Butt Contact Pushbutton Switches
SERIES 30
Sealed, Front Panel Mounting
FEATURES
Pushbutton Switches
Threaded bushing
Choice of 6 button colors
SPST (momentary contact)
Gold plated contacts
Strong, lightweight aluminum housing
Sealed against dust and moisture
to IP67 (to IP67 with silicone boot*)
DIMENSIONS in inches (and millimeters)
RATING
.298
[ 7,58 ]
.220
[ 5,59 ]
.050
[ 1,27 ]
.182
[ 4,62 ]
Ø .530 ±.003
[ 13,46 ]
.503
[ 12,78 ]
RECOMMENDED PANEL
CUTOUT
Ø.522
[ 13,26 ]
.510 ±.003
[ 12,95 ]
.110
[ 2,79 ]
1/2-32 UNEF THREADS
Ø.689
[ 17,51 ]
.780
REF.
[ 19,81 ]
Cycles: 500,000 actuations
Operating Temperature: -40ºC to +80ºC
Shock: 100 G's/6 milliseconds
Travel: .090 nominal
Travel Before Make: .035 nominal
Rating at 24 VDC: 150 milliamps
Voltage Breakdown: 1000 Vac
Contact Resistance: 25 Megaohms max
(initial)
Insulation Resistance: 1,000 Megaohms
minimum
MATERIAL
Housing: Aluminum, black chrome finish
Button, Base, and Plunger: Nylon, 45%
glass-filled
Terminal: Brass, gold-plated over nickel
Shorting Bar: Brass, gold-plated over
nickel
Internal Seal: Silicone rubber
O-ring panel Seal: Silicone
Spring: Tinned music wire
Hex Nut: 1/2-32, Brass with Nickel Plating,
P/N 635201
Lockwasher: Internal,1/2 dia. , Steel with
Zinc plating, P/N 635401
Cable Options
* Switch meets IP67 without boot if not
actuated during immersion
CIRCUITRY: SPST N.O.
ORDERING INFORMATION
30-201B-1S
Series
Threaded Bushing
Strain Relief: Blank = shrink tubing, S = strain relief
Connection: Blank = terminals, E = epoxy rear seal
1 = 6" leads, 2 = 12" leads, 3 = 36" leads
Silicone Boot: Blank = no boot, B = black boot, C = clear boot
Cap Color: 0 = black, 1 = red, 2 = green
3 = yellow, 4 = orange, 5 = blue
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
Silicone Boot Part Numbers
Black: 30M4070-1
Clear: 30M4070-2
pictured with
clear silicone boot
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
很抱歉,暂时无法提供与“30-205”相匹配的价格&库存,您可以联系我们找货
