38FSP9B0M7RT
38FSP9B0M7RT
    GRAYHILLINC.
    SWITCHPUSHBUTTONSPST0.4VA20V
38FSP9B0M7RT 数据手册
Subminiature Pushbutton Switches Series 38F Sub-Miniature Pushbutton Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuators, Bushings, and Terminations • UL Recoginized Models in inches (and millimeters) SPST FLAT .155 (3.94) 10-48UNS Ø.100 (Ø2.54) .214 (5.45) .173 (4.39) .200 (5.08) .321 (8.16) .020 (0.51) .059 (1.52) .110 (2.79) .282 (7.18) SCHEMATIC .200 (5.08) ()=MOMENTARY MODEL NO. SP9 SWITCH POSITION OFF (ON) SPDT FLAT Ø.240 (Ø6.10) .155 (3.94) 10-48UNS Ø.100 (Ø2.54) .173 (4.39) .110 (2.79) 3 N.O. N.C.1 .321 (8.16) .059 (1.52) .160 (4.06) .282 (7.18) 2COMM. .200 (5.08) .020 (0.51) .214 (5.45) SCHEMATIC .200 (5.08) MODEL NO. SP8 ()=MOMENTARY TERM. COMM. SWITCH POSITION ON (ON) 2-3 2-1 BUSHING OPTIONS in inches (and millimeters) B5 B6 Ø.100 (Ø2.54) .220 (5.59) 10-48 UNS .173 (4.39) .220 (5.59) Ø.187 (Ø4.75) .173 (4.39) .020 (0.51) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Ø.100 (Ø2.54) .020 (0.51) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Switches Ø.240 (Ø6.10) Subminiature Pushbutton Switches BUSHING OPTIONS (CONT.) in inches (and millimeters) B7 B8 Ø.187 (Ø4.75) Ø.100 (Ø2.54) .220 (5.59) Ø.122 (Ø3.10) .310 (7.87) .225 (5.72) Ø.187 (Ø4.75) .200 (5.08) Ø.314 (Ø8.00) B9 1/4 40NS .020 (0.51) .020 (0.51) B0 Pushbutton Switches Ø.200 (Ø5.08) Ø.122 (Ø3.10) .310 (7.87) .225 (5.72) Ø.100 (Ø2.54) .200 (5.08) Ø.314 (Ø8.00) .130 (3.30) .020 (0.51) .020 (0.51) TERMINATION OPTIONS in inches (and millimeters) M1 Solder Lug P. C. Mount (Std) .040 (1.02) .060 (1.53) .110 (2.79) .060 (1.52) .160 (4.06) M6 M2 .040 (1.02) .030 (0.76) THK. .020 (0.51) .030 (0.76) THK. .020 (0.51) Right Angle, P. C. Mount .128 (3.26) Ø.187 (Ø4.75) .173 (4.39) SPST FLAT .577 (14.65) Ø.100 (Ø2.54) .130 (3.30) .362 (9.20) .321 (8.16) .020 (0.51) Ø.240 (Ø6.10) .200 (5.08) .036 (0.90) .152 (3.86) .016 (0.41) .200 (5.08) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .199 (5.04) .020 (0.51) .134 (3.40) .200 (5.08) Ø.043 (Ø1.09) .200 (5.08) P.C. MOUNTING .034 (0.86) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Subminiature Pushbutton Switches TERMINATION OPTIONS (CONT.) in inches (and millimeters) M6 .137 (3.50) Ø.187 (Ø4.75) Ø.100 (Ø2.54) .173 (4.39) SPDT .036 (0.90) .034 (0.86) Ø.043 (Ø1.09) .320 (8.13) .356 (9.04) .020 (0.51) .016 (0.41) .152 (3.86) .030 (0.76) .130 (3.30) .200 (5.08) .200 (5.08) .220 (5.59) Ø.240 (Ø6.10) FLAT Ø.100 (Ø2.54) .152 (3.86) Ø.100 (Ø2.54) .400 (10.16) .030 (0.76) .356 (9.04) .020 (0.51) P.C. MOUNTING .200 (5.08) .200 (5.08) .030 (0.76) .016 (0.41) .200 (5.08) .200 (5.08) .200 (5.08) Ø.043 (Ø1.09) .320 (8.13) .137 (3.50) .173 (4.39) Ø.187 (Ø4.75) .030 (0.76) .200 (5.08) .100 (2.54) .130 (3.30) P.C. MOUNTING .400 (10.16) (3.26) .128 Ø.043 (Ø1.09) Ø.187 (Ø4.75) .173 (4.39) .236 (6.00) .020 (0.51) SPST .338 (8.60) .200 (5.08) .030 (0.76) .130 (3.30) .017 (0.42) .400 (10.16) Ø.100 (Ø2.54) .200 (5.08) .200 (5.08) .400 (10.16) P.C. MOUNTING .020 (0.51) .128 (3.26) Ø.043 (Ø1.09) Ø.187 (Ø4.75) .173 (4.39) SPDT .236 (6.00) .020 (0.51) .200 (5.08) .030 (0.76) .338 (8.60) .130 (3.30) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .017 (0.42) .400 (10.16) .100 (5.08) .020 (0.51) .400 (10.16) P.C. MOUNTING .100 (2.54) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Switches Ø.100 (Ø2.54) .173 (4.39) V2 Vertical Bracket, P. C. Mount P.C. MOUNTING .134 (3.40) .128 (3.26) FLAT SPDT .200 (5.08) .199 (5.04) .020 (0.51) .220 (5.59) Ø.240 (Ø6.10) Ø.187 (Ø4.75) Ø.043 (Ø1.09) .020 (0.51) .362 (9.20) .152 (3.86) .016 (0.41) .200 (5.08) .200 (5.08) SPST .200 (5.08) Ø.240 (Ø6.10) FLAT M7 Right Angle, P. C. Mount .321 (8.16) .577 (14.65) Subminiature Pushbutton Switches Snap-in Termination Options (Snap-in termination options have the same PC layout as M2, M6 and M7 options) S2 S6 S7 SPECIFICATIONS Pushbutton Switches Ratings Contact Rating: Q & G option - 1A with resistive load @ 125 VAC or 28 VDC; R option - 0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 make-and-break cycles at full load Travel: .030 ± .010 Contact Resistance: 20 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Plunger: Polyester Bushing: Brass, nickel plated Housing: Stainless steel Terminal/Switch Support: Brass, electrotin plated Terminal Seal: Epoxy ORDERING INFORMATION SERIES 38F 38F = SubMiniature Pushbutton Switches MODEL NO. SP8 Options: SP8, SP9 (see models for switching positions) BUSHING B5 Options: B5, B6, B7, B8, B9, B0 (see bushing options) TERMINATION M1 Options: M1, M2, M6, M7, V2, S2, S6, S7 (see termination options) T R = Copper alloy, gold plate over nickel plate. T = Lead Free and RoHS Compliant Q = Copper alloy, silver plated G=Gold plate over silver plate Example Part Number: 38FSP8B5M1QE Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
38FSP9B0M7RT
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
38FSP9B0M7RT 价格&库存
很抱歉,暂时无法提供与“38FSP9B0M7RT”相匹配的价格&库存,您可以联系我们找货
38FSP9B0M7RT
  • 1+60.456891+7.82172
38FSP9B0M7RT
