3S1-SP8-B6-M7RE
3S1-SP8-B6-M7RE
    CARLING
    SWITCH PUSH SPDT 0.4VA 20V
3S1-SP8-B6-M7RE 数据手册
3S-Series Miniature Pushbutton Switches PROD UC T WE BP A GE request sample, configure part The 3S family of sub-miniature pushbutton switches is composed of three switch series; the 3S1-Series subminiature pushbutton switch, the 3SS-Series sealed sub-miniature pushbutton switch, and the 3SM-Series surface mount sealed sub-miniature pushbutton switch. All switches are available with a variety of rating, termination and actuator choices, and will withstand temperatures from -30°C to +85°C. 1-2 Poles .4-6 125, 250 Amps Typical Applications ∙ Instrumentation ∙ Telecommunications www.carlingtech.com ∙ Networking ∙ Performance Audio 860.793.9281 sales@carlingtech.com VAC ∙ Computers 28 VDC ∙ Low Power On/Off Designs Tech Specs 3S1-Series 3SS-Series 3SM-Series Sealed Surface Mount Sub-Miniature Pushbutton Switch Sub-Miniature Pushbutton Switch Sealed Sub-Miniature Pushbutton Switch Electrical Material Contact Rating refer to ordering scheme Electrical Life 50,000 make & break cycles @ full load Contact Resistance 20 mΩ max. initial @ 2-4 VDC 100mA for both silver & gold plated contacts Insulation Resistance 1000 MΩ min. Dielectric Strength 1500 Volts RMS @ sea level Physical Operating Temperature -30°C to +85°C Index of Protection 3SS & 3SM-Series: IP67 Solder Heat Resistance MIL-STD-202, Method 210 Case all UL94 V-0 3S1-Series: Dially phthalate (DAP) 3SS-Series: Glass filled nylon 6/6,flame retardant, heat stabilized 3SM-Series: Glass filled nylon 4/6,flame retardant, heat stabilized Plunger 3S1-Series:Thermoplastic polyester, black 3SS-Series: Thermoplastic polyester (UL 94V-0), with internal o-ring 3SM-Series: Glass filled nylon 4/6,flame retardant, heat stabilized Bushing 3S1-Series: Brass, nickel plated 3SS-Series: Glass filled nylon 6/6,flame retardant, heat stabilized (UL 94V-0) 3SM-Series: Glass filled nylon 4/6,flame retardant, heat stabilized (UL 94V-0) Housing Stainless Steel Switch Support Brass, tin plated Terminal Seal Epoxy Ordering Scheme 3SS - WSP 9 - M6 R E Sample Part Number 1 Selection 1. SERIES 3SS 2 Sealed Sub-Miniature Pushbutton Switch 2. POLES WSP WDP Single pole - uses terminals 1, 2 & 3 Double pole - uses terminals 1, 2, 3, 4, 5 & 6 3. CIRCUIT ( ) - momentary Switching Position: 8 9 3 4 Note: Plunger at rest in Position 1. Plunger depressed in Position 2. 4. ACTUATOR STYLE Contact Material G silver 1 K gold 2 P silver 1 R gold 2 8. EPOXY SEAL Epoxy Seal Terminal Plating Rating Approvals gold over silver 1A 125VAC or 28VDC IP67 tin 3,4 0.4VA max 20V max (AC/DC) IP67 tin 3,4 1A 125VAC or 28VDC IP67 gold 2 0.4VA max 20V max (AC/DC) IP67 0 without Epoxy Seal Notes: 1 Movable contact & terminal platings: silver over copper alloy 2 Movable contact & terminal platings: gold over nickel over copper alloy 3 Terminal platings: tin over nickel over copper alloy 4 Tin option available with PC terminations only. 4 M2 PCB M6 PC Mount, 90° horizontal M61 Snap-In, 90° horizontal M7 PC Mount, 90° vertical M71 Snap-In, 90° vertical VS2 PC Mount, U bracket VS21 Snap-In, U bracket 2. 6 5. CONTACTS / TERMINALS E 1 2 2-3, 5-6 2-1, 5-4 ON (ON) OFF (ON) 5 *Manufacturer reserves the right to change product specification without prior notice. Configure Complete Part Number > Browse Standard Parts > Ordering Schemes 3S1 - SP 9 - B6 - M7 - R E Sample Part Number 1 Selection 1. SERIES 3S1 2 3 4 6. CONTACTS / TERMINALS 3. CIRCUIT Contact Material G silver 3 K gold 4,7 P silver 3,8 Q silver 3 R gold 4 1 2 2-3, 5-6 2-1, 5-4 ON (ON) OFF (ON) Note: Plunger at rest in Position 1. Plunger depressed in Position 2. 10-48 Threaded Unthreaded “D” Unthreaded 1/4-40 Threaded “D” E B9 B0 0P1 P0 Configure Complete Part Number > Sample Part Number Selection Flush Bushing 1/4” Unthreaded “D” Snap-In with bezel Flush Plunger Browse Standard Parts > 1 2 3 5 6 7 5. CONTACTS/TERMINALS Contact Material Terminal Plating Rating Approvals gold over silver 1A 125VAC or 28VDC IP67 G silver 1 K gold 2,5 tin 4 0.4VA max 20V max (AC/DC) IP67 P silver 1,6 tin 4 1A 125VAC or 28VDC IP67 1 1 Q silver silver 1A 125VAC or 28VDC IP67 R gold 2 gold 3 0.4VA max 20V max (AC/DC) IP67 Sealed Snap-Action Miniature Pushbutton Switch Single pole - uses terminals 1, 2 & 3 6. EPOXY SEAL 3. CIRCUIT E ( ) - momentary Switching Position: 1 2 2-3, 5-6 2-1, 5-4 7 ON (ON) 0 Epoxy Seal without Epoxy Seal 7. PACKAGING T/R Note: Plunger at rest in Position 1. Plunger depressed in Position 2. tape reel - 500 pieces per reel Switches are bulk packed, unless T/R is specified at the end of the part number. 4. TERMINATION K6 M6 M7 S6 without Epoxy Seal Notes: 1 Hardware includes (2) 2M1-HDW21 nuts, and (1) 2M1-HDW22 washer 2 Hardware includes (2) 2M1-HDW2 nuts, (1) 2M1-HDW11 washer, and (1) 2M1-HDW16 locking ring 3 Movable contact and terminal platings: silver over copper alloy 4 Movable contact and terminal platings: gold over nickel over copper alloy 5 Terminal platings: gold over nickel over copper alloy 6 Terminal platings: tin over copper alloy 7 Terminal contact platings: Gold over nickel alloy 8 Terminal contact platings: silver over nickel alloy 4 2. POLES SP 0 Epoxy Seal 3S1 - SP 9 - B6 - M7 - R E 1. SERIES 3MS Terminal Plating Rating gold over silver 1A@125VAC or 28VDC tin 6 0.4VA max @ 20V max (AC/DC) tin 6 1A@125VAC or 28VDC 3 silver 1A@125VAC or 28VDC 5 gold 0.4VA max @ 20V max (AC/DC) 7. EPOXY SEAL 4. ACTUATOR STYLE B5 1 B6 B7 B8 2 7 M6 PC Mount, 90° horizontal VS2 PC Mount, U bracket M61 Snap-In, 90° horizontal VS21 Snap-In, U bracket M1 Solder Lug M7 PC Mount, 90° vertical M2 PCB M71 Snap-In, 90° vertical Single pole - uses terminals 1, 2 & 3 ( ) - momentary Switching Position: 8 9 6 5. TERMINATION Sub-Miniature Pushbutton Switch 2. POLES SP 5 Notes: 1 Movable contact and terminals platings: silver over copper alloy 2 Movable contact platings: gold over nickel over copper alloy 3 Terminal platings: gold over nickel over copper alloy 4 Terminals platings: tin over copper alloy 5 Terminal contact platings: gold over nickel alloy 6 Terminal contact platings: silver over nickel alloy Surface Mount, horizontal .433 [11.00 mm] Surface Mount, 90° flat .286 [7.26 mm] Surface Mount, 90° right angle Surface Mount, 90° horizontal .353 [8.97 mm] Configure Complete Part Number > Browse Standard Parts > 3S-Series Accessories To order accessories assembled on a switch, specify the switch number followed by the accessory part number and the word “assembled”. Ex: 3S1-SP9-B6-M7-RE-C23 ASSEMBLED. To order accessories in bulk, specify the Series, followed by the accessory. Ex: 3S1-C13. Optional Cap 1. SERIES 3S1 Selection 3S1 - C1 3 C1 .158” [4.01 mm] height 1 2 3 3. CAP COLOR Fits 3SS, 3S1 or 3MS 2. TOGGLE CAP SIZE 3. Sample Part Number C2 .138” [35.05 mm] height 1 White 2 Black 3 Red 4 Orange 5 6 7 Yellow Green Blue Dimensional Specs inches [millimeters] Single Pole .244 [6.20] .177 [4.50]DIA .100 [2.54]DIA .528 [13.40] Double Pole EPOXY SEAL .201 [5.10] .020 [0.50] .177 [4.50]DIA .319 [8.10] .100 [2.54] .177 [4.50] .217 [5.50] .177 [4.50] .030 [0.76] .102 [2.60] .532 [13.50] EPOXY SEAL .362 [9.20] .020 [0.50] .327 [8.30] .200 [5.08] .030 [0.76] .120 [3.05] .200 [5.08] * Double Thrown Shown. Single Throw uses two outer terminals only. Termination Options M6 Single Pole .100 [2.54] DIA .528 [13.40] .244 [6.20] .177 [4.50]DIA EPOXY SEAL .100 [2.54] .201 [5.10] .126 [3.20] .032 [0.80] P.C.MOUNTING .319 [8.10] .034 [0.85] .016 [0.40] .200 [5.08] .020 [0.50] .043 [1.09] DIA .200 [5.08] .100 [2.54] .200 [5.08] .200 [5.08] * Double Thrown Shown. Single Throw uses two outer terminals only. M6 Double Pole .100 / 2.54]DIA [O .217 [5.50] .177 [4.50]DIA .200 [5.08] .034 [0.85] .016 [0.40] .158 [4.00] .200 [5.08] M7 Single Pole .100 [2.54] DIA .244 [6.20] .177 [4.50]DIA .200 [5.08] .100 [2.54] .020 [0.50] .100 [2.54] .201 [5.10] .020 [0.50] .172 [4.37] P.C.MOUNTING .319 [8.10] .016 [0.40] .200 [5.08] .100 [2.54] .200 [5.08] .043 / 1.09] [O .200 [5.08] EPOXY SEAL .185 [4.70] .030 [0.76] P.C.MOUNTING .362 [9.20] .205 [5.20] .030 [0.76] .327 [8.30] EPOXY SEAL .100 [2.54] .043 [1.09]DIA .200 [5.08] .030 [0.76] * Double Thrown Shown. Single Throw uses two outer terminals only. M7 Double Pole .217 [5.50] .177 [4.50]DIA .100 [2.54] DIA .030 [0.76] .020 [0.50] .185 [4.70] P.C.MOUNTING .200 [5.08] .327 [8.30] .016 [0.40] .189 [4.80] .200 [5.08] 4. .362 [9.20] EPOXY SEAL .200 [5.08] .201 [5.10] .030 [0.76] .200 [5.08] .043 / 1.09] DIA [O .200 [5.08] Dimensional Specs inches [millimeters] Termination Options VS2 Single Pole .177 [4.50]DIA .244 [6.20] .100 [2.54] DIA P.C.MOUNTING .161 [4.10] .100 [2.54] EPOXY SEAL .366 [9.30] .030 [0.76] .130 [3.30] .016 [0.40] .100 [2.54] .201 [5.10] VS2 Double Pole .043 [1.09]DIA .020 [0.50] .400 [10.16] * Double Thrown Shown. Single Throw uses outer terminals only. .100 [2.54] DIA .177 [4.50] P.C.MOUNTING .217 [5.50] .043 [1.09]DIA .161 [4.10] .366 [9.30] .030 [0.76] .130 [3.30] .201 [5.10] .016 [0.40] .200 [5.08] EPOXY SEAL .039 [1.00] .016 [0.40] .039 [1.00] * PC Mounting for M61, M71, VS21 refer to M6, M7, VS2 respectively. 5. .400 [10.16] .200 [5.08] .400 [10.16] M71 .016 [0.40] .200 [5.08] .020 [0.50] Snap-In Termination Options M61 .400 [10.16] VS21 .030 [0.76] .059 [1.50] .016 [0.40] .039 [1.00] Dimensional Specs inches [millimeters] Single Pole .236 [6.00]DIA FLAT .236 [6.00] .154 [3.90] .173 [4.40] .201 [5.10] .020 [0.50] .098 [2.50] 3 .319 [8.10] .100 [2.54] 2 1 .030 [0.76] .130 [3.30] * DoubleThrow shown.SingleThrow uses two outer terminalsonly. Actuator Options for Snap-In Front Mount OP1 PANEL MOUNTING .614 [15.60] R.005 [R0.13] .150 [3.80] .091 [2.30] .370 [9.40] PANEL THICKNESS .125 .047 [1.19] TO [3.18] .764 [19.40] * .600 [15.24] .449 [11.40] *Increase thisdimension to .620/.625 [1 5.75/1 5.88] for .091/.1 25[2.31 /3.1 8]thk.panels. MAX. TYP. .500 [12.70] OP1 Without Frame PANEL MOUNTING .472 [12.00] .240 [6.10] .713 [18.10] .370 [9.40] PANEL THICKNESS .047 TO .125 [3.18] [1.19] R.005 [R0.13] * .600 [15.24] .476 [12.10] *Increasethis dimensionto .620/.625 [1 5.75/1 5.88]for .091/.125 [2.31/3.1 8]thk. panels. MAX. TYP. .500 [12.70] .476 [12.10] Bushing Options B5 .173 [4.40] 10-48UNS .189 [4.80]DIA B8 B6 .098 [2.50]DIA .236 [6.00] .020 [0.50] .224 [5.70] .122 [3.10] DIA 1/4-40UNS .244 [6.20]DIA .329 [8.35] 020 [0.50] .173 [4.40] .098 [2.50]DIA .189 [4.80]DIA B7 .098 [2.50]DIA .189 [4.80]DIA .236 [6.00] .020 [0.50] B9 .020 [0.50] B0 .098 [2.50]DIA .197 [5.00]DIA .224 [5.70] .122 [3.10] DIA .244 [6.20]DIA .020 [0.50] .020 [0.50] Termination Options M1 .039 [1.00] .059 [1.50] .028 [0.70] 6. .118 [3.00] .158 [4.00] .020 .061 [1.55] X [0.50] THK M2 .039 [1.00] .020 .030 [0.76] X [0.50] THK .236 [6.00] .130 [3.30] .329 [8.35] Dimensional Specs inches [millimeters] Termination Options M6 Single Pole .142 [3.60] .173 [4.40] F L AT .098 .126 [3.20] [2.50] .236 [6.00]DIA .035 [0.90] .200 [5.08] .142 [3.60] .236 [6.00]DIA .187 [4.75] P.C.MOUNTING .319 [8.10] .200 .043 [1.09] DIA [5.08] .201 [5.10] .016 [0.40] .034 [0.85] .236 [6.00] .200 [5.08] .020 [0.50] .200 [5.08] M7 Single Pole .173 [4.40] .236 .333 [6.00] [8.45] .100 [2.54] .100 [2.54] * Double Thrown Shown. Single Throw uses two outer terminals only. P.C.MOUNTING .201 [5.10] .020 [0.50] .319 [8.10] .098 [2.50] .200 [5.08] .016 [0.40] .030 [0.76] .043 [1.09] DIA .100 [2.54] .200 [5.08] VS2 Single Pole .189 [4.80] .030 [0.76] * Double Thrown Shown. Single Throw uses two outer terminals only. .173 [4.40] .098 [2.50] .020 [0.50] P.C.MOUNTING .142 [3.60] .236 [6.00] .100 [2.54] .350 [8.90] .030 [0.76] .130 [3.30] .016 [0.40] .200 [5.08] .100 [2.54] .020 [0.50] .400 [10.16] M71 .016 [0.40] .016 [0.40] .039 [1.00] .039 [1.00] * PC Mounting for M61, M71, VS21 refer to M6, M7, VS2 respectively. 7. .400 [10.16] .043 [1.09] DIA * Double Thrown Shown. Single Throw uses outer terminals only. Snap-In Termination Options M61 .100 [2.54] VS21 .030 [0.76] .059 [1.50] .016 [0.40] .039 [1.00] Dimensional Specs inches [millimeters] .177 [4.50]DIA K6 Single Pole .319 [8.10] .100 [2.54]DIA M6 Single Pole .161 [4.10] .244 [6.20] EPOXY SEAL EPOXY SEAL .030 [0.76] .138 [3.50] .433 [11.00] .280 [7.10] .354 [9.00] .276 [7.00] .020 [0.50] .100 [2.54] .278 [7.50] .032 [0.80] .100 [2.54] .083 [2.10] .110 [2.80] .079 [2.00] M7 Single Pole .177 / 4.50]DIA [O .280 [7.10] .173 [4.39] .217 [5.50] .016 [0.40] .217 [5.50] EPOXY SEAL .100 [2.54] .030 [0.76] .118 [3.00] .161 [4.10] EPOXY SEAL .020 [0.50] .177 [4.50] .100 [2.54]DIA S6 Single Pole .161 .366 [4.10] [9.30] .244 [6.20] .125 [3.18] .120 [3.00] .561 [14.25] .079 [2.00] .063 [1.60] .125 [3.18] .100 [2.54] .325 [8.27] * Double Thrown Shown. Single Throw uses two outer terminals only. C1 C2 .189 [4.80] .197 [5.00] * MATERIAL: ABS. 8. CAP COLORS .283 [7.20] .158 [4.00] .102 [2.60] Plunger Caps .138 [3.50] .091 [2.30] .291 [7.40] * MATERIAL: ABS. 1 White 6 2 Black 7 Green Blue 3 Red 8 Brown 4 Orange 9 Gray 5 Yellow Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 9. © Carling Technologies, Inc. Carling is a registered trademark of Carling Technologies, Inc. in the U.S. and other countries.
3S1-SP8-B6-M7RE 价格&库存
很抱歉,暂时无法提供与“3S1-SP8-B6-M7RE”相匹配的价格&库存,您可以联系我们找货
