GH36S010001
GH36S010001
    APEM(埃斐)
    滑动开关 单刀双掷 直插
GH36S010001 数据手册
04-Serie G-A_04-Serie G-A 21/11/12 18:25 Page8 G series Slide switches - telecom grade Distinctive features and specifications ❑ Panel and PC mount models ❑ 6 actuator lengths ❑ Wide variety of contact materials ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (codes 1 or 2) : 3A 30VDC - gold plated brass contacts (code 0) : 0,4VA 20VAC or DC max. • Initial contact resistance : 10 mΩ • Insulation resistance : 1.000 MΩ min. • Dielectric strength : 1.000 Vrms 50 Hz min. • Electrical life with resistive load : - silver contacts (codes 1 or 2) : 2 positions : 40.000 cycles 3 positions : 20.000 cycles - gold plated brass contacts (code 0) : 60.000 cycles (0,4VA max.) E MATERIALS • Case : PES • Actuator : polyamide, glass filled • Cover : stainless steel • Contacts 0 : brass, gold plated 1 : silver 2 : silver, gold plated 5 : special contact, lower rating, minimum quantity : consult factory • Terminal seal : epoxy E-8 GENERAL SPECIFICATIONS • Travel : 2,20 mm (.086), except actuator N on SP model : 2,60 mm (.102) • Operating temperature : -30°C to +85°C • Recommended soldering : 300°C 5 sec. max. www.apem.com APEM 04-Serie G-A_04-Serie G-A 21/11/12 18:25 Page9 G series Slide switches - telecom grade Overview G Actuators SERIES C H L B E N 3,50 mm (.137) 5,10 mm (.200) Standard 6,40 mm (.251) 7,65 mm (.301) 9,10 mm (.358) 9,50 mm (.374) Number of poles 3 4 Terminals Electrical functions Single pole Double pole 6 9 ON ON OFF ON ON S0 P0 W0 WW Y0 Y4 Types L, B and E for single pole models only. Contact and terminal materials 0 1 2 5 Brass, gold plated Silver Silver, gold plated Special contact, lower rating Special options 2 Special options 1 00 10 11 12 Standard model Switch without ground plate 10,35 mm (.407) PC terminals Same as 11, without ground plate Solder lugs Straight PC Right angle, horizontal Right angle, vertical Straight PC with short bracket Straight PC with tall bracket 00 01 10 11 No epoxy seal Epoxy sealed terminals Extended terminals Same as 10, with epoxy seal ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Packaging unit : 100 pieces for SP solder lug (S0) and straight terminal (P0) models. 50 pieces for other models. APEM www.apem.com E-9 E 04-Serie G-A_04-Serie G-A 21/11/12 18:25 Page10 G series Slide switches - telecom grade 2 1.10 (.043) 3 1.80 (.070) 4.00 (.157) 1 5.90 (.232) 4.20 (.165) 1.90 (.074) • Solder lug, straight PC or right angle terminals • Single and double pole configurations 1.10 (.043) MODEL STRUCTURE Shown with standard actuator (type H) 19.50 (.767) 17.53 (.690) 11.40 (.448) 6.10 (.240) 2.40 (.094) 6.65 (.261) 17.53 (.690) 4.70 (.185) ON ON 0.80 (.031) 1.10 (.043) 0.50 (.019) 4.70 (.185) 4.00 (.157) OFF 4.70 (.185) 3.85 (.151) 0.80 (.031) 4.70 (.185) Ø1.60 (.062 DIA) 4.70 (.185) 4.75 (.187) 1.17 (.046) 3.85 (.151) ON ON 0.50 (.019) 4.70 (.185) 1.30 (.051) 0.80 (.031) 3.30 (.129) 4.30 (.169) 9.53 (.375) 13.20 (.519) E-10 www.apem.com Ø1.60 (.062 DIA) 4.70 (.185) 0.80 (.031) 3.85 (.151) 5.70 (.224) 0.50 (.019) 12.70 (.500) OFF 13.60 (.535) 3.81 (.150) Single pole Double pole GH36W0 GH46W0 ON GH39W0 GH49W0 ON 3.85 (.151) 4.70 (.185) 13.60 (.535) 4.70 (.185) 3.85 (.151) 1.10 (.043) 0.50 (.019) 4.70 (.185) 9.53 (.375) Right angle terminals - horizontal 9.50 (.374) 3.85 (.151) Ø1.60 (.062 DIA) 4.70 (.185) 4.40 (.173) 5.10 (.200) 11.40 (.448) 8.25 (.324) 3.85 (.151) 5.10 (.200) Single pole Double pole GH36P0 GH46P0 ON GH39P0 GH49P0 ON 12.70 (.500) 6.65 (.261) 3.85 (.151) 10.55 (.415) 12.70 (.500) 4.00 (.157) 12.70 (.500) 0.50 (.019) 5.10 (.200) Order with epoxy sealed terminals (option 01). Straight PC terminals 0.30 (.011) 5.80 (.228) 12.70 (.500) 0.80 (.031) 12.70 (.500) 0.50 (.019) 7.60 (.299) 6.35 (.250) 0.80 (.031) E 3.85 (.151) 3.85 (.151) 4.20 (.165) ON ON 5.10 (.200) OFF 4.70 (.185) 3.85 (.151) 3.85 (.151) 0.30 (.011) Single pole Double pole GH36S0 GH46S0 ON GH39S0 GH49S0 ON 6.10 (.240) 19.50 (.767) 2.40 (.094) Solder lug terminals 13.20 (.519) 3.10 (.122) Ø1.60 (.062 DIA) 4.70 (.185) APEM 04-Serie G-A_04-Serie G-A 21/11/12 18:25 Page11 G series Slide switches - telecom grade 12.70 (.500) 1.10 (.043) 2.80 (.110) 6.35 (.250) 3.81 (.150) 12.70 (.500) Ø1.60 (.062 DIA) 3.81 (.150) 11.40 (.448) 3.18 (.125) 15.75 (.620) 4.70 (.185) 15.75 (.620) 0.50 (.019) 3.85 (.151) 4.70 (.185) 3.85 (.151) 13.65 (.537) 3.18 (.125) 15.75 (.620) 4.70 (.185) 3.18 (.125) 4.70 (.185) 0.40 (.015) 0.80 (.031) ON ON E 11.40 (.448) 3.85 (.151) 4.70 (.185) 3.85 (.151) OFF Ø1.60 (.062 DIA) Ø1.60 (.062 DIA) 7.50 (.295) Straight PC terminals - tall bracket : Y4 10.46 (.411) 7.50 (.295) 15.75 (.620) 15.75 (.620) Single pole Double pole GH36Y4 GH46Y4 ON GH39Y4 GH49Y4 ON 0.50 (.019) 4.75 (.187) 4.70 (.185) 0.40 (.015) 0.80 (.031) 4.70 (.185) 4.70 (.185) 0.50 (.019) 3.85 (.151) 4.70 (.185) 4.70 (.185) 0.40 (.015) 0.80 (.031) ON ON 3.18 (.125) OFF 3.85 (.151) 9.20 (.362) 3.85 (.151) 0.80 (.031) 0.40 (.015) 0.50 (.019) 15.75 (.620) Ø1.60 (.062 DIA) 4.75 (.187) 15.75 (.620) 14.90 (.586) 4.45 (.175) 7.50 (.295) 3.85 (.151) Single pole Double pole GH36Y0 GH46Y0 ON GH39Y0 GH49Y0 ON Ø1.60 (.062 DIA) 10.16 (.400) Straight PC terminals - short bracket : Y0 4.75 (.187) 4.75 (.187) 6.35 (.250) 4.70 (.185) 2.80 (.110) 3.85 (.151) 3.18 (.125) ON ON 3.85 (.151) 7.50 (.295) 4.70 (.185) 15.75 (.620) Ø1.60 (.062 DIA) 3.18 (.125) OFF 11.40 (.448) 3.85 (.151) 4.70 (.185) 10.16 (.400) 3.85 (.151) Single pole Double pole GH36WW GH46WW ON GH39WW GH49WW ON 12.70 (.500) 6.65 (.261) 12.70 (.500) 4.70 (.185) Right angle terminals - vertical 17.53 (.690) Solder lug model 4.20 (.165) PANEL CUT-OUT Ø2.40 (.094 DIA) 6.50 (.255) APEM www.apem.com 14.90 (.586) 13.65 (.537) 10.46 (.411) 9.20 (.362) 6.35 (.250) 12.70 (.500) 5.70 (.224) 11.40 (.448) 3.30 (.129) 9.50 (.374) 8.25 (.324) 6.65 (.261) PCB MOUNTING E-11 04-Serie G-A_04-Serie G-A 21/11/12 18:25 Page12 G series Slide switches - telecom grade ACTUATORS Replace second digit (H) of basic model number with one of the codes below. G H . . . . 5.10 (.200) 3.50 (.137) L Standard For single pole only E 9.10 (.358) 9.50 (.374) H 7.65 (.301) C 6.40 (.251) Dimensions below are for solder lug (S0) and straight terminals (P0) models. For other models (WO - WW - Y0 - Y4), height is less 0,4 mm (.015). B E For single pole only For single pole only N CONTACT AND TERMINAL MATERIALS 0 1 2 5 E-12 Brass, gold plated Silver Silver, gold plated Special contact, lower rating, minimum quantity : consult factory www.apem.com APEM 04-Serie G-A_04-Serie G-A 21/11/12 18:25 Page13 G series Slide switches - telecom grade SPECIAL OPTIONS 1 00 Standard switch as presented under "Model Structure" 10 Switch without ground plate For right angle only (W0 and WW models) 11 10.35 (.407) 10 10,35 mm (.407) long PC terminals 12 10,35 mm (.407) long PC terminals without ground plate 10.35 (.407) 11 12 2 00 No epoxy seal 01 Epoxy sealed terminals (compulsory on solder lug models) 10 Extended terminals For vertical right angle (WW models) 11 APEM E 21.60 (.850) SPECIAL OPTIONS 10 EPOXY 11 Extended terminals as above, with epoxy seal www.apem.com E-13
GH36S010001 价格&库存
很抱歉,暂时无法提供与“GH36S010001”相匹配的价格&库存,您可以联系我们找货
