09
TA
9
V1
AV series
-A
SW
PANEL SWITCHES
17
CT
Tactile security pushbutton switches •
Ø 19 mm • momentary (NO)
DISTINCTIVE FEATURES
Tactile feedback
Illuminated or non-illuminated
Momentary (NO)
Marking available
ENVIRONMENTAL SPECIFICATIONS
• Optional front panel sealing : IP65 according to IEC 60529
• Operating temperature : -30 °C to +70 °C (-22 °F to +158 °F)
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load : 50 mA 24 VDC
• LED voltage and consumption : 2-color LED : 2 V (3 V max.) 20 mA
Other colors : 2 V (3 V max.) 10 mA
A resistor must be series-connected by the user**
• Initial contact resistance : 100 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength : 500 Vrms 50 Hz min. between terminals
2,000 Vrms 50 Hz min. between terminals and frame
• Electrical life : 1,000,000 cycles at full load
**Resistor value = supply voltage - LED forward voltage
LED forward current
GENERAL SPECIFICATIONS
• Travel : 0.7 mm (.027) ± 0.1 mm (.003)
• Operating force : 7 N ± 2N
• Torque : 5 Nm min. - 14 Nm max. applied to nut
• Panel thickness : 1 (.039) to 6 mm (.236) max.
• Hand soldering : 270 °C, 3 seconds max.
The company reserves the right to change specifications without notice.
1
PANEL SWITCHES
AV series
MATERIALS
• Case : PBT UL94-V0
• Terminals : brass, gold plated
• Contacts : gold plated dome
• Bushing and actuator : see following pages
• LED
ELECTRICAL FUNCTIONS
Function 3 (NO)
MOUNTING
• Panel cut-out : Ø 19.2 mm (.755)
• Min. pitch for matrix mounting :
30 mm x 30 mm (1.181x1.181)
2
BUILD YOUR PART NUMBER
BASIC PART NUMBER
AV
C7
SERIES
ACTUATOR TYPES
CASE
09
Flat
No
19
Curved
L
Illuminated
CONTACTS
FUNCTION
ILLUMINATION
3
Normally open
(NO)
D
TERMINALS
Gold plated
dome
2
Solder
9
Screw
OPTIONS
BUSHING/ACTUATOR MATERIALS
Non-illuminated models
00 (std)
LED COLORS
Blank
No LED
Nickel plated brass / Nickel plated brass
1
Blue
10
Nickel plated brass / Stainless steel
3
Green
30
Chrome plated bras / Stainless steel
5
Yellow
40
Stainless steel / Stainless steel
6
Red
70
Black chrome plated brass / Black chrome
plated brass
7
White
9
Amber
2
Red/green
Illuminated models
00 (std)
10
Chrome plated brass / Chrome plated brass
40
50
Stainless steel / Nickel plated brass
70
plated brass
MARKING
see following pages
SEALING
Blank
K
No sealing
Sealed to IP65
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of
website.
3
PANEL SWITCHES
AV series
Hex nut 22 (.866) across flats
FLAT ACTUATOR - NON ILLUMINATED
Ø19.00x1.00 SI
(.748DIAx1.00 IS)
2.00
(.078)
Solder lug terminals
2.00
(.078)
4.00
(.157)
1.90
(.074)
Ø15.00
(.590DIA)
Ø22.00
(.866DIA)
Screw terminals
Ø15.00
(.590DIA)
Ø22.00
(.866DIA)
1.10
(.043)
AV09C703D2
EPOXY
4.15
(.163)
AV09C703D9
13.50
(.531)
3.90
(.153)
13.50
(.531)
13.20
(.519)
CAVDTL-1A
FLAT ACTUATOR - ILLUMINATED
Ø19.00x1.00 SI
(.748DIAx1.00 IS)
2.00
(.078)
2.00
(.078)
4.00
(.157)
Ø10.00
(.393DIA)
Ø15.00
(.590DIA)
Ø22.00
(.866DIA)
Ø15.00
(.590DIA)
AV09C7L3D2
Screw terminals
1.90
(.074)
1.10
(.043)
Ø22.00
(.866DIA)
PANEL SWITCHES
AV series
EPOXY
4.15
(.163)
13.50
(.531)
AV09C7L3D9
13.50
(.531)
13.20
(.519)
3.90
(.153)
CAVDTL-2A
BUSHING/ACTUATOR
MATERIALS
BASIC P/N
NON-ILLUMINATED MODELS
ILLUMINATED MODELS
CODE
BUSHING
ACTUATOR
CODE
BUSHING
ACTUATOR
00 (std)
Nickel plated brass
Nickel plated brass
00 (std)
Nickel plated brass
Nickel plated brass
10
Nickel plated brass
Stainless steel
10
Nickel plated brass
Stainless steel
30
Chrome plated brass
Stainless steel
Chrome plated brass
Chrome plated brass
40
Stainless steel
Stainless steel
40
Stainless steel
Stainless steel
70
50
Stainless steel
Nickel plated brass
70
LED COLORS
BASIC P/N
Blank
1
3
5
4
No LED
Blue
Green
Yellow
6
7
9
2
Red
White
Amber
Red/green
MARKING
BASIC P/N
For flat or curved actuator.
- by laser etching on non-illuminated brass or stainless
steel actuator.
- by hot stamping on thermoplastic insert
(illuminated actuators)
8.00
(0.314)
Ø10.00
(0.393DIA)
1.50
(0.059)
1.00
(0.039)
TYPE OF MARKING
0 to 9
X
Y
A to N
P to W
Numbers 0 to 9
Symbol *
Symbol #
Letters A to N
Letters P to W
Letter O
Letter O : same code and same design as number 0.
For special symbols, consult factory.
Minimum order : 500 pieces
COLOR OF MARKING
Select an option from each of the two paragraphs
opposite (Type /Color).
Non-illuminated actuators :
0 (std) Same as finish
2
Black
Note : a finished product supplied in version “0” cannot be
modified to version «2».
Illuminated actuators
2
Black (on white)
SEALING
BASIC P/N
Blank No sealing
K
Front panel sealing to IP65
OPTION K
2
- internal gasket
1
- external gasket
CAVETKK-A
5
PANEL SWITCHES
AV series
很抱歉,暂时无法提供与“AV09C7L3D2003K”相匹配的价格&库存,您可以联系我们找货
