B123J77V7B2
B123J77V7B2
    ELECTROSWITCH
    插件
    船型开关 SPDT 500mA 28VAC 28VDC
B123J77V7B2 数据手册
MINIATURE SWITCHES Ordering Table — Standard Rocker & Paddle Switches HOW TO ORDER YOUR DESIGN (Bold Face Type indicates items normally in Distributor Stock) To determine a part number select the options desired and fill in Following the table from left to right, the designer is able to specify the boxes in the selection guides illustrated below. the options wanted. The options are described and illustrated on pages 24-31. Refer to page 57 for mounting hardware. Rocker Switch Selection Guide Rocker Switch Series Poles and Throw Circuit + Series B + Poles and Throw No. Code SPDT 1 + Circuits Code Description POS. "C" DPDT 2 ON OFF ON 21 3PDT 3 ON NONE ON 23 4PDT ON NONE ON* 26 ON* OFF ON* 27 ON OFF ON* 31 4 ON ON ON ON ON ON* NONE ON ON* ON* ON ON* NONE ON ON Terminal Type Actuator 32 33 34 35 + Actuator Options Type Code Rocker J1 (Screw Mount) Paddle J2 (Screw Mount) Rocker J3 (Screw Mount) Paddle J5 (Screw Mount) Snap-In Mount Rocker With Bezel Snap-In Mount Paddle With Bezel Large Snap-In Mount Rocker With Bezel Large Snap-In Mount Paddle With Bezel Snap-In Rocker 53 J11 J21 J37 J47 J50 Snap-In Rocker J53 Snap-In Paddle J60 Snap-In Paddle J63 Rocker Actuator Paddle Actuator Rocker Actuator Paddle Actuator Rocker Actuator Paddle Actuator J71 J72 J73 Terminal Options Type Right Angle PC Contact Material Actuator Color + + Code A Contact Material Type Code B gold/brass Vertical PC .100 Spacing AV1 gold/silver G White coin silver Q Vertical PC .150 Spacing AV2 PC Terminals Bezels + Actuator Color Color Code Dark Gray 0 Bezels Type + Bright Chrome Code 1M 1 Black 2M Black 2 Satin Chrome 3M K Red 3 White 1P C L Green 5 Black 2P PC & Support V3 M Blue 6 Red 3P PC & Support V4 Light Gray 8 Black w/LED 4P Yellow 9 Green 5P Brown 10 Blue 6P Vertical PC .150 Spacing V5 Other PC & Support V6 PC & Support V7 Light Gray 8P .750 Wire Wrap W Yellow 9P .964 Wire Wrap W1 Dark Gray 0P .425 Wire Wrap W3 1.062 Wire Wrap W4 Solder Lugs Z Quick Connect Z3 Other Option Type Epoxy Sealed Terminals J75 J76 J77 *Momentary Contact 1 and 2 pole only. For J50 and J60 only. For J11, J21, J37 and J47 only. Consult plant for availability. These circuits are NOT available with the following 3 and 4 pole options: A, AV1, AV2, V3, V4, V5, V6 and V7. Epoxy seal standard on all terminal options. Available with C, Z, Z3 or W-W4 terminations. Available with AV1, AV2, V3-V7 terminations. Available with A, AV1, AV2 or V3-V7 terminations. 1, 2 and 3 pole only. See page 58 for construction detail, wiring and electrical diagrams. Same as B, G and Q respectively except terminals brass with tin nickel alloy over nickel plate. Consult plant for availability. EXAMPLES: B121J71AQ2 = SPDT rocker switch with an ON-OFF-ON circuit, J71 style rocker (black), right angle P.C. terminals with coin silver contacts and epoxy sealed terminals. B223J50ZQ22P = DPDT rocker switch with an ON-NONE-ON circuit, J50 style rocker (black), solder lug terminals with coin silver contacts, black snap in bezel and epoxy sealed terminals. 24 Litho in U.S.A GG MINIATURE SWITCHES Standard Rocker & Paddle Switches — Specifications and Materials SPECIFICATIONS MATERIALS Contact Rating — Letter codes G and Q — 6 amp at 125 VAC, 3 amp @ 250 VAC, ( U.L. recognized, CSA certified) or 6 amp at 28 VDC resistive. Letter codes B and G — 0.5. volt-amp (VA) maximum @ 28 V maximum (AC or DC). Base (body) — 1- and 2-pole —Diallyl Phthalate. (DAP). 3- and 4-pole — high strength phenolic. Rocker/Paddle — Molded nylon. Bushing — Brass, nickel plated. Clamp (frame) — Stainless steel. Support Bracket — Steel, tin plated. Metal Bezel — Spring steel. Plastic Bezel — Molded nylon. Switching Contacts and Rockers — Letter Code B — gold/nickel/brass Letter Code G — gold/nickel/silver Letter Code Q — Coin silver Center Terminal Letter Codes B, G — Gold flash/nickel/brass Letter Code Q — Silver plated brass. Hardware — See page 57. Life Under Load — 60,000 make-and-break cycles — resistive load only. Initial Contact Resistance — 10 milliohms maximum. 3 VDC, 100 ma for both silver and gold plated contacts. Insulation Resistance — 1 & 2 pole — 1,000 megohms minimum. 3 & 4 pole — 1,000 megohms minimum. Dielectric Strength — 1,000 volts rms at sea level. Operating Temperature — 30° to +85°C APPROXIMATE BASE DIMENSIONS Litho in U.S.A GG ONE POLE TWO POLE THREE POLE FOUR POLE 25 MINIATURE SWITCHES Rocker Actuator Options For P.C. Mounting J71 J72 J73 J75 J76 J77 ACTUATOR/MOUNTING OPTIONS J1 Screw Mount Rocker Refer to Page 57 for Mounting Hardware J2 Screw Mount Paddle Rocker Refer to Page 57 for Mounting Hardware J3 Screw Mount Large Rocker J5 Screw Mount Large Tappered Paddle Rocker Refer to Page 57 for Mounting Information Refer to Page 57 for Mounting Hardware 26 Litho in U.S.A GG MINIATURE SWITCHES Actuator and Mounting Options — Cont'd J11 Rocker with Snap-In Bezel One Pole PANEL THICKNESS .062 to .125 Two Pole PANEL THICKNESS .062 to .125 J21 Paddle with Snap-In Bezel One Pole PANEL THICKNESS .062 to .125 Two Pole PANEL THICKNESS .062 to .125 J37 Rocker Actuator/Mounting Option J47 Paddle Actuator/Mounting Option Three and four pole switches require assembly from back of panel. Litho in U.S.A GG 27 MINIATURE SWITCHES Actuator and Mounting Options J50 J60 = Snap in Mounting w/Low Profile Rocker = Snap in Mounting w/Low Profile Paddle J50 Rocker Style J60 Paddle Style PANEL CUT-OUT J53 J63 = Snap in Mounting w/High Profile Rocker = Snap in Mounting w/High Profile Paddle PANEL CUT-OUT J53 Rocker Style J63 Paddle Style OPTIONAL BEZELS (For use with J50/J60 Series only) Bezel Assembled with J50/J60 Series Color White Black Red Code 1P 2P 3P J50 Rocker Style w/Bezel Part No. W-BZ-12A W-BZ-12 W-BZ-12B J60 Paddle Style w/Bezel PANEL CUT-OUT Bezel for L.E.D. Assembled with J50/J60 Series (Note: LED is not supplied) Color Black Code 4P Part No. PANEL CUT-OUT W-BZ-15 J50 Rocker Style w/Bezel for L.E.D. J60 Paddle Style w/Bezel for L.E.D. OPTIONAL MOUNTING CLIP (For use with J50/J60 Series only) Clip Assembled with J50/J60 Series • For thick plastic panel mount applications (.094" - .125" thick) • Consult factory for availability PANEL CUT-OUT All rocker switches on this page are snap-in from the front of the panel. No behind panel assembly hardware is needed. 28 Litho in U.S.A GG MINIATURE SWITCHES Termination Options C Printed Circuit W Wire-Wrap W1 Wire-Wrap W3 Wire-Wrap W4 Wire-Wrap Z Standard Z3 Quick Connect Mating Receptacle from AMP SPECIAL IND., P.O. Box 984, Paoli, Pa. 19301 Amp P/N single piece 61454 series, strip from 60900 NOTE: Wire-Wrap is a registered trademark of the Gardner-Denver Company. TERMINATION/MOUNTING OPTIONS A ONE POLE P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS A TWO POLE P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS A P.C. Mounting THREE POLE EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V5 ONE POLE P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS P.C. Mounting V5 TWO POLE EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS The V5 option is available in Three and Four Pole Circuits. Litho in U.S.A GG 29 MINIATURE SWITCHES Termination/Mounting Options AV1 AV2 w/.100" Terminal Spacing w/.150" Terminal Spacing (Pictured Below) 1 Pole P.C. Mounting ONE POLE AV1 AV2 EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS w/.100" Terminal Spacing w/.150" Terminal Spacing (Pictured Below) 2 Pole P.C. Mounting TWO POLE AV1 AV2 EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS w/.100" Terminal Spacing w/.150" Terminal Spacing (Pictured Below) 3 Pole P.C. Mounting THREE POLE AV1 AV2 EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS w/.100" Terminal Spacing w/.150" Terminal Spacing (Pictured Below) 4 Pole P.C. Mounting FOUR POLE 30 EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS Litho in U.S.A GG MINIATURE SWITCHES Termination/Mounting Options V3 1 Pole P.C. Mounting 1 Pole 2 Pole 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V4 1 Pole P.C. Mounting 1 Pole 2 Pole 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V6 1 Pole P.C. Mounting 1 Pole 2 Pole 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS V7 1 Pole P.C. Mounting 1 Pole 2 Pole 2 Pole P.C. Mounting EPOXY SEALED P.C. TERMINALS ARE SUPPLIED AS STANDARD FOR THESE OPTIONS Litho in U.S.A GG 31
B123J77V7B2 价格&库存
很抱歉,暂时无法提供与“B123J77V7B2”相匹配的价格&库存,您可以联系我们找货
