9233CD
9233CD
    APEM(埃斐)
    SWITCH PUSH SPST-NO 0.1A 30V
9233CD 数据手册
9000 series Subminiature momentary pushbutton switches Distinctive features and pecifications UG1006-A ❑ Panel and PC mount models, horizontal or vertical ❑ Self-cleaning and butt action contacts ❑ Several plunger options B ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 100mA 30VDC • Initial contact resistance : 30 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 1.000 Vrms 50 Hz min. between terminals and frame • Electrical life at full load : 9100 - 9200N and 9500N : 250.000 cycles 9200 - 9500 : 100.000 cycles MATERIALS • Case : Pa6T • Actuator : polyamide, glass filled • Bushing : brass, nickel plated • Contacts : CD : brass, gold plated • Terminal seal : epoxy B-14 GENERAL SPECIFICATIONS • Torque : 0,5 Nm (.590 Ft.lb) max. applied to nut • Operating temperature : -30°C to +65°C • Panel thickness : 1,50 mm (.059) max. • Travels : see table below Tolerance : +/- 0,3 mm (.011) 9533-9233 9532-9232 9533N 9233N-9133 Total travel 1,10 (.043) 1,80 (.070) 1 (.039) Pre-travel 0,80 (.031) 1,00 (.039) - Over travel 0,30 (.011) 0,75 (.029) - www.apem.com APEM 9000 series Subminiature momentary pushbutton switches Overview 9 Number of poles SERIES 3 Single pole Electrical functions 2 3 Normally closed (NC) Normally open (NO) Terminals, case and bushing B Case height 8 (.314) 2 Straight terminals - threaded bushing 2..Y Tall bracket - plain bushing 2..WW Right angle terminals - plain bushing 5 Solder lugs - threaded bushing Case height 6,1 (.240) 1 Straight terminals - threaded bushing - 7,10 (.279) PCB to panel 1..Y Short bracket - plain bushing 1..WW Right angle terminals - plain bushing 2..N Straight terminals - threaded bushing - 8,90 (.350) PCB to panel 2..NY Tall bracket - plain bushing 5..N Solder lugs - threaded bushing Contact materials CD Gold plated brass (standard) Sealing Plunger Blank Epoxy sealed terminals standard K Front panel sealing by two O-rings Blank Standard -0 Flush -4 Long Caps For plunger -4 U4310 Height 4 (.157) U4320 Height 3,9 (.153) Mounting bezel U4922 For 9500 model only. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - their options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. : please note that not all combinations of above numbers are available. Refer to the following pages for further information. NOTICE Sealing boots are available to protect the switches. They are presented in section H. Mounting accessories : standard hardware supplied with all threaded bushing models : 1 nickel plated hex nut 5 (.196) across flats, part number U544. This nut is presented after model structure of switches. Packaging unit : 100 pieces. APEM www.apem.com B-15 9000 series Subminiature momentary pushbutton switches Solder lug or straight PC terminals : 9500 - 9200 - 9200Y • Case height 8 (.314) • With over travel • Self-cleaning contacts • Epoxy sealed terminals standard 4.00 (.157) 0.60 (.023) 2.00 (.078) MODEL STRUCTURE Threaded bushing - solder lugs : 9500 3.50 (.137) Ø2.45 (.096 DIA) 8.00 (.314) Normally Open Ø6.50 (.255 DIA) 0.20 (.008) 2.00 (.078) 3.00 (.118) 9533 Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) Normally Closed 3.00 (.118) 9532 2.54 (.100) EPOXY Threaded bushing - straight PC terminals : 9200 3.50 (.137) Ø2.45 (.096 DIA) 8.00 (.314) Normally Open Ø6.50 (.255 DIA) Ø1.10 (.043 DIA) 0.20 (.008) 5.00 (.196) 2.54 (.100) EPOXY 0.60 (.023) 2.54 (.100) 9233 Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) Normally Closed 3.00 (.118) 9232 Normally Open 9.30 (.366) Ø3.00 (.118 DIA) 0.60 (.023) 5.08 (.200) Ø1.10 (.043 DIA) EPOXY 0.20 (.008) 0.40 (.015) 2.54 (.100) 7.62 (.300) B-16 www.apem.com 5.08 (.200) 7.62 (.300) 9233Y Normally Closed 4.00 (.157) 9232Y Ø2.45 (.096 DIA) 2.54 (.100) 3.50 (.137) Straight PC terminals - bracket mounting : 9200Y 2.60 (.102) B NO (function 3) 0.80 (.031) NC (function 2) 5.00 (.196) 1.00 (.039) 3.00 (.118) 1.00 (.039) APEM 9000 series Subminiature momentary pushbutton switches Right angle terminals : 9200WW Right angle terminals : 9200WW 2.70 (.106) 0.60 (.023) 0.60 (.023) Ø1.10 (.043 DIA) 0.60 (.023) 10.16 (.400) 5.08 (.200) 2.54 (.100) 2.54 (.100) 5.08 (.200) 10.16 (.400) Ø3.00 (.118 DIA) 9.50 (.374) 5.08 (.200) Normally Open 3.00 (.118) 9233WW Normally Closed Ø2.45 (.096 DIA) 0.20 (.008) 9232WW Ø6.5 (.255) EPOXY 3.25 (.127) 3.50 (.137) B PANEL CUT-OUT STANDARD HARDWARE 9500 - 9200 5.00 (.196) 1.50 (.059) Ø4.20 (.165 DIA) M4 X 0.70 SI (.157 DIA X 0.70 IS) For threaded bushing models. APEM www.apem.com U544 (nickel plated) B-17 9000 series Subminiature momentary pushbutton switches Solder lug or straight PC terminals : 9500N - 9200N - 9100 • Case height 6,1 (.240) • Epoxy sealed terminals • Butt action contacts 2.00 (.078) MODEL STRUCTURE Threaded bushing - solder lugs : 9500N Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 6.10 (.240) 3.50 (.137) Ø2.45 (.096 DIA) Ø6.50 (.255 DIA) 0.40 (.015) 2.00 (.078) EPOXY 3.00 (.118) Normally Open 3.00 (.118) 9533N 2.54 (.100) Threaded bushing - straight PC terminals - 8,90 (.350) PCB to panel 3.50 (.137) Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 6.10 (.240) Ø2.45 (.096 DIA) 8.90 (.350) Normally Open Ø1.10 (.043 DIA) 0.60 (.023) 2.54 (.100) EPOXY 0.40 (.015) 4.00 (.157) 9233N 3.00 (.118) Ø6.50 (.255 DIA) 2.54 (.100) Threaded bushing - straight PC terminals - 7,10 (.279) PCB to panel Ø4.00 X 0.70 SI (.157 DIA X 0.70 IS) 3.25 (.127) Ø2.45 (.096 DIA) 6.10 (.240) 0.20 (.008) 2.54 (.100) B-18 www.apem.com EPOXY 0.60 (.023) Ø1.10 (.043 DIA) 2.54 (.100) Ø6.50 (.255 DIA) 7.10 (.279) Normally Open 4.00 (.157) 9133 3.00 (.118) B 0.60 (.023) 0.80 (.031) NO (function 3) 4.00 (.157) 1.00 (.039) 3.00 (.118) 1.00 (.039) APEM 9000 series Subminiature momentary puhsbutton switches Straight PC or right angle terminals : 9200NY - 9100Y - 9100WW Straight PC terminals - tall bracket : 9200NY Normally Open 9.30 (.366) 2.60 (.102) 9233NY Ø3.00 (.118 DIA) 3.50 (.137) Ø2.45 (.096 DIA) Ø1.10 (.043 DIA) 5.08 (.200) 0.40 (.015) 2.54 (.100) 0.60 (.023) 7.62 (.300) 7.62 (.300) 0.60 (.023) 2.54 (.100) 0.40 (.015) 4.00 (.157) EPOXY 5.08 (.200) B 3.50 (.137) Ø3.00 (.118 DIA) 2.60 (.102) Normally Open EPOXY 0.40 (.015) Ø1.10 (.043 DIA) 0.60 (.023) 0.20 (.008) 2.54 (.100) 5.08 (.200) 4.00 (.157) 0.60 (.023) 5.08 (.200) 2.54 (.100) 7.62 (.300) 7.62 (.300) 9133Y Ø2.45 (.096 DIA) 7.70 (.303) Straight PC terminals - short bracket : 9100Y Right angle terminals - vertical : 9100WW Ø6.5 (.255) EPOXY 0.60 (.023) 7.60 (.299) 0.60 (.023) 10.16 (.400) Ø3.00 (.118 DIA) 3.25 (.127) 0.40 (.015) 5.08 (.200) Normally Open 2.70 (.106) 3.00 (.118) 9133WW Ø2.45 (.096 DIA) 3.50 (.137) Ø1.10 (.043 DIA) 0.60 (.023) 10.16 (.400) 5.08 (.200) 2.54 (.100) 5.08 (.200) 2.54 (.100) PANEL CUT-OUT STANDARD HARDWARE 9500N - 9200N - 9100 5.00 (.196) Ø4.20 (.165 DIA) 1.50 (.059) M4 X 0.70 SI (.157 DIA X 0.70 IS) For threaded bushing models. APEM www.apem.com U544 (nickel plated) B-19 9000 series Subminiature momentary pushbutton switches CONTACT MATERIALS CD Gold plated brass (standard) SEALING B Blank Epoxy sealed terminals standard K Front panel sealing by two O-rings. Protects the switch against water and dust. Panel seal withstands 0,1 bar pressure. 1 Option K for models 9533N, 9233N and 9133 only. ➀ O-rings PLUNGERS Ø2.45 (.096 DIA) Ø2.45 (.096 DIA) 4.70 (.185) 3.50 (.137) Ø2.5 (.098 DIA) Blank -4 -0 Standard Long Flush B-20 www.apem.com APEM 9000 series Subminiature momentary pushbutton switches CAPS + U... Cap colours Replace "0" by number Ø5.00 (.196 DIA) 1 1/4 2 3 4 5 6 7 7/1 9 3.00 (.118) 4.00 (.157) 3.00 (.118) 3.90 (.153) Ø6.50 (.255) U4310 U4320 For use with plunger -4 only For use with plunger -4 only blue dark blue black green grey yellow red ivory white orange B MOUNTING BEZEL + U... 15.60 (.614) ø11.00 (.433) 0.90 (.035) 2.30 (.090) For 9500 model (case height 8 mm) only The mounting bezel U4922 has been designed to facilitate the mounting of the 9500 series pushbutton switch onto a panel. The switch + bezel assembly is snapped into the equipment through the front of the panel, then electrically connected by solder lug terminals. Panel cut-out : Ø 8,15 mm ± 0,05 (.320 DIA ± .002) Shown with cap U570. APEM www.apem.com B-21
9233CD 价格&库存
很抱歉,暂时无法提供与“9233CD”相匹配的价格&库存,您可以联系我们找货
9233CD
  • 15+62.0748615+8.02384
  • 50+40.8747550+5.28350
  • 100+38.62790100+4.99307
  • 300+35.05291300+4.53096
  • 500+32.29592500+4.17459
库存:1000
9233CD
  • 1+40.31197
  • 50+39.11438
  • 100+37.91678
  • 250+37.10451
  • 500+36.04229
库存:167
