Series 47C: Sub-Miniature Rocker Switches
Series 47C
FEATURES
• Save Space and Weight
• SPDT and DPDT Circuitry
• Choice of Actuators and Terminations
• UL Recognized
Models
in inches (and millimeters)
SPDT
.250
(6.35)
SWITCH POSITION
MODEL
NO.
ON
ON
ON
(ON)
ON
2-3
MSP1
MSP2
MSP3
MSP4
MSP5
TERM. COMM.
NONE
NONE
OFF
OFF
OFF
OPEN
ON
(ON)
ON
(ON)
(ON)
2-1
.850
(21.59)
Rocker and Paddle Switches
MDP1
MDP2
MDP3
MDP4
MDP5
1.095
(27.81)
SCHEMATIC
TERM. COMM.
.250
(6.35)
ON
NONE
(ON)
NONE
ON
OFF
(ON)
OFF
(ON)
OFF
OPEN 2-1,5-4
1
6
ActuatoR OPTIONS
R1
.475
(12.07)
.250
(6.35)
.110
(2.79)
.332
(8.43)
.016
(0.41)
.020
(0.51)
.100
(2.54)
EPOXY
SEAL
.437
(11.10)
.200
(5.08)
.850
(21.59)
1.095
(27.81)
SCHEMATIC
6
.160
(4.06)
.300
(7.62)
.360
(9.14)
.320
(8.13)
1
.324
(8.23)
.016
(0.41)
.060
(1.52)
Ø.093
(Ø2.36)
2
05COMM.
3 4
2
1
3
()=MOMENTARY
02COMM.
3
.160
(4.06)
.300
(7.62)
SWITCH POSITION
ON
ON
ON
(ON)
ON
2-3,5-6
.320
(8.13)
1
.324
(8.23)
DPDT
MODEL
NO.
Ø.093
(Ø2.36)
.100
(2.54)
2
02COMM.
3
.020
(0.51)
3
()=MOMENTARY
1
EPOXY
SEAL
.437
(11.10)
3
5
2
4
1
.110
(2.79)
.332
(8.43)
.060
(1.52)
.350
(8.87)
.580
(14.73)
STD. ALL MODELS EXCEPT SPDT
WITH M6 TERMINATIONS
.300
(7.62)
.187
(4.75)
R2
.475
(12.07)
.250
(6.35)
.350
(8.87)
.580
(14.73)
STD. ON SPDT MODELS
.230
(7.62)
.187
(4.75)
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Termination OPTIONS
M1
M2
Solder Lug
.060
(1.52)
.110
(2.79)
.160
(4.06)
.160
(4.06)
SP
DP
Note: Solder lug terminals
supplied with mounting ears standard.
M6
Right Angle P.C. Mount,
Horizontal Actuation
.030
(0.76)
1
.020
(0.51)
EPOXY
SEAL
4
.020
(0.51)
DPDT
1
.200
(5.08)
.030
(0.76)
M7
Right Angle P.C.
Mount, Vertical
Actuation
.016
(0.41)
EPOXY
SEAL
.300
(7.62)
2
P.C. MOUNTING
.320
(8.13)
6
.100
(2.54)
.200
(5.08)
3
.020
(0.51)
.200
(5.08)
.100
(2.54)
.200
(5.08)
.158
(3.96)
5
.100
(2.54)
Ø.043
(Ø1.09)
.200
(5.08)
Ø.043
(Ø1.09)
.100
(2.54)
.130
(3.30)
.200
(5.08)
.200
(5.08)
.200
(5.08)
.417
(10.59)
.300
(7.62)
3
.030
(0.76)
.158
(4.01)
.200
(5.08)
2
DP
.200
(5.08)
.320
(8.13)
.016
(0.41)
.200
(5.08)
THK. .020 (0.51)
SP
PC mount terminals
supplied without mounting ears standard
.130
EPOXY
(3.30)
SEAL .020
(0.51)
.417
(10.5)
.230
(5.84)
SPDT
THK. .020 (0.51)
.160
(4.06)
THK. .020 (0.51)
.030
(0.76)
.030
(0.76)
.030
(0.76)
.060
(1.52)
EPOXY SEAL
EPOXY SEAL
DIP Switches
.060
(1.52)
THK. .020 (0.51)
.130
(3.30)
.130
(3.30)
EPOXY
SEAL
EPOXY
SEAL
.030
(0.76)
P.C. Mount (Std)
.110
(2.79)
P.C. MOUNTING
.320
(8.13)
.020
(0.51)
Ø.043
(Ø1.09)
.200
(5.08)
3
2
.030
(0.7)
.304
(7.72)
SPDT
.016
(0.41)
.200
(5.08)
.100
(2.54)
.200
(5.08)
.417
(10.59)
.300
(7.62)
.417
(10.59)
EPOXY
SEAL
P.C. MOUNTING
.020
(0.51)
DPDT
.200
(5.08)
.030
(0.76)
6
.200
(5.08)
3
5
2
4
1
Ø.043
(Ø1.09)
.320
(8.13)
.100
(2.54)
.016
(0.41)
.200
(5.08)
.200
(5.08)
.360
(9.14)
.200
(5.08)
.304
(7.72)
.100
(2.54)
.200
(5.08)
.100
(2.54)
.030
(0.76)
P.C. MOUNTING
Slide DIP Switches
1
Termination OPTIONS
V2
Vertical Bracket P.C. Mount
.417
(10.59)
.300
(7.62)
.400
(10.16)
.100
(2.54)
.352
(8.94)
.130
(3.30)
.304
(7.72)
1
SPDT
V3
Vertical
Bracket
P.C. Mount
.200
(5.08)
.030
(0.76)
.300
(7.62)
2
EPOXY SEAL
.020
(0.51)
.100
(2.54)
.360
(9.14)
.130
(3.30)
Ø.043
(Ø1.09)
.304
(7.72)
.016
(0.4)
.100
(2.54)
.200
(5.08)
.100
(2.54)
5
6
.200
(5.08)
EPOXY SEAL
.020
(0.51)
.400
(10.16)
Specifications
Ratings
Contact Rating: Q option - 3A with resistive
load @ 125 VAC or 28 VDC; 1.5A with resistive load @ 250 VAC. R option - 0.4 VA max
@ 20 Vmax (AC or DC)
Electrical Life: 30,000 make-and-break
cycles at full load
P.C. MOUNTING
.400
(10.16)
4
.030
(0.76)
Ø.043
(Ø0.19)
.417
(10.59)
.352
(8.94)
DPDT
3
.016
(0.41)
Contact Resistance: 20 milliohms max. initial
@ 2-4 VDC, 100 mA
Insulation Resistance: 1,000 megaohms
minimum
Dielectic Strength: 1,000 V RMS @ sea
level
Operating Temperature: -30°C to 85°C
UL Recognition: File number is E35289
.400
(10.16)
.200
(5.08)
P.C. MOUNTING
MATERIALS
Case: Diallyl phthalate (DAP) (UL94V-0)
Rocker: Nylon
Bushing: Brass, nickel plated
Housing: Stainless steel
Switch Support: Brass, electrotin plated
Terminal/Contacts: Copper alloy with silver
or gold plating
Terminal Seal: Epoxy
Ordering Information
Series 47C Sub-Miniature Rocker Switches
Model: SPDT: MSP1, MSP2, MSP3, MSP4, MSP5
DPDT: MDP1, MDP2, MDP3, MDP4, MDP4
(See Model for options.)
Actuator Options: R1, R2 (See Actuator options.)
47CMSP1R2M6RT
RoHS Compliant
Type of Contact: R = Copper alloy, gold plate over nickel plate
Q = Copper alloy, silver plated
Termination Options: M1, M2, M6, M7, V2, V3
(See Termination options.)
Available from your local Grayhill Component Distributor.
For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill.
很抱歉,暂时无法提供与“47CMSP1R1V2RT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+54.65446500+7.07039
