47CMSP3R2M6RT
47CMSP3R2M6RT
    GRAYHILLINC.
    插件
    船型开关 SPDT 400mA 20VAC 20VDC
47CMSP3R2M6RT 数据手册
Series 47C: Sub-Miniature Rocker Switches Series 47C Sub-Miniature Rocker Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuators and Terminations • UL Recognized Models in inches (and millimeters) SPDT .250 (6.35) SWITCH POSITION MODEL NO. ON ON ON (ON) ON 2-3 MSP1 MSP2 MSP3 MSP4 MSP5 TERM. COMM. NONE NONE OFF OFF OFF OPEN ON (ON) ON (ON) (ON) 2-1 .850 (21.59) Rocker and Paddle Switches MDP1 MDP2 MDP3 MDP4 MDP5 1.095 (27.81) SCHEMATIC TERM. COMM. .250 (6.35) ON NONE (ON) NONE ON OFF (ON) OFF (ON) OFF OPEN 2-1,5-4 1 6 ActuatoR OPTIONS R1 .475 (12.07) .250 (6.35) .110 (2.79) .332 (8.43) .016 (0.41) .020 (0.51) .100 (2.54) EPOXY SEAL .437 (11.10) .200 (5.08) .850 (21.59) 1.095 (27.81) SCHEMATIC 6 .160 (4.06) .300 (7.62) .360 (9.14) .320 (8.13) 1 .324 (8.23) .016 (0.41) .060 (1.52) Ø.093 (Ø2.36) 2 05COMM. 3 4 2 1 3 ()=MOMENTARY 02COMM. 3 .160 (4.06) .300 (7.62) SWITCH POSITION ON ON ON (ON) ON 2-3,5-6 .320 (8.13) 1 .324 (8.23) DPDT MODEL NO. Ø.093 (Ø2.36) .100 (2.54) 2 02COMM. 3 .020 (0.51) 3 ()=MOMENTARY 1 EPOXY SEAL .437 (11.10) 3 5 2 4 1 .110 (2.79) .332 (8.43) .060 (1.52) in inches (and millimeters) .350 (8.87) .580 (14.73) STD. ALL MODELS EXCEPT SPDT WITH M6 TERMINATIONS .300 (7.62) .187 (4.75) R2 .475 (12.07) .250 (6.35) .350 (8.87) .580 (14.73) STD. ON SPDT MODELS WITH M6 TERMINATIONS .230 (7.62) .187 (4.75) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 47C: Sub-Miniature Rocker Switches Termination OPTIONS M1 in inches (and millimeters) M2 Solder Lug .060 (1.52) .110 (2.79) .160 (4.06) .160 (4.06) SP DP Note: Solder lug terminals supplied with mounting ears standard. M6 Right Angle P.C. Mount, Horizontal Actuation .030 (0.76) 1 .020 (0.51) EPOXY SEAL 4 .020 (0.51) DPDT 1 .200 (5.08) .030 (0.76) M7 Right Angle P.C. Mount, Vertical Actuation .016 (0.41) EPOXY SEAL .300 (7.62) 2 P.C. MOUNTING .320 (8.13) 6 .100 (2.54) .200 (5.08) 3 .020 (0.51) .200 (5.08) .100 (2.54) .200 (5.08) .158 (3.96) 5 .100 (2.54) Ø.043 (Ø1.09) .200 (5.08) Ø.043 (Ø1.09) .100 (2.54) Rocker and Paddle Switches .130 (3.30) .200 (5.08) .200 (5.08) .200 (5.08) .417 (10.59) .300 (7.62) 3 .030 (0.76) .158 (4.01) .200 (5.08) 2 DP .200 (5.08) .320 (8.13) .016 (0.41) .200 (5.08) THK. .020 (0.51) SP PC mount terminals supplied without mounting ears standard .130 EPOXY (3.30) SEAL .020 (0.51) .417 (10.5) .230 (5.84) SPDT THK. .020 (0.51) .160 (4.06) THK. .020 (0.51) .030 (0.76) .030 (0.76) .030 (0.76) .060 (1.52) EPOXY SEAL EPOXY SEAL DIP Switches .060 (1.52) THK. .020 (0.51) .130 (3.30) .130 (3.30) EPOXY SEAL EPOXY SEAL .030 (0.76) P.C. Mount (Std) .110 (2.79) P.C. MOUNTING .320 (8.13) .020 (0.51) Ø.043 (Ø1.09) .200 (5.08) 3 2 .030 (0.7) .304 (7.72) SPDT .016 (0.41) .200 (5.08) .100 (2.54) .200 (5.08) .417 (10.59) .300 (7.62) .417 (10.59) EPOXY SEAL P.C. MOUNTING .020 (0.51) DPDT .200 (5.08) .030 (0.76) 6 .200 (5.08) 3 5 2 4 1 Ø.043 (Ø1.09) .320 (8.13) .100 (2.54) .016 (0.41) .200 (5.08) .200 (5.08) .360 (9.14) .200 (5.08) .304 (7.72) .100 (2.54) .200 (5.08) .100 (2.54) .030 (0.76) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Slide DIP Switches 1 Series 47C: Sub-Miniature Rocker Switches Termination OPTIONS V2 in inches (and millimeters) Vertical Bracket P.C. Mount .417 (10.59) .300 (7.62) .400 (10.16) .100 (2.54) .352 (8.94) .130 (3.30) .304 (7.72) 1 SPDT V3 Vertical Bracket P.C. Mount .200 (5.08) .030 (0.76) .300 (7.62) 2 EPOXY SEAL .020 (0.51) .100 (2.54) .360 (9.14) .130 (3.30) Ø.043 (Ø1.09) .304 (7.72) .016 (0.4) Rocker and Paddle Switches .100 (2.54) .200 (5.08) .100 (2.54) 5 6 .200 (5.08) EPOXY SEAL .020 (0.51) .400 (10.16) Specifications Ratings Contact Rating: Q option - 3A with resistive load @ 125 VAC or 28 VDC; 1.5A with resistive load @ 250 VAC. R option - 0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 make-and-break cycles at full load P.C. MOUNTING .400 (10.16) 4 .030 (0.76) Ø.043 (Ø0.19) .417 (10.59) .352 (8.94) DPDT 3 .016 (0.41) Contact Resistance: 20 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C UL Recognition: File number is E35289 .400 (10.16) .200 (5.08) P.C. MOUNTING MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Rocker: Nylon Bushing: Brass, nickel plated Housing: Stainless steel Switch Support: Brass, electrotin plated Terminal/Contacts: Copper alloy with silver or gold plating Terminal Seal: Epoxy Ordering Information Series 47C Sub-Miniature Rocker Switches Model: SPDT: MSP1, MSP2, MSP3, MSP4, MSP5 DPDT: MDP1, MDP2, MDP3, MDP4, MDP4 (See Model for options.) Actuator Options: R1, R2 (See Actuator options.) 47CMSP1R2M6RT RoHS Compliant Type of Contact: R = Copper alloy, gold plate over nickel plate Q = Copper alloy, silver plated Termination Options: M1, M2, M6, M7, V2, V3 (See Termination options.) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
47CMSP3R2M6RT 价格&库存
很抱歉,暂时无法提供与“47CMSP3R2M6RT”相匹配的价格&库存,您可以联系我们找货
47CMSP3R2M6RT
    • 1+108.63720
    • 189+43.35120
    • 513+41.90400
