4002
4002
    GRAYHILLINC.
    SWITCH PUSH SPST-NC 1A 115V
4002 数据手册
Wiping Contact Pushbutton Switches SERIES 10 SERIES 4000 SPST, 1 and 3 Amp FEATURES • Momentary or Momentary With Positive Feel • UL Recognized at 3 Amps DIMENSIONS CIRCUITRY in Inches (and millimeters) Pushbutton Switches 4001(UL) 10-09 (UL) 10-100 4002 (UL) 10-10 (UL) 10-101 .312 + .000 .012 (7,92 0,30) DIA. B 15/32-32 UNS-2A THREAD HEX MOUNTING NUT .094 (2,39) THICK .563 (14,30) ACROSS FLATS C SPSt n.O. A A = N.O. 1.500 (38,1) REF. N.C. 1.490 (37,8) REF. B = N.O. .160 – .015 (4,06 – 0,38) N.C. .150 – .015 (3,81 – 0,38) C = .375 – .010 (9,53 – 0,25) D = .668 – .015 (16,97 – 0,38) E = .297 –.020 (7,54 – 0,51) D LABEL* E Dimension across bushing flats is .406 ± .010 (10,31 ± 0,25). The inside distance between terminals is .359 (9,12) at the switch base. .800 – .015 (20,32 – 0,38) DIA. SPSt n.C. AccessorIES *PART NUMBER AND E.I.A. DATE CODE LABEL Oper. at Rating at Rating at Rated 115 Vac 220 Vac Actuating Action Part No. Circuitry Load Resistive Resistive Force Momentary 4001 SPST-N.O. 100,000 1 Amp 10-09 Momentary 4002 SPST-N.C. 100,000 1 Amp 10-10 Pos. Feel 10-100 SPST-N.O. 100,000 1 Amp Pos. Feel 10-101 SPST-N.C. 100,000 1 Amp 1 /2 Amp 22 oz. ± 8 1 /2 Amp 23 oz. ± 7 1 /2 Amp /2 Amp 35 oz. ± 8 35 oz. ± 10 1 Decorative Mounting Nut Part No. 07C1040-1 Button Guard Part No. 10C1015-1 Underwriters Laboratory Recognized Momentary 4001 UL SPST-N.O. 6,000 3 Amp 10-09 UL Momentary 4002 UL SPST-N.C. 6,000 3 Amp 10-10 UL —– 22 oz. ± 8 —– 23 oz. ± 7 Ordering Information SPECIFICATIONS Rating Criteria Rated: See chart above Contact Resistance: 25 milliohms or less on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Additional Characteristics Total Travel: Normally open .140 ± .032 (3,56 ± 0,81). Normally closed .110 + .010/ - .020 (2,79 + 0,25/ - 0,51). Overtravel: Normally open .020 (0,51) min. Pretravel: Normally closed .010 (0,25) min. Operating Temperature: -40°C to +85°C UL Recognition: See chart above for rating. UL file number is 35289. Materials and Finishes Mounting Nut: Brass, tin zinc Mounting Bushing and Cover: Zinc, zinc trivalent chromate-plated Button and Base: Thermoset plastic Shorting Bar: Brass, silver-plated Spring: Tinned music wire Contact Terminals: Berylium copper, silverplated .0003" to .0005" Standard Options Epoxy sealed terminals are not available through distributors. Description & Button Color Part No. SPST, N.O., Red 4001 SPST, N.O., Black 10-09 SPST, N.O., UL, Red 4001UL SPST, N.O., UL, Black 10-09 UL SPST, N.O., Positive Feel, Red 10-100 SPST, N.C., Positive Feel, Black 10-101 SPST, N.C., Red 10-10 SPST, N.C., Black 4002 SPST, N.C., UL, Red 10-10 UL SPST, N.C., UL Black 4002 UL Accessory Nut 07C1040-1 Accessory Button Guard 10C1015-1 For terminals bent at 90°, contact Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
很抱歉,暂时无法提供与“4002”相匹配的价格&库存,您可以联系我们找货
