2201
2201
    GRAYHILLINC.
    HEX STANDOFF 4-40 ALUMINUM 1/4"
2201 数据手册
Snap Action Miniature Pushbutton Switches SERIES 07 SERIES 2000 SPST and SPDT, 10 Amp FEATURES • Momentary Contact • Extremely Fast Make-and-Break • Audible Click DIMENSIONS • 25,000 Cycles of Operation In Inches (and millimeters) SPDT Solder Lug Terminal .312 ± .005 (7,92 ± 0,13) 07-26* KEYWAY .068 (1,72) WIDE A 15/32-32 UNS-2A THREAD C LABEL* SPST–Faston Terminals 2201 2202 07-7 07-8 07-21 07-22 All dimensions not shown are same as part no. 7-26. 1.903 (48,34) REF. All dimensions not shown are same as part no. 7-26. 1.910 (48,51) REF. LABEL* LABEL* .95 (24,13) MAX. OVER PIN HEADS D .880 ± .010 DIA. (22,35 ± 0,25) A = .273 ±.020 (6,93 ± 0,51) B = .454 ± .015 (11,53 ± 0,38) C = .796 ± .015 (20,22 ± 0,38) D = .443 ± .015 (11,25 ± 0,38) .380 ± .015 (9,65 ± 0,38) N.C. . N.O *PART NUMBER AND E.I.A. DATE CODE LABEL C. *PART NUMBER AND E.I.A. DATE CODE LABEL .387 ± .015 (9,83 ± 0,38) TERMINALS TO ACCOMMODATE 1/4 INCH PUSH-ON TERMINATION *PART NUMBER AND E.I.A. DATE CODE LABEL CIRCUITRY N.C. C. N.O. SPDT - BBM SPST N.C. SPST N.O. SPECIFICATIONS Rating Criteria Materials and Finishes Rated: To make and break 10 Amps at 115 Vac, or 5 Amps at 220 Vac resistive load for 25,000 operations Contact Resistance: 25 milliohms or less on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Housing, Button and Internal Bridge: Thermoset plastic Mounting Nuts, Bushings, and Internal Bracket: Brass, tin zinc Fixed and Moving Contacts: Fine silver Internal Spring, Link and Contact Carrier: Beryllium, copper Cover-to-Base Mounting Pins: Brass Faston Terminals: Brass, tin over nickel Solder Lug Terminals: Brass, zinc trivalent chromate-plated Operating Features Total Button Travel: .065 (1,65) approximately Overtravel: .008 (0,20) approximately Actuating Force: 24 ounces approximately Mounting Hole: 31/64" (12,30) inches Terminal Type: Solder Lug/Faston Operating Temperature: -40°C to +85°C Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. ACCESSORIES ORDERING INFORMATION *Part Number 2201 07-7 07-21 2202 07-8 07-22 07-26 RED 07-26 BLK Description Circuitry Button Terminal SPST–N.O. SPST–N.O. SPST–N.O. SPST–N.C. SPST–N.C. SPST–N.C. SPDT–BBM SPDT–BBM Part Number 07Z1047-1 BLK 07Z1047-2 RED 07C1040-1 10C1015-1 Red Black Red Black Red Black Red Black Solder Solder Faston Solder Solder Faston Solder Solder Accessory Description Black Button Cap Red Button Cap Decorative Nut Button Guard Decorative Button Guard Mounting Nut Button Cap Part No. 07Z1047 Part No. 07C1040-1 Part No. 10C1015-1 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton 59 Pushbutton Switches HEX MOUNTING NUTS (2) .094 ± .010 (2,39 ± 0,25) THICK .562 ± .010 (14,27 ± 0,25) ACROSS FLATS B 1.966 (49,94) REF. SPST–Solder Lug Terminals
很抱歉,暂时无法提供与“2201”相匹配的价格&库存,您可以联系我们找货
