IAR5F1500
IAR5F1500
    APEM(埃斐)
    SWITCH PUSHBUTTON SPDT 2A 24V
IAR5F1500 数据手册
PANEL SWITCHES 09 17 -IA IA series SW Low profile pushbutton switches for harsh environments • bushing Ø 16 mm • momentary DISTINCTIVE FEATURES Resistant to frost, sand and hydrocarbons Tactile feedback Front panel sealed to IP65 and IP67 ENVIRONMENTAL SPECIFICATIONS • Front panel sealing : IP65 and IP67 acc. to IEC 60529 • Salt spray : IEC 512-6, test 11f • Operating temperature : -20 °C to +65 °C (-4 °F to +149 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 2 A 24 VDC • Initial contact resistance : 100 mΩ max. • Insulation resistance : 100 MΩ min. at 500 VDC • Dielectric strength : 500 Vrms • Electrical life at full load : 1,000,000 cycles GENERAL SPECIFICATIONS • Panel thickness : 7 mm (.276) max. • Total travel : 1.5 mm (.059) ± 0.3 mm • Typical operating force : 7 N ± 2 N • Low level or mechanical life : 1,000,000 cycles • Torque : 0.5 to 1 Nm max. applied to nut MATERIALS • Case/bushing : thermoplastic • Actuator : polyurethane • Contacts : silver, gold plated • Multi-wire leads AWG20, section 0.6 mm2. • Terminal seal : epoxy The company reserves the right to change specifications without notice. 1 PANEL SWITCHES IA series Low profile pushbutton switches for harsh environments • bushing Ø 16 mm • momentary PANEL MOUNTING • Panel cut-out Ø 16.2 mm (.657) • Min. pitch for matrix mounting : - with standard hex nut : 27 x 27 mm (1.062 x 1.062) - with knurled nut U3327: 20 x 20 mm (.787x.787) 1 - Flat seal ELECTRICAL FUNCTIONS C Function 3 (NO) 2 NC NO Function 5 (NC/NO) Low profile pushbutton switches for harsh environments • bushing Ø 16 mm • momentary BUILD YOUR PART NUMBER BASIC PART NUMBER IA SERIES ELECTRICAL FUNCTIONS ACTUATOR SHAPES R Round, curved 3 Normally open (NO) 5 NC/NO combined TERMINALS F Flying leads OPTIONS CONTACTS 1 Silver, gold plated ACTUATOR COLORS 1 Blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7/1 9 CASE COLOR 00 Black White Orange ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. A sealing boot is available to protect the switches against frost and sand. See "Sealing Boots" section of website. Mounting accessories : Standard hardware supplied : 1 hex nut 19 mm (.748) across flats and 1 flat seal. Knurled nut U3327 available on request. 3 PANEL SWITCHES IA series IAR3F Normally open (NO) IAR5F NC/NO combined Ø15.00 (.590 DIA) 18.50 maxi (.728MAX.) 1.20 (.047) Ø16.00x1.00SI (.629DIAx1.00IS) Wire colors (NC/NO) : black = common, brown = NC, blue = NO NO model has 2 terminals only. CONTACT MATERIAL BASIC P/N 1 Silver, gold plated ACTUATOR COLORS BASIC P/N 1 2 3 4 5 6 7/1 9 Blue Black Green Grey Yellow Red White Orange CASE COLORS BASIC P/N 00 4 Black EPOXY C NC NO 500.00±10 (19.685±.393) MODELS 3.30 (.129) Low profile pushbutton switches for harsh environments • bushing Ø 16 mm • momentary 10.00 (.393) PANEL SWITCHES IA series Ø19.80 (.779 DIA)
IAR5F1500 价格&库存
很抱歉,暂时无法提供与“IAR5F1500”相匹配的价格&库存,您可以联系我们找货
IAR5F1500
    • 10+201.63272
    • 50+195.42607
    • 100+190.93771
    • 250+186.69927
    库存:59
    IAR5F1500
    • 1+263.273761+34.08859
    • 10+227.1669210+29.41349
    • 25+214.1645425+27.72995
    • 50+204.8081950+26.51849
    • 100+195.84451100+25.35788
    • 250+184.56782250+23.89778
    库存:25
    IAR5F1500
    • 1+187.984791+24.34020
    • 25+171.7521225+22.23840
    • 50+164.6830650+21.32310
    • 100+156.47945100+20.26090
    • 250+148.36311250+19.21000
    • 500+140.24678500+18.15910
    IAR5F1500
      • 1+207.88102
      • 10+201.63272
      • 50+195.42607
      • 100+190.93771
      • 250+186.69927
      库存:28
