14AP-L1-02-Y
14AP-L1-02-Y
    GRAYHILLINC.
    Pushbutton Switch SPST-NO Standard, Illuminated Surface Mount
14AP-L1-02-Y 数据手册
SERIES 14 Sealed SMT Key Switch FEATURES • IP64 Dynamic Seal • Bright LED illumination • Excellent tactile feel • High reliability / long life • SMT lead free solder process compatible APPLICATIONS • Multi-function handgrip or joysticks in open or closed cab work vehicles • Handheld remote controllers for robotics & unmanned vehicles • Portable medical electronics such as defibrillators • Bellybox (remote control transmitter) • Marine & motorcycles DIMENSIONS in inches [and millimeters] (Unless otherwise noted, standard tolerances are +/- .015 [0, 38] ) SEALED VERSION .050 [1,27] ("P" STYLE ONLY) .366 ± .010 [ 9,3 ± 0,25 ] Ø .490 ± .015 [ 12,45 ± 0,38 ] Ø .044 ± .002 [ 1,12 ± 0,05 ] ("P" STYLE ONLY) 45 ° 2X .500 [12,7] .041 [1,03] (LED VERSION ONLY) .175 [4,45] ("P" STYLE ONLY) .460 [11,68] Pushbutton Switches 02 0 +0,05 0,00 Pushbutton Switches Ø .133 ± .002 [ 3,38 ± 0,05 ] ("P" STYLE ONLY) .060 [1,52] ("P" STYLE ONLY) 4X .065 [1,65] UNSEALED VERSION (REFER TO SEALED VERSION FOR DIMENSIONS NOT SHOWN) Ø .470 [11,94] Ø.430 [10,92] Ø .055 [ 45 ˚ THRU ("P" STYLE) ] 4X .105 [2,67] 4X .105 [2,67] RECOMMENDED ACTUATOR DESIGN .175 ± .004 [ 4,45 ± 0,1 ] ("P" STYLE) 4X KEEP OUT AREA +.002 -.000 +0,05 1,4 -0,00 - Axis of actuator to be aligned within Ø .030" of the center of actuation area. - Actuator must make contact with the actuation surface only and must not protrude into LED pocket. INTERFERENCE FIT Ø .128 ± .002 [ 3,25 ± 0,05 ] DETAIL A ACTUATION AREA ACTUATOR Ø.200 MIN. Ø.245 [6,22] LED POCKET ACTUATION SURFACE NO INTERFERENCE Ø .137±.002 [3,48±0,05] THRU ("P" STYLE) D D Ø.245 [6,22] 3 4 INTERFERENCE FIT Ø .128 ± .002 [ 3,25 ± 0,05 ] 4X .157 [3,99] 1 2 RECOMMENDED PCB LAYOUT (THRU HOLES CAN BE OMITTED FOR SWITCH VERSIONS WITHOUT POSTS) SEE DETAIL A SECTION D-D LED COLOR Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois RED 633nm ORANGE 605nm YELLOW 587nm FORWARD VOLTAGE (V) 60525-5997 • 2.0, 2.5 MAX. 2.0, 2.5 MAX. 2.0, 2.5 MAX. FORWARD CURRENT (mA) USA • 20 [25 MAX.] 20 [25 MAX.] 20 [25 MAX.] RECO .175 ± .004 [ 4,45 ± 0,1 ] ("P" STYLE) 4X KEEP OUT AREA D D ] Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com NO INTERFERENCE Ø .137±.002 [3,48±0,05] THRU ("P" STYLE) - Axis of th - Actu surf LED Pushbutton Switches RATINGS • Operating Temperature Range: -40C° to 85°C • Storage Temperature Range: -40°C to 100°C (bulk), -20°C to 60°C (tape) • Tactile Feedback Life Span: 14oz: 1,000,000 cycles 21oz: 200,000 cycles 32oz: 100,000 cycles (All versions have a functional life of 1M cycles) Pushbutton Switches • Mechanical Shock: Medium Impact: Contact openings/closings
14AP-L1-02-Y 价格&库存
很抱歉,暂时无法提供与“14AP-L1-02-Y”相匹配的价格&库存,您可以联系我们找货
14AP-L1-02-Y
  • 1+326.452251+42.23532
  • 10+281.6235010+36.43552
  • 25+265.5002725+34.34955
  • 50+253.8971550+32.84838
  • 100+247.90946100+32.07371
库存:437
14AP-L1-02-Y
  • 200+232.12590200+30.03168
  • 400+221.92104400+28.71141
库存:437
14AP-L1-02-Y
    • 200+113.86823
    库存:200
