AV09C703D240E
AV09C703D240E
    APEM(埃斐)
    SWITCH PUSH SPST-NO 0.05A 24V
AV09C703D240E 数据手册
09 TA 9 V1 AV series -A SW PANEL SWITCHES 17 CT Tactile security pushbutton switches • Ø 19 mm • momentary (NO) DISTINCTIVE FEATURES Tactile feedback Illuminated or non-illuminated Momentary (NO) Marking available ENVIRONMENTAL SPECIFICATIONS • Optional front panel sealing : IP65 according to IEC 60529 • Operating temperature : -30 °C to +70 °C (-22 °F to +158 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 50 mA 24 VDC • LED voltage and consumption : 2-color LED : 2 V (3 V max.) 20 mA Other colors : 2 V (3 V max.) 10 mA A resistor must be series-connected by the user** • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 500 Vrms 50 Hz min. between terminals 2,000 Vrms 50 Hz min. between terminals and frame • Electrical life : 1,000,000 cycles at full load **Resistor value = supply voltage - LED forward voltage LED forward current GENERAL SPECIFICATIONS • Travel : 0.7 mm (.027) ± 0.1 mm (.003) • Operating force : 7 N ± 2N • Torque : 5 Nm min. - 14 Nm max. applied to nut • Panel thickness : 1 (.039) to 6 mm (.236) max. • Hand soldering : 270 °C, 3 seconds max. The company reserves the right to change specifications without notice. 1 PANEL SWITCHES AV series Tactile security pushbutton switches • Ø 19 mm • momentary (NO) MATERIALS • Case : PBT UL94-V0 • Terminals : brass, gold plated • Contacts : gold plated dome • Bushing and actuator : see following pages • LED ELECTRICAL FUNCTIONS Function 3 (NO) MOUNTING • Panel cut-out : Ø 19.2 mm (.755) • Min. pitch for matrix mounting : 30 mm x 30 mm (1.181x1.181) 2 Tactile security pushbutton switches • Ø 19 mm • momentary (NO) BUILD YOUR PART NUMBER BASIC PART NUMBER AV C7 SERIES ACTUATOR TYPES CASE 09 Flat 0 No 19 Curved L Illuminated CONTACTS FUNCTION ILLUMINATION 3 Normally open (NO) D TERMINALS Gold plated dome 2 Solder 9 Screw OPTIONS BUSHING/ACTUATOR MATERIALS Non-illuminated models 00 (std) LED COLORS Blank No LED Nickel plated brass / Nickel plated brass 1 Blue 10 Nickel plated brass / Stainless steel 3 Green 30 Chrome plated bras / Stainless steel 5 Yellow 40 Stainless steel / Stainless steel 6 Red 70 Black chrome plated brass / Black chrome plated brass 7 White 9 Amber 2 Red/green Illuminated models 00 (std) Nickel plated brass / Nickel plated brass 10 Nickel plated brass / Stainless steel 20 Chrome plated brass / Chrome plated brass 40 Stainless steel / Stainless steel 50 Stainless steel / Nickel plated brass 70 Black chrome plated brass / Black chrome plated brass MARKING see following pages SEALING Blank K No sealing Sealed to IP65 ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories: standard hardware supplied : 1 hex nut. Standard and special hardware is presented in the "Hardware" section of website. 3 PANEL SWITCHES AV series Tactile security pushbutton switches • Ø 19 mm • momentary (NO) Hex nut 22 (.866) across flats FLAT ACTUATOR - NON ILLUMINATED Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) Solder lug terminals 2.00 (.078) 4.00 (.157) 1.90 (.074) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Screw terminals Ø15.00 (.590DIA) Ø22.00 (.866DIA) 1.10 (.043) AV09C703D2 EPOXY 4.15 (.163) AV09C703D9 13.50 (.531) 3.90 (.153) 13.50 (.531) 13.20 (.519) CAVDTL-1A FLAT ACTUATOR - ILLUMINATED Ø19.00x1.00 SI (.748DIAx1.00 IS) 2.00 (.078) 2.00 (.078) 4.00 (.157) + Ø10.00 (.393DIA) Ø15.00 (.590DIA) Ø22.00 (.866DIA) Ø15.00 (.590DIA) AV09C7L3D2 Screw terminals 1.90 (.074) 1.10 (.043) Solder lug terminals Ø22.00 (.866DIA) PANEL SWITCHES AV series EPOXY 4.15 (.163) 13.50 (.531) AV09C7L3D9 13.50 (.531) 13.20 (.519) 3.90 (.153) CAVDTL-2A BUSHING/ACTUATOR MATERIALS BASIC P/N NON-ILLUMINATED MODELS ILLUMINATED MODELS CODE BUSHING ACTUATOR CODE BUSHING ACTUATOR 00 (std) Nickel plated brass Nickel plated brass 00 (std) Nickel plated brass Nickel plated brass 10 Nickel plated brass Stainless steel 10 Nickel plated brass Stainless steel 30 Chrome plated brass Stainless steel 20 Chrome plated brass Chrome plated brass 40 Stainless steel Stainless steel 40 Stainless steel Stainless steel 70 Black chrome plated brass Black chrome plated brass 50 Stainless steel Nickel plated brass 70 Black chrome plated brass Black chrome plated brass LED COLORS BASIC P/N Blank 1 3 5 4 No LED Blue Green Yellow 6 7 9 2 Red White Amber Red/green Tactile security pushbutton switches • Ø 19 mm • momentary (NO) MARKING BASIC P/N For flat or curved actuator. - by laser etching on non-illuminated brass or stainless steel actuator. - by hot stamping on thermoplastic insert (illuminated actuators) 8.00 (0.314) Ø10.00 (0.393DIA) 1.50 (0.059) 1.00 (0.039) TYPE OF MARKING 0 to 9 X Y A to N P to W 0 Numbers 0 to 9 Symbol * Symbol # Letters A to N Letters P to W Letter O Letter O : same code and same design as number 0. For special symbols, consult factory. Minimum order : 500 pieces COLOR OF MARKING Select an option from each of the two paragraphs opposite (Type /Color). Non-illuminated actuators : 0 (std) Same as finish 2 Black Note : a finished product supplied in version “0” cannot be modified to version «2». Illuminated actuators 2 Black (on white) SEALING BASIC P/N Blank No sealing K Front panel sealing to IP65 OPTION K 2 - internal gasket 1 - external gasket CAVETKK-A 5 PANEL SWITCHES AV series
AV09C703D240E 价格&库存
很抱歉,暂时无法提供与“AV09C703D240E”相匹配的价格&库存,您可以联系我们找货
AV09C703D240E
  • 100+218.61666100+28.28390
