PANEL SWITCHES
09
17
-IA
IA series
SW
Low profile pushbutton switches for harsh
environments • bushing Ø 16 mm • momentary
DISTINCTIVE FEATURES
Resistant to frost, sand and hydrocarbons
Tactile feedback
Front panel sealed to IP65 and IP67
ENVIRONMENTAL SPECIFICATIONS
• Front panel sealing :
IP65 and IP67 acc. to IEC 60529
• Salt spray : IEC 512-6, test 11f
• Operating temperature : -20 °C to +65 °C (-4 °F to +149 °F)
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load : 2 A 24 VDC
• Initial contact resistance : 100 mΩ max.
• Insulation resistance : 100 MΩ min. at 500 VDC
• Dielectric strength : 500 Vrms
• Electrical life at full load : 1,000,000 cycles
GENERAL SPECIFICATIONS
• Panel thickness : 7 mm (.276) max.
• Total travel : 1.5 mm (.059) ± 0.3 mm
• Typical operating force : 7 N ± 2 N
• Low level or mechanical life : 1,000,000 cycles
• Torque : 0.5 to 1 Nm max. applied to nut
MATERIALS
• Case/bushing : thermoplastic
• Actuator : polyurethane
• Contacts : silver, gold plated
• Multi-wire leads AWG20, section 0.6 mm2.
• Terminal seal : epoxy
The company reserves the right to change specifications without notice.
1
PANEL SWITCHES
IA series
PANEL MOUNTING
• Panel cut-out Ø 16.2 mm (.657)
• Min. pitch for matrix mounting :
- with standard hex nut : 27 x 27 mm (1.062 x 1.062)
- with knurled nut U3327: 20 x 20 mm (.787x.787)
1
- Flat seal
ELECTRICAL FUNCTIONS
C
Function 3 (NO)
2
NC
NO
Function 5 (NC/NO)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
IA
SERIES
ACTUATOR SHAPES
R
Round, curved
3
Normally open
(NO)
5
NC/NO combined
TERMINALS
F
Flying leads
OPTIONS
CONTACTS
1
Silver, gold
plated
ACTUATOR COLORS
1
Blue
2
Black
3
Green
4
Grey
5
Yellow
6
Red
7/1
9
CASE COLOR
00
Black
White
Orange
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
A sealing boot is available to protect the switches against frost and sand. See "Sealing Boots" section of website.
Mounting accessories : Standard hardware supplied : 1 hex nut 19 mm (.748) across flats and 1 flat seal. Knurled nut U3327 available
on request.
3
PANEL SWITCHES
IA series
IAR3F
Normally open (NO)
IAR5F
NC/NO combined
Ø15.00
(.590 DIA)
18.50 maxi
(.728MAX.)
1.20
(.047)
Ø16.00x1.00SI
(.629DIAx1.00IS)
Wire colors (NC/NO) : black = common, brown = NC, blue = NO
NO model has 2 terminals only.
CONTACT MATERIAL
BASIC P/N
1
Silver, gold plated
ACTUATOR COLORS
BASIC P/N
1
2
3
4
5
6
7/1
9
Blue
Black
Green
Grey
Yellow
Red
White
Orange
CASE COLORS
BASIC P/N
00
4
Black
EPOXY
C NC
NO
500.00±10
(19.685±.393)
MODELS
3.30
(.129)
10.00
(.393)
PANEL SWITCHES
IA series
Ø19.80
(.779 DIA)
很抱歉,暂时无法提供与“IAR5F1600”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+232.17650
- 10+227.32365
- 50+220.35680
- 100+215.00408
- 250+210.34910
- 国内价格 香港价格
- 1+192.624311+24.89874
- 10+166.2405110+21.48835
- 25+156.7364425+20.25985
- 50+149.8956550+19.37561
- 100+143.34206100+18.52849
- 250+135.09854250+17.46292
- 500+129.16430500+16.69586
