47ASP3J1M6RT
47ASP3J1M6RT
    GRAYHILLINC.
    插件
    船型开关 SPDT 400mA 20VAC 20VDC
47ASP3J1M6RT 数据手册
Series 47A: Miniature Rocker and Paddle Switches SERIES 47A Miniature Rocker and Paddle Switches In inches (and millimeters) SWITCH POSITION MODEL NO. ON ON ON (ON) ON 2-3 SP1 SP2 SP3 SP4 SP5 TERM. COMM. NONE NONE OFF OFF OFF OPEN .185 (4.70) Ø.094 (Ø2.39) SPDT .937 (23.80) 1.156 (29.36) 3 25˚ .155 (3.96) SWITCH POSITION DPDT .020 (0.50) .147 (3.70) .030 (0.76) Ø.094 (Ø2.39) 1.156 (29.36) .937 (23.80) .500 (12.70) 25˚ .155 (3.96) .275 (6.99) 6 .147 (3.70) SCHEMATIC 3P1 3P2 3P3 3P4 3P5 TERM. COMM. 3PDT SWITCH POSITION MODEL NO. ON ON ON (ON) ON 2-3,5-6 .020 (0.50) .030 (0.76) Ø.094 (Ø2.39) .185 (4.70) NONE ON NONE (ON) OFF ON OFF (ON) OFF (ON) OPEN 2-1,5-4 1 05COMM. 3 4 .937 (23.80) 3 2 1 7 5 2 4 1 1.156 (29.36) .080 (2.03) 25˚ .155 (3.96) .080 (2.03) .190 (4.83) 9 .500 8 (12.70) 7 6 5 3 2 4 1 .441 (11.21) 08COMM. 6 3 .450 (11.43) ()=MOMENTARY 02COMM. 6 .376 (9.56) 05COMM. 3 4 .190 (4.83) 3 2 1 ()=MOMENTARY 1 .270 (6.86) .185 (4.70) NONE ON NONE (ON) OFF ON OFF (ON) OFF (ON) OPEN 2-1,5-4 02COMM. 1 3 1 TERM. COMM. 2 Rocker and Paddle Switches .275 (6.99) SCHEMATIC ON ON ON (ON) ON 2-3,5-6 .500 (12.70) .376 (9.56) 02COMM. DP1 DP2 DP3 DP4 DP5 .080 (2.03) 3 2 1 ON (ON) ON (ON) (ON) 2-1 ()=MOMENTARY MODEL NO. .030 (0.76) 9 .275 (6.99) .147 (3.70) .020 (0.50) .650 (11.43) SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com G-4 Slide DIP Switches MODELS DIP Switches FEATURES • Save Space and Weight • SPDT, DPDT, 3PDT and 4PDT Circuitry • Choice of Actuators and Terminations • UL Recoginized Series 47A: Miniature Rocker and Paddle Switches MODELS In inches (and millimeters) 4PDT 4P1 4P2 4P3 4P4 4P5 TERM. COMM. .030 (0.76) Ø.094 (Ø2.39) SWITCH POSITION MODEL NO. .185 (4.70) ON ON ON (ON) ON 2-3,5-6 ON (ON) ON (ON) (ON) 2-1,5-4 NONE NONE OFF OFF OFF OPEN .937 (23.80) 1.156 (29.36) 3 2 1 25˚ .155 (3.96) 02COMM. 05COMM. 3 4 08COMM. 6 ACTUATOR OPTIONS: For Panel Mount Only .275 (6.99) 9 8 7 6 5 3 2 4 1 1.156 (29.36) .937 (23.80) .531 (13.49) .310 (7.87) .365 (9.27) .138 (3.50) .375 (9.52) Rocker and Paddle Switches .020 (0.50) .084 (2.13) R2 1.156 (29.36) .937 (23.80) .850 (11.43) In inches (and millimeters) Ø.094 (Ø2.39) .275 (6.99) 10 .147 (3.70) SCHEMATIC R1 12 .500 (12.70) 11 .020 (0.50) .275 (6.99) 9 7 .190 (4.83) .441 (11.21) ()=MOMENTARY 1 .080 (2.03) .365 (9.27) .875 (22.22) .332 R. (8.43 R.) .740 (18.8) .138 (3.50) Ø.094 (Ø2.39) .020 (0.50) R3 1.625 (41.27) 1.375 (34.92) .595 (15.11) ROCKER WIDTH .906 (23.01) .320 (8.13) .576 NOM. (14.63) .383 (9.73) Ø.125 2 PLCS. (Ø3.17) .505 (12.83) BRACKET WIDTH .093 (2.36) R4 1.625 (41.27) 1.375 (34.92) Ø.125 2 PLCS. (Ø3.17) G-5 .138 (3.50) .024 (0.61) .888 (22.56) .595 (15.11) ROCKER WIDTH .505 (12.83) BRACKET WIDTH .024 (0.61) 1.174 (29.82) 1.312 (33.32) .138 (3.50) .437 (11.10) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 47A: Miniature Rocker and Paddle Switches ACTUATOR OPTIONS: For Panel Rear Mount Only In inches (and millimeters) R5 .595 (15.11) ROCKER WIDTH 1.875 (41.27) 1.625 (34.92) .478 (12.14) 1.318 (33.4) R6 .765 (19.43) PANEL THICKNESS .047 TO .125 (1.19 TO 3.18) DIP Switches .024 .505 (0.61) (12.83) BRACKET WIDTH .138 (3.50) .128 (3.25) PANEL MOUNTING .600 (15.24) .615 (15.62) .090 (2.29) .280 (7.11) .450 (11.43) R7 .093 (2.36) .500 (12.70) .005 R.(4) (0.13 R.) MAX. TYP. .456 (11.58) PANEL MOUNTING Rocker and Paddle Switches .765 (19.43) .600 (15.24) .615 (15.62) .090 (2.29) .450 (11.43) PANEL THICKNESS .047 TO .125 (1.19 TO 3.18) ACTUATOR OPTIONS: For P.C. Mount Only .280 (7.11) .005 R.(4) (0.13 R.) MAX. TYP. .500 (12.70) In inches (and millimeters) R1 Slide DIP Switches .365 (9.27) .531 (13.49) .310 (7.87) .299 (7.59) R2 .084 (2.13) .365 (9.27) .156 (3.96) .332 R. (8.43 R.) .740 (18.80) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com G-6 Series 47A: Miniature Rocker and Paddle Switches ACTUATOR OPTIONS: For P.C. Mount Only In inches (and millimeters) R3 .351 (8.92) .906 (23.01) .595 (15.11) .320 (8.13) 1.055 (26.80) R4 .093 (2.36) .888 (22.55) 1.174 (29.82) .595 (15.11) Rocker and Paddle Switches 1.055 (26.80) R5 .595 (15.11) .478 (12.14) 1.318 (33.48) TERMINATION OPTIONS M1 In inches (and millimeters) Solder Lug .078 (1.98) M2 .156 (3.96) P.C. Mount (Std) M3 P.C. Mount, Quick Connect .075 (1.91) .189 (4.80) EPOXY SEAL .250 (6.35) .250 (6.35) .047 (1.19) .050 (1.27) .080 (2.03) THK. .030 (0.76) THK. .030 (0.76) .062 (1.57) NOTE: Solder lug terminals supplied with mounting tabs standard. PC Mount terminals supplied without mounting tabs standard. G-7 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 47A: Miniature Rocker and Paddle Switches TERMINATION OPTIONS M6 In inches (and millimeters) Right Angle P.C. Mount, Horizontal Actuation PIVOT .062 (1.57) .500 (12.70) EPOXY SEAL .125 (3.18) SPDT 3 .200 (5.08) Ø.073 (Ø1.85) .185 (4.70) .050 (1.27) DIP Switches .030 (0.76) .169 (4.29) .500 (12.70) .200 (5.08) 2 .185 (4.69) .500 (12.70) .016 (0.41) .048 (1.22) 1 .270 (6.86) .230 (5.84) .500 (12.70) EPOXY SEAL PIVOT .125 (3.18) DPDT .016 (0.41) .048 (1.22) .150 (3.81) 5 6 1 2 3 .150 (3.81) .030 (0.76) .200 (5.08) Ø.073 (Ø1.85) .185 (4.70) .500 (12.70) Right Angle P.C. Mount, Vertical Actuation Ø.073 (Ø1.85) .270 (6.86) EPOXY SEAL .150 (3.81) Rocker and Paddle Switches M7 4 .500 (12.70) .050 (1.27) .169 (4.29) .200 (5.08) .450 (11.45) .185 (4.69) 3 .100 (2.54) .125 (3.18) SPDT .500 (12.70) 2 1 2 1 .050 (1.27) .235 (5.97) .500 (12.70) .200 (5.08) .030 (0.76) .016 (0.40) .150 (3.81) .450 (6.86) EPOXY SEAL .100 (2.54) .125 (3.18) DPDT 5 4 .190 (4.83) .050 (1.27) .235 (5.97) .500 (12.70) .050 (1.27) .150 (3.81) .190 (4.83) 6 3 5 2 4 1 .500 (12.70) .500 (12.70) 6 .200 (5.08) .030 (0.76) .016 (0.40) .150 Ø.073 (Ø1.85) .200 (5.08) (3.81) .125 (3.18) 3PDT 7 8 9 6 3 8 5 2 7 4 1 .190 (4.83) .500 (12.70) .565 (14.35) 9 .050 (1.27) .565 (14.35) .650 (16.50) .100 (2.54) EPOXY SEAL .050 (1.27) .235 (5.97) .190 (4.83) .200 (5.08) Slide DIP Switches .050 (1.27) .500 (12.70) 3 .016 (0.40) .030 (0.76) .150 (3.81) .200 (5.08) .150 (3.81) .200 (5.08) Ø.073 (Ø1.85) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com G-8 Series 47A: Miniature Rocker and Paddle Switches TERMINATION OPTIONS In inches (and millimeters) .100 (2.54) EPOXY SEAL .125 (3.18) 4PDT 10 .050 (1.27) V2-V3 Vertical Bracket P.C. Mount 12 9 6 3 11 8 5 2 10 7 4 1 .016 (0.40) .030 (0.76) .150 (3.81) .565 (14.35) .150 (3.81) .565 (14.35) 12 .200 (5.08) .200 (5.08) Ø.073 (Ø1.85) .162 (4.11) .125 (3.18) DIM. "A" OPTION DIM."A" CODE SPDT 2 1 .048 (1.22) .500 (12.70) .050 (1.27) .235 (5.97) .190 (4.83) 11 .190 (4.83) .850 (21.59) 3 .020 (0.51) .185 (4.70) EPOXY SEAL V2 .460 (11,68) V3 .630 (16,00) .620 (15.75) .030 (0.76) Ø.073 (Ø1.85) .185 (4.70) .125 (3.18) .620 (15.75) .320 (8.13) Rocker and Paddle Switches .162 (4.11) .125 (3.18) DIM. "A" .370 (9.40) OPTION DIM."A" CODE DPDT 4 .048 (1.22) 5 6 .020 (0.51) .185 (4.70) V2 .460 (11,68) V3 .630 (16,00) EPOXY SEAL .620 (15.75) .030 (0.76) .190 (4.83) .185 (4.70) .125 (3.18) .320 (8.13) Ø.073 (1.85) .620 (15.75) SPECIFICATIONS RATINGS Contact Rating: Q option - 5A with resistive load @ 125 VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option - 0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 50,000 make-and-break cycles at full load Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C MATERIALS Case: Diallyl phthalate (DAP) (UL 94V-0) Rockers: Nylon (UL 94V-0) Bushing: Stainless steel Terminal/Switch Support: 3/4 Brass, electrotin plated Terminal Seal: Epoxy ORDERING INFORMATION SERIES MODEL NO. ACTUATOR TERMINATION CONTACT SEAL 47A SP1 R2 M6 R E Options: M1, M2, M3, M6, M7, V2, V3 (see termination options) R = Copper alloy, gold plate over nickel plate. E = Epoxy seal 47A = Miniature Rocker and Paddle Switches Options: SP1, SP2, SP3, SP4, SP5, DP1, DP2, DP3, DP4, DP5, 3P1, 3P2, 3P3, 3P4, 3P5, 4P1, 4P2, 4P3, 4P4, 4P5 (see models for switching positions) Example Part Number: 47ASP1R2M6RE Options: R1, R2, R3, R4, R5, R6, R7 (see actuator options) Q = Copper alloy, silver plated Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. G-9 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
47ASP3J1M6RT 价格&库存
很抱歉,暂时无法提供与“47ASP3J1M6RT”相匹配的价格&库存,您可以联系我们找货
