. , Steel with
Zinc plating, P/N 635401
Cable Options
CirCUiTrY: SPST n.o.
ORDERING INFORMATION
30-201B-1S
Series
Threaded Bushing
Strain Relief: Blank = shrink tubing, S = strain relief
Connection: Blank = terminals, E = epoxy rear seal
1 = 6" leads, 2 = 12" leads, 3 = 36" leads
Silicone Boot: Blank = no boot, B = black boot, C = clear boot
Cap Color: 0 = black, 1 = red, 2 = green
3 = yellow, 4 = orange, 5 = blue
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
pictured with clear
silicone boot
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
很抱歉,暂时无法提供与“30-202”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 9+120.28639
- 21+118.08455
- 25+111.40268
- 国内价格 香港价格
- 1+171.828991+22.25787
- 21+127.1818721+16.47450
- 25+119.9676025+15.54000
