PANEL SWITCHES
40
-1
SW
8
80
-1
0N
1400N series
Momentary pushbutton switches •
snap-in mounting • square plunger
DISTINCTIVE FEATURES
Butt action contacts, double break
Solder lug, straight PC and quick-connect terminals
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contacts (A) : 6 A 12 VDC
- silver plated copper contacts (C) : 3 A 12 VDC
• Initial contact resistance : 10 mΩ
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
1,500 Vrms 50 Hz min. between terminals
2,000 Vrms 50 Hz min. between terminals and metal panel
• Electrical life : 10,000 cycles at full load
GENERAL SPECIFICATIONS
• Panel thickness : 2 mm (.078) max.
• Operating temperature : -20 °C to +55 °C (-4 °F to +131 °F)
MATERIALS
• Case : polyamide
• Plunger : polyamide
• Contacts :
A : silver
C : gold plated silver
APEM products may be recycled at end-of-life for the re-claiming of valuable metal components.
The company reserves the right to change specifications without notice.
1
PANEL CUT-OUT
14.30
(.562)
16.50
(.649)
TERMINALS
Ø5.00
(.196DIA)
Solder lug
1.20x0.8
(.047x.031)
4.70x0.80
(.185DIAx.031)
Straight PC
ELECTRICAL FUNCTIONS
C
2
NO
NC
3.00
(.118)
7.20
(.283)
Ø2.50
(.098DIA)
Ø1.40
(.055DIA)
5.00
(.196)
2.50
(.098)
6.50
(.255)
PANEL SWITCHES
1400N series
Quick-connect
BUILD YOUR PART NUMBER
BASIC PART NUMBER
14
N
TERMINALS
SERIES
1
Solder lug
2
NC
4
Straight PC terminals
3
NO
Quick-connect 4.7 x 0.8
(.185 x .031)
5
Changeover
1../8
MODEL
OPTIONS
CONTACT MATERIALS
A
CD
PLUNGER COLORS
Silver
2
Black
Copper, silver plated
3
Green
6
Red
7
Ivory
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to following pages for further information.
3
PANEL SWITCHES
1400N series
18.00
(.708)
Normally Open
1415N
Changeover
12.00
(.472)
3.50
(.137)
1.50
(.059)
7.40
(.291)
1413N
16.00
(.63)
4.70
(.185)
Normally Closed
0.8
(.031)
1412N
12.00
(.472)
6.00
(.236)
14.00
(.551)
13.00
(.512)
18.00
(.708)
SOLDER LUG TERMINALS
Changeover
1.50
(.059)
7.40
(.059)
4.70
(.185)
4.70
(.185)
Ø1.60
(.062DIA)
QUICK-CONNECT TERMINALS
4.7 X 0.8 (.185 X .031)
13.00
(.512)
18.00
(.708)
7.20
(.283)
Normally Open
1415N/8
Changeover
12.00
(.472)
3.50
(.137)
1.50
(.059)
7.40
(.291)
1413N/8
16.00
(.63)
4.70
(.185)
Normally Closed
0.8
(.031)
1412N/8
CONTACT MATERIALS
BASIC P/N
A
C
4
Silver
18.00
(.708)
1445N
12.00
(.472)
Normally Open
12.00
(.472)
3.50
(.137)
7.40
(.291)
1443N
18.00
(.708)
16.00
(.63)
Normally Closed
0.80
(.031)
1442N
5.00
(.197)
1.20
(.047)
14.00
(.551)
13.00
(.512)
12.00
(.472)
STRAIGHT PC TERMINALS
14.00
(.551)
PANEL SWITCHES
1400N series
PLUNGER COLORS
BASIC P/N
2
Black (standard)
3
Green
6 Red
7
Ivory
Switch frame supplied in black.
5
PANEL SWITCHES
1400N series
很抱歉,暂时无法提供与“1415NC2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+71.568531+9.27665
- 10+61.7397210+8.00265
- 25+58.2234225+7.54687
- 60+55.0418760+7.13448
- 120+52.64231120+6.82345
- 300+49.62340300+6.43214
- 540+47.77504540+6.19256
- 1020+45.849341020+5.94295
