15-Serie_IA-A_09-Serie IA-A 21/11/12 14:39 Page85
IA series
Low profile pushbutton switches for harsh environments - bushing Ø 16 mm - momentary
Distinctive features - Specifications - Overview
❑ Resistant to frost, sand and hydrocarbons
❑ Tactile feedback
❑ Front panel sealed to IP67
B1
ENVIRONMENTALSPECIFICATIONS
MATERIALS
• Front panel sealing (see drawing opposite) : IP67
• Salt spray : IEC 512-6, test 11f
• Operating temperature : -20°C to +65°C
• Case/bushing : thermoplastic
• Actuator : polyurethane
• Contacts : silver, gold plated
• Multi-wire lead AWG20,
section 0,6 mm2.
• Terminal seal : epoxy
ELECTRICALANDGENERALSPECIFICATIONS
• Max. current/voltage rating with resistive load : 2A 24VDC
• Initial contact resistance : 100mΩ max.
• Insulation resistance : 100 MΩ min. at 500VDC
• Dielectric strength : 500 Vrms
• Electrical life at full load : 1.000.000 cycles
PANELMOUNTING
➀ Flat seal
1
• Panel thickness : 7 mm (.276) max.
• Total travel : 1,5 mm (.059) +/- 0,3 mm
• Typical operating force : 7N +/- 2N
• Low level or mechanical life : 1.000.000 cycles
• Torque : 0,5 to 1Nm max. applied to nut
IA
Actuator
shape
SERIES
R
round
Electrical
functions
3 Normally
open (NO)
5 NC/NO
combined
Terminals
F
Flying leads
Contacts
1
Silver,
gold plated
Actuator colours
Case colour
1
2
3
5
6
7/1
9
00 Black
Blue
Black
Green
Yellow
Red
White
Orange
Dimensions : First dimensions are in mm while inches are shown as bracketed numbers.
A sealing boot is available to protect the switches against frost and sand. See end of this catalogue.
Mounting accessories : Standard hardware supplied : 1 hex nut 19 mm (.748) across flats and 1 flat seal.
Knurled nut U3327 available on request.
Packaging unit : 25 pieces
APEMwww.apem.com
B1-85
15-Serie_IA-A_09-Serie IA-A 21/11/12 14:39 Page86
IA series
• Panel cut-out Ø 16,2 mm (.657)
• Min. pitch for matrix mounting :
- with standard hex nut : 27 x 27 mm (1.062 x 1.062)
- with knurled nut U3327: 20 x 20 mm (.787x.787)
C
NO
NO
NC/NO combined
MODEL
STRUCTURE
Normally open (NO)
Ø15.00
(.590 DIA)
15.50
(.610)
18.50 maxi
(.728MAX.)
1.20
(.047)
Ø16.00x1.00SI
(.629DIAx1.00IS)
IAR3F
EPOXY
NC/NO combined
IAR5F
C NC
NO
500.00±10
(19.685±.393)
Models
3.30
(.129)
NO model has 2 terminals only.
10.00
(.393)
B1
NC
Ø19.80
(.779 DIA)
Wire colours (NC/NO) : black = common, brown = NC, blue = NO
CONTACT MATERIAL
1
Silver, gold plated
ACTUATOR COLOURS
1 : blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7/1 : white - 9 : orange
CASE COLOUR
00 : black
B1-86
www.apem.com
APEM
很抱歉,暂时无法提供与“IAR3F1300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+149.878621+19.39080
- 5+141.493805+18.30600
- 10+130.7507610+16.91610
- 25+101.6659225+13.15320
- 国内价格 香港价格
- 1+152.359341+19.71175
- 10+131.4859410+17.01122
- 25+123.9754525+16.03954
- 50+118.5696550+15.34015
- 100+113.38877100+14.66987
- 250+106.87357250+13.82695
- 500+102.18424500+13.22026
- 国内价格 香港价格
- 4+227.006714+29.36938
- 5+214.241575+27.71787
- 10+195.3021810+25.26755
- 25+111.2867825+14.39792
- 国内价格
- 1+201.98679
- 10+197.74836
- 25+191.68750
- 50+187.06376
- 100+183.05443
- 国内价格 香港价格
- 3+285.011263+36.87382
- 5+233.456565+30.20384
- 10+201.8446310+26.11399
- 25+138.5405725+17.92392
- 50+135.9191550+17.58477
