01-Serie NK-A_01-Serie NK-A 06/11/14 13:54 Page2
NK series
Subminiature slide switches
UG1410A
❑ The smallest changeover
❑ Flush and raised actuators
ELECTRICAL SPECIFICATIONS
MATERIALS
• Max. current/voltage rating with resistive load : 0,5A 12V
• Minimum load : 1mA 10mV
• Initial contact resistance : 20 mΩ max.
• Insulation resistance : 10.000 MΩ min. at 500VDC
• Dielectric strength : 250 Vrms. 50 Hz min. between terminals
2.000 Vrms 50 Hz min. between adjacent poles of switches placed side by
side
• Electrical life with nominal load : 2.000 cycles
• Capacitance : < 1,5 pF
• Case : PA6/6, glass filled,
UL94-V0
• Actuator : PA6/6, glass filled,
UL94-V0
• Contacts : gold over nickel
EXAMPLES OF LAYOUT
Ø1.00
(.039DIA)
2.54
(.100)
2.54
(.100)
GENERAL SPECIFICATIONS
• Wave solderable : flux sealed
• End stackable, 2,54 (.100) terminal to terminal pitch - 4 switches max.,
hole dia. 1 mm (.039)
• Travel : 1,6 mm (.062)
• Operating temperature : -40°C to +85°C
• Soldering temperature : 250°C for 5 sec. max.
• Moisture test : 21 days at 95 % RH (IEC 68-2-3)
Ø0.80 - Ø1.00
(.031DIA - .039DIA)
Straight PC terminals
Raised actuator
NK236H
2.60
(.102)
I
I
ON
II
2.54
(.100)
7.90
(.311)
2
3
ON
II
3 1 2
2.54
(.100)
5.00
(.196)
Flush actuator
NK236
1
0.50
(.019)
E
II
1-2
6.50
(.256)
I
1-3
2 1 3
Ø1.00
(.039 DIA)
Ø0.60
(.023 DIA)
10.00
(.393)
ON
ON
Right angle terminals
ON
3 1 2
2.54
(.100)
I
II
2.54
(.100)
7.90
(.311)
0.70
(.027)
3.70
(.146)
10.00
(.393)
ON
2.60
(.102)
I
Ø0.60
(.023 DIA)
Raised actuator
NK236WH
2
3
ON
II
0.50
(.019)
Flush actuator
NK236W
1
II
1-2
6.50
(.256)
I
1-3
2 1 3
Ø1.00
(.039 DIA)
ON
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
Packaging unit : 100 pieces.
The company reserves the right to change specifications without notice.
E-2
www.apem.com
APEM
很抱歉,暂时无法提供与“NK236”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+12.15295
- 50+11.67808
- 125+11.08241
- 250+10.85539
