9532CD
9532CD
    APEM(埃斐)
    SWITCH PUSH SPST-NC 0.1A 30V
9532CD 数据手册
9000 series Momentary pushbutton switches Distinctive features and specifications ❑ Two case lengths ❑ Three electrical functions ❑ Sealing options ❑ Model X1146 with Ø 16 (.630) bushing B ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contact (A) : 0,3A 250VAC - 0,6A 125VAC - 1A 30VDC - gold plated contacts (CD) : 100mA 30VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals 1.500 Vrms 50 Hz min. between terminals and frame • Electrical life : 250.000 cycles MATERIALS • Case : thermoplastique UL94-V0 • Actuator : polyamide, glass filled • Bushing : brass, nickel plated • Contacts : A : silver CD : brass, gold plated • Terminal seal : epoxy B-52 GENERAL SPECIFICATIONS • Total travel : 9600-9400-9400Y 9600N-9400N Functions 3 and 5 Function 2 Function 3 1,3 mm 2 mm 0,9 mm • Torque : 1,25 Nm (.922 Ft.lb) max. applied to nut • Operating temperature : -30°C to +65°C www.apem.com APEM 9000 series Momentary pushbutton switches Overview 9 Number of poles SERIES 3 Single pole Electrical functions 2 3 5 Normally closed (NC) Normally open (NO) Combined (NC/NO) Terminals, case and bushing B Case length 11,2 (.440) All models have Ø 6,35 (1/4) threaded bushing. 4 Straight PC terminals 6 Solder lug terminals 4..Y Straight PC terminals, bracket mounting Case length 8,5 (.334) 4..N Straight PC terminals 6..N Solder lug terminals 6..NZ1 Quick-connect terminals Contact materials A CD Silver Brass, gold plated Sealing Blank No sealing B Epoxy sealed terminals K Front panel sealing by two O-rings Special options X1146 X601 Bushing Ø 16 (.630) Special contact, lower rating Caps U900 U1140 U1720 U480 U630 U2430 U2020 Ø 5 (.196) Ø 8 (.314) Ø 9,4 (.370) Ø 10 (.393) standard Ø 15 (.590) Square - Height 4 (.157) Square - Height 6 (.236) ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - their options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Sealing boots are available to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied with all switches : 2 hex nuts 8 mm (.314) across flats and 1 lockwasher. Standard and special hardware available are presented in section I. Packaging unit : 50 pieces, except for 9400Y (25 pieces) APEM www.apem.com B-53 9000 series Momentary pushbutton switches 9600 - 9400 - 9400Y • Single pole • Solder lug or straight PC terminals 2.80 (.110) 4.55 (.179) 5.20 (.204) 1.50 (.059) 1.20 (.047) Function 5 (combined) 1.20 (.047) 1.00 (.039) 2.00 (.078) MODEL STRUCTURE Solder lug terminals - case length 11,2 (.440) : 9600 6.00 (.236) Ø4.00 (.157 DIA) 9635 Combined function Ø10.0 (.393 DIA) 11.20 (.440) Normally Closed 7.00 (.275) 9632 Ø6.35-40UNS (1/4-40UNS) Ø9.00 (.354 DIA) NO NO NC 0.40 (.015) 5.20 (.204) 2.00 (.078) 5.08 (.200) F2 F5 For Normally Open (function 3), see next page. Straight PC terminals - case length 11,2 (.440) : 9400 5.08 (.200) Ø6.35-40UNS (1/4-40UNS) 5.08 (.200) 6.00 (.236) Ø4.00 (.157 DIA) 11.85 (.466) NO NO NC 1.00 (.039) 0.40 (.015) 5.08 (.200) F2 5.08 (.200) 5.08 (.200) Ø6.35-40UNS (1/4-40UNS) 3.18 (.125) Ø10.00 (.393 DIA) Normally Open 0.40 (.015) 9435Y Combined function 4.10 (.161) 1.17 (.046) 3.18 (.125) 8.20 (.322) The bracket is not fastened to the switch. B-54 F2 www.apem.com Ø1.60 (.062 DIA) NO NO NC 0.40 (.015) 5.08 (.200) 5.08 (.200) 9433Y Normally Closed 13.00 (.511) 9432Y 15.75 (.620) Ø4.00 (.157 DIA) 6.00 (.236) Bracket mounting - case length 11,2 (.440) : 9400Y F5 15.75 (.620) 15.75 (.620) Combined function Ø1.60 (.062 DIA) Ø9.00 (.354 DIA) 5.08 (.200) 9435 Normally Open 4.55 (.179) 9433 Ø10.0 (.393 DIA) Normally Closed 7.00 (.275) 9432 6.60 (.259) B Function 3 (NO) 9400 5.20 (.204) 8.70 (.342) Function 2 (NC) 9600 2.40 (.094) 9600Z1 3.18 (.125) F5 APEM 9000 series Momentary pushbutton switches 9600N - 9400N Solder lug terminals - case length 8,5 (.334) : 9600N 6.00 (.236) Ø4.00 (.157 DIA) Normally Open 0.40 (.015) 2.00 (.078) 5.00 (.196) 5.08 (.200) 1.50 (.059) 8.50 (.334) Ø9.50 (.374 DIA) 7.00 (.275) 9633N Ø6.35-40UNS (1/4-40UNS) Ø8.50 (.334 DIA) B Also available with quick-connect terminals 2,8 x 0,5 mm : 9633NZ1 Straight PC terminals - case length 8,5 (.334) : 9400N 6.00 (.236) Ø4.00 (.157 DIA) Ø9.50 (.374 DIA) 10.00 (.393) Normally Open Ø1.60 (.062 DIA) 0.40 (.015) 1.00 (.039) 3.50 (.137) Ø8.50 (.334 DIA) 5.08 (.200) 5.08 (.200) 1.50 (.059) 7.00 (.275) 9433N Ø6.35-40UNS (1/4-40UNS) PANEL CUT-OUT Ø6.50 (.255 DIA) 2.00 (.078) Panel cut-out : Ø 16,2 (.637) Max. current/voltage rating. : 0,3A 250VAC - 1A 30VDC Epoxy sealed terminals. Options of the following pages not applicable. APEM 3.00 (.118) 19.00 (.748) Ø16.00x1.00SI (.629DIAx1.00IS) www.apem.com 0.40 (.015) 5.08 (.200) 5.20 (.204) Gold plated silver contacts 9633ADX1146 Normally open 7.40 (.291) Normally open Ø18.00 (.708DIA) 3.30 (.129) Ø12.00 (.472DIA) 9.50 (.374) Silver contacts 9633AX1146 1.50 (.059) Bushing Ø 16 (.630) - metal button : 9633•X1146 Hex nut 19 (.748) across flats B-55 9000 series Momentary pushbutton switches CONTACT MATERIALS A CD Silver Brass, gold plated Special contact, lower rating : see X601 under "Special options". SEALING Blank No sealing B Epoxy sealed terminals K Front panel sealing by two O-rings. Protects the switch against water and dust. Panel seal withstands 0,1 bar pressure and remains tight even when switch is operated. KB Combined sealings 5.50 Maxi (.216 MAX) B 1 K ➀ O-rings Sealing boots : see section H. SPECIAL OPTIONS X601 Silver plated brass contacts Current/voltage rating for an electrical life of 20.000 cycles : 0,2A 250VAC - 0,4A 125VAC - 0,5A 30VDC. Minimum quantity : 5.000 pieces per model and shipment. X1146 Model with dia. 16 (.630) bushing and metal plunger See previous page. B-56 www.apem.com APEM 9000 series Momentary pushbutton switches CAPS + U... U900 U1140 B U1720 Ø15.00 (.590 DIA) Ø10.00 (.393) Replace last "0" by number 1 1/4 2 3 4 5 6 7 7/1 9 3.00 (.118) 3.00 (.118) 10.00 (.393) 7.50 (.295) Cap colours U480 Standard U630 5.00 (.195) 4.00 (.157) U2430 Square blue dark blue black green grey yellow red ivory white orange 6.00 (.236) 11.50x11.50 (.452 SQ) 11.50x11.50 (.452 SQ) 3.00 (.196) 6.35 (.250) 3.00 (.118) 6.35 (.250) 3.00 (.118) 4.00 (.157) 3.30 (.129) Ø9.40 (.370) Ø8.00 (.314) Ø5.00 (.196) U2020 Square DRESS NUTS Ø18.50 (.728 DIA) Ø8.20 (.322 DIA) Ø10.50 (.413 DIA) Ø15.50 (.610 DIA) U1636 Ø6.35-40UNS (1/4-40UNS) Ø6.35-40UNS (1/4-40UNS) Ø6.35-40UNS (1/4-40UNS) For cap U1140 8.00 (.314) 8.20 (.322) 8.00 (.314) 5.80 (.228) Ø13.50 (.531 DIA) 6.20 (.244) Ø12.70 (.500 DIA) 5.80 (.228) Chrome plated U825 U840 For cap U480 For cap U630 Dress nuts are to be ordered separately. APEM www.apem.com B-57 9000 series Alternate action or momentary pushbutton switches Distinctive features and specifications ❑ Bushing Ø 6,35 (1/4) and 11,9 (15/32) ❑ Two electrical functions B ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load and electrical life : - silver contacts (A) : 0,5A 250VAC - 1A 28VDC - 250.000 cycles 1,5A 250VAC - 3A 28VDC - 10.000 cycles - gold plated contacts (CD) : 0,4VA 20V max. AC or DC • Initial contact resistance : 10 mΩ max. at 0,1A 3VDC • Insulation resistance : 10.000 MΩ min. • Dielectric strength : 1.000 Vrms 50 Hz min. MATERIALS • Case : diallylphthalate • Actuator : nylon black for series 9630M white for series 9631 • Bushing : brass, nickel plated • Contacts : A : silver CD : brass, gold plated • Terminal seal : epoxy B-58 GENERAL SPECIFICATIONS • Operating temperature : -30°C to +85°C • Travels : see table below. MODELS 9631 9633M Total travel 3,48 (.137) 2,79 (.110) Pre-travel 0,66 (.026) - Over travel 2,69 (.106) 0,51 (.020) www.apem.com APEM 9000 series Alternate action or momentary pushbutton switches • Single pole • Solder lug terminals • Epoxy sealed terminals Function 3 (NO) 2.55 (.100) Function 1 OFF ON 1.00 (.040) 5.60 (.220) 2.05 (.080) 1.25 (.050) B Bushing Ø 6,35 (1/4) - Alternate action - tactile feedback Silver contacts 9631AB ON OFF - 5.35 (.210) - 6.35 (.250) ON Ø9.40 (.370 DIA) 16.25 (.640) Gold plated contacts 9631CDB Ø4.05 (.160 DIA) Ø6.35-40UNS (1/4-40UNS) OFF EPOXY 5.60 (.220) 0.40 (.015) 5.30 (.209) Standard hardware : 1 conic nut and 1 lockwasher Bushing Ø 11,9 (15/32) - front or rear mounting - NO A Ø8.40 (.330 DIA) Normally open 9.25 (.365) 9633MCDB 16.65 (.655) Ø11.90-32UNS (15/32-32UNS) Ø9.40 (.370 DIA) MODEL A 9633M 6.35 (.250) EPOXY 5.60 (.220) 0.40 (.015) 5.30 (.209) Standard hardware : 2 hex nuts 14 mm (.551) across flats and 1 lockwasher APEM www.apem.com B-59
9532CD 价格&库存
很抱歉,暂时无法提供与“9532CD”相匹配的价格&库存,您可以联系我们找货
9532CD
  • 1+50.230991+6.49815
  • 10+43.4025610+5.61479
  • 25+40.9304125+5.29498
  • 50+39.1490050+5.06452
  • 100+37.44488100+4.84407
  • 300+34.88927300+4.51346
  • 500+33.75853500+4.36719
  • 1000+32.280231000+4.17594
